Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
21 registered members (ArrestMeRedZ, blufeb95, ctechbob, edhackett, Bscott07, Bjornviken, 2 invisible), 1,049 guests, and 24 spiders.
Topics305,958
Posts5,283,648
Members71,545
Outside fumes enter cabin on Saab 9-5. #4808479 07/08/18 04:03 PM
G
gr8gatzby Offline OP
G
3 months with my 2004 Saab 9-5 wagon. Stage 0 was the first order of business, including cabin air filter. However, when recirculate is selected, I still get fumes from outside air inside the cabin. Was it installed incorrectly by my mechanic, or is this a design flaw in the system?
'12 Lexus LS460 AWD
'89 Volvo 244 | 322k
'95 Ford F150 | 4x4 | 5.8 | 9MPG
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808497 07/08/18 04:50 PM
E
edwardh1 Offline
E
all recirc systems I think mix some outside air
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Outside fumes enter cabin on Saab 9-5. [Re: edwardh1] #4808505 07/08/18 05:12 PM
K
Kira Offline
K
We've had 3 9-5's in the family. All of 'em allowed a bit of outside air to come in. It's an anti mold & mildew thing.
The Volvos I've had are 100% closed from my experience.
Also, FYI: There's an easy to reach hose on the 2.3l 4 cyl. behind the engine high up so it's quite doable. It can come off the oil drip box and stink to high heaven. Just shove it back on.
Which engine do you have? If it's the 2.3 has PCV modification #6 been done to it? If not it's real easy to do and takes about an hour. There are extra hoses on the right (passenger's side No. America) and one of them T's into the oil filler neck. A new neck is part of the PCV #6 kit.
Good luck with your Saab. They are easy and fun to drive....responsive.
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808576 07/08/18 06:43 PM
slacktide_bitog Offline
What kind of cabin filter is it? Did you get a filter with carbon/charcoal? Was the filter sealed in a plastic bag when you bought it?
Recric doesn't necessarily filter during recirc mode (although some cars will run the recirculated air thru the filter, not all cars do this)
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4889306 10/06/18 02:35 PM
N
NoNameJoe Offline
N
Did you check to make sure the door and motor for recirculation are even working? They may not be working.
In most cases you can observe their operation with the cabin air filter removed. When you adjust the recirculation you should physically see the door (usually with foam seal) move in and out of place.
2015 Civic LX Coupe
