Fram Pro Synthetic #9688 **NEW** CUT OPEN
by 53' Stude. 03/24/19 08:26 AM
Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
92 registered members (4WD, AdditiveOCD, 1foxracing, 2003f7, 53' Stude, 9 invisible), 1,757 guests, and 56 spiders.
Topics286,324
Posts4,906,419
Members67,599
Most Online2,967
Mar 10th, 2019
Xenon HID Headlamps #4807760
07/07/18 03:19 PM
07/07/18 03:19 PM
Flaherty, KY
92saturnsl2 Offline OP
Flaherty, KY
My '07 Pacifica I purchased recently has Xenon HID headlamps. This is the first vehicle with this style of lighting that I've owned, so I have a few questions. How is reliability and maintenance with these? Any parts wear out over time and/or does the lighting output degrade with age? Do these work like traditional "bulbs" in when it burns out, you just replace with another? From what I understand they work along the same lines as a metal halide or sodium lamp, so I suspect there's a ballast or other electrical gizmos to make them work. Do these need periodic replacement?
How does the brightness compare to the more modern LED headlights available on new vehicles? Those [LEDs] can be pretty blinding when driving toward one, is the glare reduced or about the same with Xenon HID?
Early this morning was the first chance I had to do some night driving and I must say I'm extremely impressed. It's going to be difficult to go back to my other vehicles with "ordinary" headlamps after driving this one.
EDIT: One other thing--- The fog lights on this car are traditional halogens- the warm white color is several shades more yellow than the bright white of the OEM Xenon headlamps. Is there a bulb I can use in the halogen socket that will more closely resemble the color of the Xenon bulb? I don't want blue bulbs like the trash they sell on Ebay, just a nice bright white. Any suggestions would be appreciated.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: Xenon HID Headlamps [Re: 92saturnsl2] #4807781
07/07/18 03:50 PM
07/07/18 03:50 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
My factory Xenons are 4300k. Those blue ones tend to be in the 6000k range or higher. I believe bulb life on my is about 2500 hours and I might still be on my original ones. They do get slightly dimmer with age but they are way brighter than halogens. I believe they're actually slightly brighter than LEDs but they do cost a lot more so that's why the manufacturers made the switch over to LED. There's usually a ballast that goes with the Xenons and if those go bad, the lights also go out. Both my car have bixenons (both for high and low beam) and I haven't really had to do anything with them yet. Beware of fake bulbs, you can get cheap ones on eBay for $10, but they'll fickler and go out on you. I'd get real bulbs from a real supplier like Home Depot, Rockauto etc that control their inventory chain. Amazon use to just throw all of their inventory and other vendors into one bin so even if you bought it from Amazon, you might end up with a fake.
Re: Xenon HID Headlamps [Re: 92saturnsl2] #4807933
07/07/18 08:27 PM
07/07/18 08:27 PM
CA
spackard Offline
spackard  Offline
CA
You should wait until you've driven on wet, dark roads. I think you'll appreciate the fogs you have.
Re: Xenon HID Headlamps [Re: spackard] #4807993
07/07/18 10:00 PM
07/07/18 10:00 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
+1, Id leave the fogs as is
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Xenon HID Headlamps [Re: Rolla07] #4808018
07/07/18 10:48 PM
07/07/18 10:48 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
I've actually gone the other direction from the OP, I put SUPERJDM5000* Yellow Halogens in my Fog/driving lights.
*obviously not the real brand name. but i forget what it was.
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Xenon HID Headlamps [Re: spackard] #4808079
07/08/18 03:02 AM
07/08/18 03:02 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
I agree. Im the opposite with Xenon mains and LED fogs. I miss the PIAA Hyper yellows I installed in my MINI.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Xenon HID Headlamps [Re: 92saturnsl2] #4808223
07/08/18 09:45 AM
07/08/18 09:45 AM
Canada
Gixxer46 Offline
Gixxer46  Offline
Canada
HID are way better than halogen. They are better than most LED lights. The technology just hasnít surpassed it yet. HID light will travel farther than LED. There is no maintance. You just change the bulb when it stops working or has faded enough. If something else goes like the ballast than that will need to be replaced as well.They do fade with time like halogen and might even change color. Itís mainly just replacement of the bulb.
The glare is controlled by the projector house shutter. The projector is the glass ball looking thing and within it is this piece of metal that limits the height of the light. Thatís why when you pull up to a wall you see a nice straight line. The projector also focuses the light as well. When the high beams are on the shutter raised and is more blinding.
This why some people who put hid in their halogen assembly is terrible because the reflector housing bounces light everywhere. A retro fit needs to be done.
As for your fog lights, get some leds, look at morimoto two strokes or gtr lighting. They have really high lumens and the shorter distance mkes it great for a fog light.
Itís funny how you mention never going back to halogen. The government will make cameras up the ying yang standard but driving by candle light not?
2013 Ram 1500 with a 4.7.
I use 0W-20 year round. I alternate between RP and Amsoil Signature series.
Re: Xenon HID Headlamps [Re: 92saturnsl2] #4808322
07/08/18 12:02 PM
07/08/18 12:02 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Yep, they have ballasts, but they usually last a long time. Often times when HID bulbs fail, they turn purple first. HIDs in projector housings really put out a lot of light.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
