Originally Posted By: TiredTrucker
Not many gasoline based motors get the mileage of a diesel based motor. Many diesels, when operated and maintained properly, will go beyond 1 million miles. But under the right circumstances, some of the new E85 specific motors do get equivalent fuel economy on E85 compared to diesel. The Ricardo 3.6L EBDI E85 and the Cummins 2.8L ETHOS E85 come to mind. And since E85 specific motors have not gone mainstream, we really have no data about longevity compared to their diesel counterparts. Similar components are used, similar compression ratios, etc so one can assume similar life cycles.
You keep claiming economy, but all I can find is "efficiency" parity.
If there's less energy in a gallon...burned at the same efficiency...there's less MPG...pure and simple.
Have asked you for links, for year on where you get the same mileage claims, when I can only get efficiency.
Please provide your sources for mileage parity so that others can see and evaluate your claims.
