0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
36 registered members (alphadog, bfleeman, BlakeB, BrianF, Blkstanger, anndel, 2 invisible), 733 guests, and 56 spiders.
Topics298,255
Posts4,988,168
Members67,246
Most Online2,474
Feb 10th, 2019
2014 Silverado differential change #4808474
07/08/18 02:55 PM
07/08/18 02:55 PM
IL
04SE Offline OP
04SE  Offline OP
IL
I changed the front and rear differential fluid in my truck today. The truck has 48,000 miles and the rear fluid came out a dark golden brown and it smelled of grapes and diff lube, quite the combination of smells. The magnet in the bottom of the differential housing had more goop/fuzz than I expected but nothing big enough to actually see with the naked eye. I re-siliconed the magnet in place and let it dry as well. I cleaned/scrubbed the cover in our parts washer and flushed out the housing with brake clean. GM was nice enough to use a reusable gasket.
The front was easy as GM was nice enough to put a drain and fill plug. The fluid that drained out was thick and almost gray. I am guessing they didn't put a synthetic up front.
I refilled both with Mobil 1 75w90. I figure they are easily good for another 50k. I very rarely tow and most miles are commuting or vacation.
Life's little problems can be solved with a shovel and silence.
Re: 2014 Silverado differential change [Re: 04SE] #4808485
07/08/18 03:25 PM
07/08/18 03:25 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Yes, GM often specs conventional fluid for the front diff as they expect it won't be used as much as the back diff; trying to save you 10 bucks. I've seen that severe service sometimes specs synthetic. I have synthetic in the front and rear diff as you have done. Good job!
If you want the job done right......do it yourself.
Re: 2014 Silverado differential change [Re: 04SE] #4808727
07/08/18 09:44 PM
07/08/18 09:44 PM
Washington, DC
CapitalTruck Offline
Washington, DC
I put 75w90 synthetic up front is mine as well as there is a TSB that advises to use it for really cold weather.
2013 Silverado 4.8L VVT 4x4 97k mi - ACDelco Dexos Full Synthetic 5w30 (ExxonMobil variant), ACDelco PF48E
Moderated by  ekpolk
