Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
No start
by Roughneck777. 02/22/19 08:24 AM
A Quick Question for ebay Sellers...
by Touring5. 02/22/19 07:38 AM
Small 4x4 with a 4 cyl and manual not to be found
by Elkins45. 02/22/19 07:17 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
107 registered members (007, 1978elcamino, 240_Ed, 19074, 2000Trooper, 8 invisible), 1,895 guests, and 53 spiders.
Topics284,665
Posts4,874,796
Members67,313
Most Online2,548
Feb 16th, 2019
Will O'Reilly's 1 Gallon Yellow OAT Antifreeze wor #4808335
07/08/18 11:14 AM
07/08/18 11:14 AM
USA
qwerty11 Offline OP
qwerty11  Offline OP
USA
All,
Bottom line up front: Will O'Reilly's 1 Gallon Yellow OAT Antifreeze work in a 2009 Honda Civic 1.8L?
The long version:
I am about to change the coolant out in my 2009 Honda Civic 1.8L. I cannot find any references that indicate what fluids I can use in the Civic except genuine Honda fluids, which are not readily available at my location. Oriley's has one that their website says is a match. However, I'm hesitant to trust the website. Also, I see it is concentrate. Can I just pour the fluid then a proportional amount of distilled water in the radiator and it will naturally mix on its own?
Here is the link:
https://www.oreillyauto.com/detail/b/o-r...009/honda/civic
Re: Will O'Reilly's 1 Gallon Yellow OAT Antifreeze wor [Re: qwerty11] #4808345
07/08/18 11:32 AM
07/08/18 11:32 AM
Basehor, KS
JayhawkRoy Online content
JayhawkRoy  Online Content
Basehor, KS
You might look at the Pentofrost lines of antifreeze for your vehicle. They are more specific to vehicle type and are still about $10/gal at Autozone.
Re: Will O'Reilly's 1 Gallon Yellow OAT Antifreeze wor [Re: qwerty11] #4808350
07/08/18 11:39 AM
07/08/18 11:39 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Re: Will O'Reilly's 1 Gallon Yellow OAT Antifreeze wor [Re: qwerty11] #4808365
07/08/18 12:09 PM
07/08/18 12:09 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Id use the pentofrost concentrate. Once I know there was only water in the system Id fill the correct ratio of antifreeze into the system and top off with water. It will mix in the engine
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Will O'Reilly's 1 Gallon Yellow OAT Antifreeze wor [Re: qwerty11] #4808467
07/08/18 02:46 PM
07/08/18 02:46 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I wouldn't use O'R Dexclone with 2eha in a Honda. Right now as noted previously, Walmart has Valvoline Asian Vehicle, in Honda matching blue tint for ~$12/gal. It's the same as Zerex Asian Formula, just sold at WM.
Readily available, Asian PHOAT so matches Honda oem AF type chemistry. Link is to VAV red/pink tint, however most WM stores now stock the for Honda blue tint AF.
https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-Ready-To-Use-1-Gallon/49660461
EDIT Just noticed comment above about Pentofrost at AZ and forgot about that deal. If you can find the A3 still in stock for $10/gal, that looks best value now.
https://www.autozone.com/antifreeze-radi...534416_580160_0
Moderated by  ekpolk
