I've used it on my truck and while the color was almost spot on, their clear yellowed badly. I used it with a proper spray gun clearcoat and it matched well. The primer is garbage IMO, a good 2K spray primer would be a lot better.
Your local automotive paint store can mix your color and put it in an aerosol can. More expensive, but would likely yield better results.
