1988 cadillac brougham oil disappearing
by momo - 08/25/19 01:41 PM
Amp draw
by mjk - 08/25/19 01:36 PM
SHELL cracker plant
by 53' Stude - 08/25/19 12:03 PM
Mirrored Window Film
by Warstud - 08/25/19 11:40 AM
I want a Challenger
by Jarlaxle - 08/25/19 11:33 AM
Why not?🤔
by Mad_Hatter - 08/25/19 11:10 AM
CanAm OEM oil alternatives
by Carbon12 - 08/25/19 10:46 AM
2019 Dodge Ram Classic 1500 Big Horn Brakes
by Honda2003 - 08/25/19 10:45 AM
Pontiac V8 oil observation
by CheezWhiz - 08/25/19 10:42 AM
Dillemma ...
by Baveux - 08/25/19 10:41 AM
Schaeffers vs Mobil one
by salesrep - 08/25/19 10:04 AM
Moly EP grease
by rideon - 08/25/19 09:59 AM
grease in a golf cart clutch
by jacobsond - 08/25/19 09:53 AM
Pennszoil
by JohnnyJohnson - 08/25/19 09:32 AM
Clunk from the front when I let out the clutch
by atikovi - 08/25/19 09:16 AM
M1 5w30 SN+ D1 / G2 Make Up ?
by ChrisD46 - 08/25/19 09:07 AM
2015 F150 owners manual rear diff fluid options
by Buzzinhalfdozen - 08/25/19 09:02 AM
Recommend a 7 passenger w/10,000 tow
by sasilverbullet - 08/25/19 08:54 AM
Lawn tractor problem
by supton - 08/25/19 07:57 AM
Jobs and social interaction
by ZZman - 08/25/19 07:52 AM
Faux, jk1401, EricTwoCamaros, Subie5w30, Iautox
69057 Registered Users
94 registered members (2K2AcuraTL, ABerns, Alex_V, Ag76, 11 invisible), 2,517 guests, and 26 spiders.
Topics293,782
Posts5,046,648
Members69,057
Most Online3,532
Jul 30th, 2019
Outside fumes enter cabin on Saab 9-5. #4808479 07/08/18 04:03 PM
G
gr8gatzby Offline OP
G
3 months with my 2004 Saab 9-5 wagon. Stage 0 was the first order of business, including cabin air filter. However, when recirculate is selected, I still get fumes from outside air inside the cabin. Was it installed incorrectly by my mechanic, or is this a design flaw in the system?
'95 Ford F150 | 4x4 | 5.8 | 9MPG
'11 Honda Crosstour | AWD | 3.5 | 21MPG
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808497 07/08/18 04:50 PM
E
edwardh1 Offline
E
all recirc systems I think mix some outside air
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Outside fumes enter cabin on Saab 9-5. [Re: edwardh1] #4808505 07/08/18 05:12 PM
K
Kira Offline
K
We've had 3 9-5's in the family. All of 'em allowed a bit of outside air to come in. It's an anti mold & mildew thing.
The Volvos I've had are 100% closed from my experience.
Also, FYI: There's an easy to reach hose on the 2.3l 4 cyl. behind the engine high up so it's quite doable. It can come off the oil drip box and stink to high heaven. Just shove it back on.
Which engine do you have? If it's the 2.3 has PCV modification #6 been done to it? If not it's real easy to do and takes about an hour. There are extra hoses on the right (passenger's side No. America) and one of them T's into the oil filler neck. A new neck is part of the PCV #6 kit.
Good luck with your Saab. They are easy and fun to drive....responsive.
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808576 07/08/18 06:43 PM
slacktide_bitog Online Content
Online Content
What kind of cabin filter is it? Did you get a filter with carbon/charcoal? Was the filter sealed in a plastic bag when you bought it?
Recric doesn't necessarily filter during recirc mode (although some cars will run the recirculated air thru the filter, not all cars do this)
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4889306 10/06/18 02:35 PM
N
NoNameJoe Offline
N
Did you check to make sure the door and motor for recirculation are even working? They may not be working.
In most cases you can observe their operation with the cabin air filter removed. When you adjust the recirculation you should physically see the door (usually with foam seal) move in and out of place.
2015 Civic LX Coupe
