0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (3dfever, 2strokeNorthstar, Bjornviken, alphadog, bfleeman, BlakeB, 3 invisible), 669 guests, and 59 spiders.
Topics298,255
Posts4,988,171
Members67,246
Most Online2,474
Feb 10th, 2019
Dexcool compatibilty #4808117
07/08/18 06:02 AM
07/08/18 06:02 AM
Hudson, NH
LeakySeals Offline OP
Hudson, NH
I'm having continual problems with leaking and failing plastic heater core quick connects on a 06 Escalade. I want to get rid of the plastic and use metal tees and hoses. Are there any metals I should not use with dexcool?
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Dexcool compatibilty [Re: LeakySeals] #4808150
07/08/18 06:37 AM
07/08/18 06:37 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Have you replaced your radiator cap? Maybe you have a defective one that lets too much PSI build in the system.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Dexcool compatibilty [Re: LeakySeals] #4808153
07/08/18 06:40 AM
07/08/18 06:40 AM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Are the heater hoses too long or too short, or routed wrong, and are putting too much stress on the quick connects?
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Dexcool compatibilty [Re: LeakySeals] #4808161
07/08/18 06:54 AM
07/08/18 06:54 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
If you use the Dorman junk from the parts store they will fail again.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30
2008 Ford Crown Vic P71 4.6 ~166K Miles: AMSOIL SS 0W-30
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
Re: Dexcool compatibilty [Re: skyactiv] #4808169
07/08/18 07:11 AM
07/08/18 07:11 AM
Hudson, NH
Hudson, NH
Don't have one. The gauges say everything is normal. A little under 215.
Re: Dexcool compatibilty [Re: mrsilv04] #4808170
07/08/18 07:13 AM
07/08/18 07:13 AM
Hudson, NH
Hudson, NH
Well it's the factory set up which routes along the engine cover. There isn't much play. And it's difficult to put the engine covers on and off without taking everything off. I do wonder if the engine flexing is slowly wearing these things out. Another reason to change the configuration to metal and a bit longer hoses rerouted away from the engine
Re: Dexcool compatibilty [Re: dogememe] #4808175
07/08/18 07:19 AM
07/08/18 07:19 AM
Hudson, NH
Hudson, NH
I think you might be right. Each one of these failures has been a catastrophic emergency on the side of the highway sending me into the parts store for the Dormans. I've taken videos of them just wiggling loosely on the ends of the heater core pipes. When these things fail they are a catastrophe if it's on the highway. It's just not worth playing games with plastic heating core quick connects anymore. They don't quick disconnect. They are a pain. I just want to put on metal and hoses and be done with it. Those things can ruin your vacation and destroy your engine in a matter of minutes
Re: Dexcool compatibilty [Re: LeakySeals] #4808180
07/08/18 07:23 AM
07/08/18 07:23 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
So what metal and hose do you intend to use instead? Dorman or equivalent junk?
Get the OE parts, hurt once, and move on.
Even my nearly 40 year old Mercedes cars have plastic radiators and they are original.
Re: Dexcool compatibilty [Re: LeakySeals] #4808181
07/08/18 07:23 AM
07/08/18 07:23 AM
Hudson, NH
Hudson, NH
This is a six-month-old Dorman. Everything was fine suddenly a catastrophic loss of coolant on the highway. It just broke in two.
Re: Dexcool compatibilty [Re: JHZR2] #4808183
07/08/18 07:31 AM
07/08/18 07:31 AM
Hudson, NH
Hudson, NH
GM plastic heater hose quick connects are a known weak spot. It was a bad idea and everyone with a GM truck knows it and will be dealing with the problem sooner or later. In my case it was so bad I'm not even using the truck right now until I come up with another solution that isn't plastic.
Re: Dexcool compatibilty [Re: LeakySeals] #4808191
07/08/18 07:40 AM
07/08/18 07:40 AM
Idaho
sprite1741 Offline
sprite1741  Offline
Idaho
Plastic, heat and age are the problem. Unfortunately they (manufacturers) all use it. 12 years and my radiators fail like clockwork. It's always the plastic. The last time the Dodge went the plastic tank split open and gushed hot coolant everywhere.
2005 Grand Prix GXP 5.3L Supertech Synthetic Dexos 5w30 Fram Ultra 3506
1986 Dodge Lancer 2.2L Turbo, Supertech Synthetic 10w30 Fram Ultra 3614
Re: Dexcool compatibilty [Re: LeakySeals] #4808192
07/08/18 07:48 AM
07/08/18 07:48 AM
Hudson, NH
Hudson, NH
I know why they did it. Because the heating core hoses get in the way when you're working on the engine or putting the engine covers back on. In theory it's easy to snap them off and get them out of the way. Well anyone that has dealt with them knows that it's not easy. Doesn't matter I don't need or want weak spot in the cooling system getting me towed on vacation. I want some type of metal tee with rubber hoses. Like the good old days. I'm just not sure which metals are compatible with Dexcool and which are not. I'm assuming aluminum is. But I don't know about brass or Steel
Re: Dexcool compatibilty [Re: LeakySeals] #4808199
07/08/18 08:00 AM
07/08/18 08:00 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I cut those off,remove them then use a new piece of heater hos and slip it past the Barb then clamp it with a hose clamp. Elimating those problematic plastic fittings
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Dexcool compatibilty [Re: LeakySeals] #4808200
07/08/18 08:03 AM
07/08/18 08:03 AM
Georgia
AVB Offline
AVB  Offline
Georgia
Anything but pot metal should be fine. I had to extract quite a few of the old metal quick connects on 5.7 intake manifolds. If the manifold was off it was easiest to just chisel out the remains.
Re: Dexcool compatibilty [Re: Chris142] #4808255
07/08/18 09:41 AM
07/08/18 09:41 AM
Hudson, NH
Hudson, NH
I have rear heat so I think I need a tee? If there was a way to just use hoses I would do that.
Moderated by  ekpolk
