WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
97 registered members (53' Stude, 240_Ed, 2010Civic, 2015_PSD, 8 invisible), 2,221 guests, and 49 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Purolator oil filter problem #4808705
07/08/18 09:51 PM
07/08/18 09:51 PM
SW MN
countryboy9799 Offline OP
SW MN
Hi all, I have a 2014 Yamaha Grizzly 550 and have used the PL14610 filter a time or 2 before along with a Wix filter 51358 with no problems until now. I changed oil about 2 months ago and haven't ridden it a lot but I did go for a ride about a week ago. I go out today and noticed a puddle underneath and it was 1.2 qts. low, holds 2.2 qts. When I added more oil it could leak again at a rate of about 1 drip per minute which is fairly significant! I took the oil filter off and cleaned up the gasket and it still leaked, I planned on replacing it but I just wanted to see if I could find anything wrong.
According to Purolator's website they call for filter ML16817 which is slightly smaller but I don't think that is the problem when I inspected it upon removal and the Grizzly forums recommend this filter as it is a little longer. I have never had an issue with this and it really bothers me because if my son or wife would have driven it that would not have been ideal. Have there been issues like this with Purolator? I will be putting a Wix on before I ride it again.
2012 Subaru Outback 45,000 Miles
1999 Dodge Cummins 125,000 Miles
2014 Toyota Corolla 40,000 Miles
Re: Purolator oil filter problem [Re: countryboy9799] #4808707
07/08/18 09:54 PM
07/08/18 09:54 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Don't blame Purolator because you used a filter other-than the one they stipulate on their website
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Purolator oil filter problem [Re: countryboy9799] #4808715
07/08/18 10:17 PM
07/08/18 10:17 PM
SW MN
SW MN
Where in my post did I blame them??? I am just trying to find out if they have had problems. This filter is recommended for this atv at several atv forums and it has worked for me in the past and this filter has been working for a couple months.
Re: Purolator oil filter problem [Re: countryboy9799] #4808716
07/08/18 10:17 PM
07/08/18 10:17 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Leak-O-Later
Sounds like a leaky crimp on the base.
Re: Purolator oil filter problem [Re: ZeeOSix] #4808720
07/08/18 10:20 PM
07/08/18 10:20 PM
SW MN
SW MN
That is what I was wondering. The fact that it's slightly larger shouldn't make a difference as there was plenty of flat metal where the gasket is.
Originally Posted By: ZeeOSix
Leak-O-Later
Re: Purolator oil filter problem [Re: countryboy9799] #4808743
07/08/18 11:32 PM
07/08/18 11:32 PM
USA
oldhp Offline
oldhp  Offline
USA
Since the Purolator leaked...... Use the Wix 51358(Napa Gold 1358) or if you want, the longer 51356(Napa Gold 1356).
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Purolator oil filter problem [Re: countryboy9799] #4808782
07/09/18 04:02 AM
07/09/18 04:02 AM
Wisconsin
Black_Thunder Offline
Wisconsin
I've used that filter on my wheeler several times and also the bosch and supertech equivalent.
the only filter i've had leak lately was on my r1 i put on a 6607 supertech and its like it wouldn't tighten down like it would tighten and then stop suddenly like the threads were bottoming out. i took it back off and put on a bosch and no issues since.
sometimes filters just leak unfortunately.
I'd buy Callahan autoparts if I could.
Re: Purolator oil filter problem [Re: countryboy9799] #4808790
07/09/18 05:16 AM
07/09/18 05:16 AM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
You could try an XG7317 as well if you wanted a synthetic media filter. The PL14610 filter size is recommended for many ATVs. I used that size on my 2010 Kawasaki Brute Force with great results.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Purolator oil filter problem [Re: countryboy9799] #4808802
07/09/18 05:39 AM
07/09/18 05:39 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
There was some talk about a change in the tapping plate design which caused this filter to no longer work on some motorcycles as the tapping plate bottoms on the fitting on the engine.
This could be what is going on.
Edit, a couple such threads:
http://www.yamahasupertenere.com/index.php?topic=17157.0
https://www.triumphrat.net/air-cooled-twins-technical-talk/543602-defective-purolator-filter.html
Robert
  • 2007 Toyota Prius Touring (It is For Sale)
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Purolator oil filter problem [Re: countryboy9799] #4808811
07/09/18 05:59 AM
07/09/18 05:59 AM
Georgia
MParr Offline
MParr  Offline
Georgia
FRAM lists the PH6017A for that application. This crosses over to WIX 51348, NAPA Gold 1348, Motorcraft 910s, Purolator PH241. There is a specific Purolator oil filter for your application = ML16817
http://www.pureoil.com/en/do-it-yourself/online-catalog/filter-lookup/
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Purolator oil filter problem [Re: countryboy9799] #4808848
07/09/18 07:32 AM
07/09/18 07:32 AM
Just because the math-fit is the same, doesn't allow for the oil pump-pressure differences between a motorcycle oil filter and a car oil filter.
Buy a filter specifically listed in a manual for your bike.
Re: Purolator oil filter problem [Re: Triple_Se7en] #4808873
07/09/18 08:06 AM
07/09/18 08:06 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
There are about 4.5 bazillion folks that have proven that is bunk.
beanoil: Tough under heat, real dirty afterwards.
Re: Purolator oil filter problem [Re: countryboy9799] #4808885
07/09/18 08:20 AM
07/09/18 08:20 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Leaking while engine not running means more detective work needed IMO. In any case Purolator has a strong seam so unless the seam shows damage, there is virtually zero chance it leaks at the seam. If there is a puddle it makes no sense gravity alone is pulling oil from the oil filter.
Re: Purolator oil filter problem [Re: countryboy9799] #4808956
07/09/18 09:40 AM
07/09/18 09:40 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I dont see how a filter will leak majority of oil with no op applied. I vote it's not leaking from the filter.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Purolator oil filter problem [Re: beanoil] #4809005
07/09/18 10:23 AM
07/09/18 10:23 AM
Without any help from the peanut gallery here, then tell us why that filter leaked beanoil?
No help please...... just beanoil, in response to this post.
