Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
119 registered members (2004tdigls, Al, 10WSmuckers, 928, AandPDan, 12 invisible), 1,762 guests, and 53 spiders.
Topics284,678
Posts4,874,959
Members67,313
Most Online2,548
Feb 16th, 2019
Maxlife vs Dex 6 for Silverado transfer case #4809597
07/09/18 07:05 PM
07/09/18 07:05 PM
IL
04SE Offline OP
04SE  Offline OP
IL
I plan on changing the transfer case fluid on my 2014 Silverado this weekend. Spec is 2 quarts of Dex 6. I have a few gallons of Maxlife. Should I just spend the $10 and grab 2 quarts of SuperTech Dex 6 or possibly Valvoline Dex 6 or just pump 2 quarts of Maxlife in there?
Thanks.
Life's little problems can be solved with a shovel and silence.
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: 04SE] #4809613
07/09/18 07:18 PM
07/09/18 07:18 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
If you have to go out and buy fluid, buy the right fluid. If you have Maxlife sitting around, use it.
"Zed's dead baby, Zed's dead."
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: 04SE] #4809639
07/09/18 07:44 PM
07/09/18 07:44 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
No reason I can think of not to use the Maxlife in this situation.
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: 04SE] #4809709
07/09/18 08:57 PM
07/09/18 08:57 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
On the older models such as mine, 2002, been using Mobil 1 10w30 for 15 years. Many of us GM guys are using motor oil. Mike L of Lynwood transmissions strongly suggests synthetic motor oil due to evaporation.
I don't know if they updated and fixed the pump rub problem the older models have, you might check and see if they sell a kit "plate" to alleviate wear thru of the transfer case housing.
eta; its been fixed 2008. Does not apply to your T case.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: 04SE] #4809721
07/09/18 09:13 PM
07/09/18 09:13 PM
Austin, TX
MaximaGuy Offline
MaximaGuy  Offline
Austin, TX
High quality (not that Maxlife isnt but its all over the place from a viscosity standpoint) ATF spewed for DexVI is readily available. Common sense dictates sticking with a DexVI spewed fluid like M1.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: MaximaGuy] #4809726
07/09/18 09:22 PM
07/09/18 09:22 PM
NewYorkistan
BISCUT Offline
BISCUT  Offline
NewYorkistan
I kinda go with this. And I used Maxlife in a Nissan Matic type application for years (2010 Armada).
2015 F150 Lariat M1 0-20 FRAM Ultra(33k)
2017 Sub OB M1 5-30 FRAM Ultra(52k)
Re: Maxlife vs Dex 6 for Silverado transfer case [Re: 04SE] #4809745
07/09/18 10:08 PM
07/09/18 10:08 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
Email Valvoline ensure Maxlife is recommended for this. If so just use up your Maxlife.
don't use.
Moderated by  ekpolk
