comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
92 registered members (1978elcamino, anndel, 53' Stude, 2015_PSD, AdditiveOCD, 9 invisible), 2,041 guests, and 58 spiders.
Topics286,392
Posts4,907,430
Members67,614
Most Online2,967
Mar 10th, 2019
A/C Residential Arizona #4809001
07/09/18 10:21 AM
07/09/18 10:21 AM
Columbus,Nebraska
Yah-Tah-Hey Offline OP
Columbus,Nebraska
I removed our A/C condenser intake screen as cotton season is over. Late this year because of cool spring. Wondering if A/C units for Arizona market are especially built for Southwest or are units sized larger? Regards. thankyou
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809028
07/09/18 10:42 AM
07/09/18 10:42 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Sized larger. Units selected for a given house are determined by insulation, wall/window area, roof type and area, square footage, and expected outside temperatures.
The great thing about much of Arizona, New Mexico, and parts of west/northwest Texas is that you don't even have to use a traditional AC. With 10% relative humidity, an evaporative cooler will blow 40F air all day long for a fraction of the electricity... though of course it does consume water which may be more costly than electricity at some point.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: A/C Residential Arizona [Re: 440Magnum] #4809064
07/09/18 11:15 AM
07/09/18 11:15 AM
Columbus,Nebraska
Columbus,Nebraska
I grew up in Albuquerque and the swamp coolers did a good job when the east mesa looked like the Conquistadors probably saw it five hundred years ago, but as the city grew and more trees and grass and black top replaced mesa, the swamp coolers weren't so efficient any longer. On a visit ten years ago, I asked my brother about turning the air conditioning on and he said it was going full blast. About a year later, a Carrier A/C unit was keeping their home comfortable. Regards
Re: A/C Residential Arizona [Re: 440Magnum] #4809081
07/09/18 11:32 AM
07/09/18 11:32 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Maybe in the old days some of what you say was true before AC was widely available and average humidity was lower. When the humidity reaches 50%, which it does regularly in monsoon season, as in now, swamp coolers don't work. At all. As to blowing 40 degree air, we moved here from Pa and I was quite interested in the evap process and used to measure temps a lot and on the best days of low humidity you can get 30 degrees differential. 40 degrees on a 100 degree day with 10% RH ain't ever happening. More likely 100 outside = 80 out of the vents.
Nobody in Arizona today runs only a cooler. Well, maybe Flagstaff at 7000 feet but that's not typical desert.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: A/C Residential Arizona [Re: AZjeff] #4809119
07/09/18 11:51 AM
07/09/18 11:51 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
Exactly! 80 degrees is even pushing the limit unless the evap cooler is maintained religiously.
As for the OPs question, remember when the rule of thumb was roughly 500 sq ft per ton of AC? Well,it's not even close anymore. The problem with that rule today is that newer homes are being built to energy efficiency standards which can go to 800 sq ft per ton of AC, or even double/triple that in cooler climates. The reason you don't want to go too big on an HVAC system is that the system will short cycle because it satisfies the thermostat's set temp quicker. Short cycling will not remove enough humidity from the home and make it feel damp and causes more wear and tear on the system also. So no, an AC system is not sized any differently in Arizona than it is in Minnesota, it's size is based off of a load calculation. Look up HVAC load calc and you'll get a better understanding.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809167
07/09/18 12:23 PM
07/09/18 12:23 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
The fact that they don't work doesn't keep them from advertising swap coolers, even on the east coast where they are useless at best. I'm specifically referring to that Artic Air thing.
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809218
07/09/18 01:15 PM
07/09/18 01:15 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I've looked online at some new A/C units, and there is some models built specifically for Arizona. Not sure what the difference is though.
I went on www.hvacdirect.com and selected a random Goodman 13 SEER 3 ton unit, and it says at the bottom:
Quote:
This unit (and all 13 SEER units) cannot be shipped or installed in the following states: Alabama, Arizona, Arkansas, California, Delaware, Florida, Georgia, Kentucky, Louisiana, Maryland, Mississippi, Nevada, New Mexico, North Carolina, Oklahoma, South Carolina, Tennessee, Texas, and Virginia
Click here to see the 14 SEER unit that is available in these states.
For more information about state efficiency requirements, please click here.
Then I found a different 14 SEER unit and it too can't be installed in Arizona:
Quote:
This unit cannot be shipped or installed in the following states: Arizona, California, Nevada, and New Mexico
Click here to see the unit that is available in these states.
Our units are sized larger though. My house is 1,400 square feet and has a 3-1/2 ton A/C. If I were somehow able to magically scoop up this house and plant it in New York, the unit would be way oversized, it would cool it but would short cycle and be very humid in the house. Not good for the unit either.
Same as if you scooped up a NY house and put it in Phoenix. There's no way it could keep cool in the summer.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809226
07/09/18 01:20 PM
07/09/18 01:20 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
The new 1600 sq ft house we moved into in April has a 2 ton/14 SEER unit and has had no trouble cooling when it's 100 out. Exactly what Funflyer said above.
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809319
07/09/18 03:06 PM
07/09/18 03:06 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
I have a 4 ton in my 1655 sq ft house. On really hot days like last week it runs almost continuously to keep the house at 73.
It was so hot I had 3 birds fall dead out of the tree in the front yard and then something came along overnight and ate them shocked2
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: A/C Residential Arizona [Re: Yah-Tah-Hey] #4809333
07/09/18 03:21 PM
07/09/18 03:21 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Not only 'size' but design as latent heat loads are much lower where you live vs. here & East of here in the humid South. Here, both sensible & latent heat removal is critical.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
