Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
50 registered members (69Torino, alarmguy, AndyB, Aero540T, 2015_PSD, 97K15004WD, 5 invisible), 673 guests, and 52 spiders.
Topics284,588
Posts4,872,984
Members67,294
Most Online2,548
Feb 16th, 2019
Page 1 of 4 1 2 3 4
Strange oil consumption issue with '04 Corolla #4809088
07/09/18 10:35 AM
07/09/18 10:35 AM
OH
grampi Offline OP
grampi  Offline OP
OH
My Corolla now has 345K miles. From around 150K miles to around 300K miles, it used 1 qt between oil changes (every 6K miles), which I considered to be normal considering its mileage. At around 300K consumption jumped considerably. It now goes through a qt every 700 miles. I changed the plugs about 20K miles ago and they had about 120K miles on them. They looked normal (they had a light tan powdery haze to them) and the electrodes were still in good shape. I expected them to show signs of oil fouling, but they didn't. I also changed my PCV valve, which did nothing to slow consumption. The car doesn't smoke when started after being parked over night, nor do I see any smoke coming out of the tailpipe when I'm driving. I had car headlights behind me at night which really shows a smoking engine, but mine shows nothing. Question is, where is this oil going? Could it be going out the tailpipe without burning it? It could also be going out through another part of the PCV system, but it seems like I'd be able to see it somewhere. It also doesn't leak. The engine runs fine and I'm just going to keep driving it until something major goes, but I can't figure out where all of this oil is going.
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809126
07/09/18 10:54 AM
07/09/18 10:54 AM
Massachusetts
turtlevette Offline
turtlevette  Offline
Massachusetts
What are you expecting?
USA-1
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809128
07/09/18 10:55 AM
07/09/18 10:55 AM
Michigan
ZZman Online content
ZZman  Online Content
Michigan
Hmmm. No idea. But I would be happy the car is still running.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809134
07/09/18 10:58 AM
07/09/18 10:58 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Any leaks? Valve seals could be worn also.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (37k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809135
07/09/18 10:58 AM
07/09/18 10:58 AM
PimTac Offline
PimTac  Offline
Assuming you have checked for any leaks like the rear main? What oil are you running?
Cannot see signatures any longer so it doesn’t matter.
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809145
07/09/18 11:08 AM
07/09/18 11:08 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
That car/engine owes you nothing at this point & time in its life. Consider doing a piston soak or moving up to a HM oil or up in viscosity also?
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (100K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809154
07/09/18 11:16 AM
07/09/18 11:16 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Without looking into things like the pcv valve, oil leaks, valve seals, doing a compression test, and a leak down test it's hard to tell what is going on. With that kind of miles on the clock sooner or later something is going to let go.
God Bless Our Troops
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809162
07/09/18 11:19 AM
07/09/18 11:19 AM
stl
MarkM66 Offline
MarkM66  Offline
stl
Converter is burning it smokeless.
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809173
07/09/18 11:26 AM
07/09/18 11:26 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
When you changed the PCV valve, did you use an OE one or an aftermarket one?
Having said that, at 345K miles, one quart every 700 miles isn't horrible.
Re: Strange oil consumption issue with '04 Corolla [Re: MarkM66] #4809182
07/09/18 11:34 AM
07/09/18 11:34 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
This.
It takes a lot of oil burning to show smoke with cat converters. My GF's Prius burned a quart every 800 miles and no smoke was visible.
With 345k, my guess is the valve seals and/or piston rings are getting worn.
Re: Strange oil consumption issue with '04 Corolla [Re: grampi] #4809216
07/09/18 12:08 PM
07/09/18 12:08 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
98-02 Corolla engines were ravenous oil burners. Clogged piston oil return holes when cheapo oil was used. They changed the pistons and its not much of an issue anymore. But.. its an aluminum Toyota engine with a thin skin. So it still has the potential to fry cheap oil in those holes.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Strange oil consumption issue with '04 Corolla [Re: turtlevette] #4809251
07/09/18 12:46 PM
07/09/18 12:46 PM
OH
grampi Offline OP
grampi  Offline OP
OH
To find out where the oil is going.
Re: Strange oil consumption issue with '04 Corolla [Re: ZZman] #4809252
07/09/18 12:47 PM
07/09/18 12:47 PM
OH
grampi Offline OP
grampi  Offline OP
OH
I am.
Re: Strange oil consumption issue with '04 Corolla [Re: jeepman3071] #4809254
07/09/18 12:48 PM
07/09/18 12:48 PM
OH
grampi Offline OP
grampi  Offline OP
OH
No leaks, and if the valve seals were bad, I'd see smoke when I first start it up...
Re: Strange oil consumption issue with '04 Corolla [Re: PimTac] #4809255
07/09/18 12:48 PM
07/09/18 12:48 PM
OH
grampi Offline OP
grampi  Offline OP
OH
Supertech
Page 1 of 4 1 2 3 4
Moderated by  ekpolk
