Well, at $2.95 a gallon for ethanol free regular in my area vs $2.65 for E10, there is going have to be a major increase in mpg using non ethanol to make it worth while. If a car is getting an average 20 mpg on E10, that equates to about 13.25 cents a mile fuel cost. For non ethanol to be equitable, the mpg average would have to jump to a little over 22 mpg. That is probable, but it is just the break even. if the 3% thing is true, then the real probable average mpg increase is going to be about 21 mpg for non ethanol. That doesn't make the switch worth it. And that is typically what I see with my vehicles between non ethanol and E10.... about a 1 mpg difference at best. So non ethanol only goes in my OPE and motorcycle and my vehicles get some blend of corn. My 3/4 ton pickup gets E85 since it is about $1.10 cheaper a gallon than non ethanol regular. E85 is currently $1.85 a gallon in my area now. Even with the lower mpg, it still is substantially cheaper on a cost per mile basis. The wife's car isn't flex fuel, but gets E15.
And because of Trump's tariffs, corn and soybean prices are heading south. That will make biofuels cheaper yet.
