Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
104 registered members (69Torino, AandPDan, 2004tdigls, 97K15004WD, 1WildPig, 8 invisible), 1,804 guests, and 51 spiders.
Topics284,677
Posts4,874,922
Members67,313
Most Online2,548
Feb 16th, 2019
Help! Strange charging system symptoms. Bad alt.? #4808768
07/09/18 01:44 AM
07/09/18 01:44 AM
Gold Coast, QL, Australia
19jacobob93 Offline OP
Symptom: washed engine - now alternator intermittently over charging, lights go bright and engine labours every 20secs or so when battery light comes on. Engine power loss under load.
I gave my engine bay a quick rinse down a couple of weeks ago, I've done this dozens of times before without an issue but this time I was heading away and the car wouldn't be started for another 5 days = cold sitting water.
When I came back my battery light was on and the engine sounded slightly labored like the alternator was working over time and I figured it will just be topping the battery up after sitting...
I took it for a drive and the light would go on and off but got less frequent, but now the engine would lose almost all power when under load like setting off from the lights and would take a few seconds to pick back up, which I had to be light on the throttle and fether the revs up. Revved out perfectly fine in neutral/park though.
The battery now showed red or 'replace' so I took it back under warranty but the multimeter test showed it to be fine.
They swapped it anyway and I just fit it but the car still intermittently shows the battery light (every 10-30secs) and when it comes on the engine drops revs a bit like it's laboring and the headlights and dash cluster lights brighten significantly, then back to normal again when the battery light goes off...
Could this random overcharging be a sign of a bad alternator? My guess is water could have sat in it for a few days and caused damage
Car: 2000 Ford Falcon AU2 - 4.0L I6 @330,000km
Oil: Castrol GTX HM 15W50 + LM MoS2
Filter: Ryco Z9
Re: Help! Strange charging system symptoms. Bad alt.? [Re: 19jacobob93] #4808862
07/09/18 06:56 AM
07/09/18 06:56 AM
CA
spackard Offline
spackard  Offline
CA
It sounds like the regulator to me.
Re: Help! Strange charging system symptoms. Bad alt.? [Re: 19jacobob93] #4809184
07/09/18 11:36 AM
07/09/18 11:36 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
In most cases the voltage regulator is part of the alternator.
So, YES, the alternator is bad and needs to be rebuilt.
Depending on the model/type of alternator, a good rebuilder can test it and see if it is just the regulator that needs replacement.
  • 2017 Toyota Sienna
Re: Help! Strange charging system symptoms. Bad alt.? [Re: 19jacobob93] #4809484
07/09/18 05:08 PM
07/09/18 05:08 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
You might pull the electrical connector off the regulator and make sure there is no water in there, no corrosion or something messing up the works. Since it was sitting for 5 days, it may have possibly devloped corrosion in the connector if water was forced into it. Might even be worth de-pinning the connector and just checking to make sure.
This is why I dont wash engines ever. Too many electrical items and connectors that can get water trapped in them, more so if you are using a pressure washer, forcing the water into places it shouldnt be.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Moderated by  ekpolk
