Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
116 registered members (Anton93, 2010Civic, 2015_PSD, AlanGonzales, Aichiguy, 13 invisible), 2,045 guests, and 52 spiders.
Topics286,244
Posts4,905,172
Members67,587
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Flash point, base oil quality, performance #4808624
07/08/18 07:53 PM
07/08/18 07:53 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
I always thought there was generally a strong correlation between an engine oil's flash point and the quality of its base stocks, such that an oil with a higher flash point could generally (though not always) be expected to be more resilient at high temps: less shear, fewer deposits, etc. I fully expected there to be exceptions, but I thought that was more-or-less the general trend.
Now I feel like I might have been wrong about that. On the one hand, Castrol Edge Supercar HP -- their Indy Car oil -- has a flash point of 220 C; Mobil 1 FS 0W-40 is at 226 C; and most (all?) of the Pennzoil Ultra line is below 230 C, with some oils only just above 200 C. On the other hand, the dino 5W-20 I'm running now has a flash point of 230 C, and Idemitsu makes an $8/qt 10W-30 with a flash point of 260 C.
Is there no correlation between flash point and base oil quality? Can anything about an engine oil's performance be reasonably inferred from its flash point? If so, what?
2008 BMW M3 Sedan 6MT
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808679
07/08/18 09:15 PM
07/08/18 09:15 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
The problem with flash point is the test reproducibility by ASTM D 92 is +- 9C (+- 16F). To this test reproducibility you need to add batch-to-batch variability, which can give quite a range to the formulation. In addition, the figure published by the manufacturer for the formulation may be the average of their batch data, or the highest, or even the lowest.
In my day I ran thousands of flash points, and monitored lab data on thousands more so I could report an accurate average on our ester data sheets. I knew exactly what the flash point should be for a given pure ester, yet the flash points listed on competitor data sheets for the same ester were all over the place.
If you had a true flash point on the motor oil base oils, I would expect some correlation to base oil quality within a given chemistry, but when you start blending base oil chemistry and adding additives, all bets are off - too many variables. For example, a 4 cSt Group I stock has a flash point of around 400F while a 4 cSt PAO is about 425F, a diester about 440F, and a POE 480F. These differences make it difficult to compare unknown blends.
Noack volatility on the finished motor oil is probably a better measure of base oil quality since it isolates volatility from flammability, but even here there are many variables. For all the above reasons I pretty much ignore flash points.
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808699
07/08/18 09:39 PM
07/08/18 09:39 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Thanks TOM
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808760
07/09/18 01:25 AM
07/09/18 01:25 AM
WA
OilUzer Offline
OilUzer  Offline
WA
How did Noack came up with 250C?
Or who came up with 250C?I
Do we want the Noack test temperature (250C = 482F) be above most (all?) oil flash points to be an effective test or does it matter at all?
Re: Flash point, base oil quality, performance [Re: Tom NJ] #4808814
07/09/18 06:12 AM
07/09/18 06:12 AM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Thanks, Tom!
As a largely-academic aside: is there ever a case where a tougher base oil is less volatile but not less flammable?
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808851
07/09/18 07:35 AM
07/09/18 07:35 AM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Originally Posted By: d00df00d
Thanks, Tom!
Yes, different chemistries may have different flammabilities. For example phosphates would be less flammable at a given viscosity that say a hydrocarbon. There may also be flammability differences between linear hydrocarbons and aromatic hydrocarbons or esters or metal containing additives, but I do not have data on this. Molecular weight distribution is also a factor. The flash point test gathers oil vapors in the space above the oil surface, mixes the vapors with air and attempts to ignite the vapor/air mixture with a flame. The Noack test sweeps the vapors away making it a more pure volatility test. Since both tests are substantially affected by volatility there is a correlation but I wouldn't expect it to be perfect since there is no flame involved in the Noack (not to mention different temperature profiles).
Re: Flash point, base oil quality, performance [Re: OilUzer] #4808864
07/09/18 07:58 AM
07/09/18 07:58 AM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
I don't know who decided on 250C - hopefully it was correlated to some real world performance parameter as all tests should be, but I have also seen what I call "management by round numbers".
Noack and flash point are quite different. Noack evaporates the light ends of an oil by blowing air across the surface at a constant 250C and measures the weight loss of the sample. Flash point slowly heats the oil from ambient to the point at which the vapors give a flash when a flame is passed over. The flame is not applied until the oil is within 27C of the expected flash point, so much of the light ends are already evaporated off. If you added say 5% of a solvent to an oil, the Noack loss would go up by 5% since all of the solvent would be evaporated off under the conditions of the test. The flash point, however, would not be affected since the solvent would be evaporated off before the flame is passed over the oil surface.
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808866
07/09/18 08:00 AM
07/09/18 08:00 AM
New England
Virtus_Probi Offline
New England
Just wanted to mention that I find Tom NJ's contributions here to be very valuable and I always keep an eye out for his posts.
Thanks so much for sharing from your wealth of oil industry knowledge, Tom NJ!
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Flash point, base oil quality, performance [Re: Virtus_Probi] #4808898
07/09/18 08:40 AM
07/09/18 08:40 AM
Alberta
carviewsonic Offline
Alberta
"Just wanted to mention that I find Tom NJ's contributions here to be very valuable and I always keep an eye out for his posts.
Thanks so much for sharing from your wealth of oil industry knowledge, Tom NJ!"
+1
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Flash point, base oil quality, performance [Re: d00df00d] #4808907
07/09/18 08:51 AM
07/09/18 08:51 AM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Thanks! Since I am retired for 11 years now I have to do something with all this useless knowledge floating around in my head before it all fades away! grin2
Now out to the garden to harvest some garlic, onions, peppers and beans.
Re: Flash point, base oil quality, performance [Re: Virtus_Probi] #4808909
07/09/18 08:51 AM
07/09/18 08:51 AM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Seconded! cheers
Re: Flash point, base oil quality, performance [Re: d00df00d] #4809006
07/09/18 10:23 AM
07/09/18 10:23 AM
NJ
bluesubie Offline
bluesubie  Offline
NJ
I wish there was an applause emoticon but Tom will have to settle for thumbsup .
cheers
'04 Subaru Forester 2.5XT
Castrol Edge 0W-40
Re: Flash point, base oil quality, performance [Re: Tom NJ] #4809027
07/09/18 10:41 AM
07/09/18 10:41 AM
New England
New England
What time is lunch? I'm all for some fresh produce...
Sounds like you have found new ways to be productive in your retirement!
Last Change;
M1 0W30 AFE d1G2
Re: Flash point, base oil quality, performance [Re: bluesubie] #4809089
07/09/18 11:36 AM
07/09/18 11:36 AM
Texas
4WD Offline
4WD  Offline
Texas
cheers
Cheers2
Re: Flash point, base oil quality, performance [Re: Virtus_Probi] #4809102
07/09/18 11:41 AM
07/09/18 11:41 AM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Retirement is so busy that I don't know where I ever fund the time to work! Been growing vegetables for over 40 years, just on a larger scale now. Lunch is beet salad with onions, blue cheese, and walnuts. Better hurry over!
Oh, and I brew beer! cheers
Page 1 of 3 1 2 3
