Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
113 registered members (Anton93, 2010Civic, 2015_PSD, AlanGonzales, Aichiguy, 12 invisible), 2,043 guests, and 52 spiders.
Topics286,245
Posts4,905,177
Members67,587
Most Online2,967
Mar 10th, 2019
Brake fluid as a bore cleaner? #4807449
07/07/18 08:47 AM
07/07/18 08:47 AM
Ohio
igolfat8 Offline OP
igolfat8  Offline OP
Ohio
So I am watching YouTube and this guy is testing all sorts of gun oils. He would burn some gun powder, on a piece of steel and then test different gun lubes and cleaners to see which one removed the burnt powder residue. I was bored yesterday so I tried this myself and found some interesting results. I tested lots of different gun lubes, home brew concoctions and firearm solvents that I had on hand plus some other oils and cleaners I had on the shelf too. The results were pretty amazing (to me). So to cut to the chase, plain old Valucraft brake fluid was one of the best at removing the burnt powder residue. Is there any reason you can think of NOT to use brake fluid to clean a barrel bore or firearm internals exposed to burnt powder residue? Would it attack aluminum, SS, poly frames or others parts? I would also assume its not safe to use on wood stock finishes.
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807457
07/07/18 08:56 AM
07/07/18 08:56 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
The big problem I see is that brake fluid is Hydroscopic, absorbs moisture. so if you use it, I would wash the bore well with hot water. Then follow with WD-40 to get out the water. Then oil.
This sounds like a lot more work than good ole bore solvent.
Rod
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807464
07/07/18 09:01 AM
07/07/18 09:01 AM
Ohio
igolfat8 Offline OP
igolfat8  Offline OP
Ohio
Thanks for your reply. I tested good ole' Hoppe's #9 solvent too and even though it gets great reviews it couldn't hold a candle to brake cleaner which I found interesting. I'm not proposing leaving brake cleaner in the bore or internals or using it as a lubricant but merely as a cleaner. I do see a red flag to it being hydroscopic and should be thoroughly flushed out though.
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807473
07/07/18 09:10 AM
07/07/18 09:10 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
If I put my nose to it - OR if I see the wife, kids....etc... running outside the front door in a hurry, I do not buy it for cleaning / lubing / preserving my guns.
If you can afford the phone/desktop and internet fees, you can afford a gun cleaner that does not create eventual health problems. So many folks here spend money when they don't need to and don't spend money when they need to.
Worst scenario?...... spending money to use the product in the wrong manner.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807485
07/07/18 09:20 AM
07/07/18 09:20 AM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Quote:
Hydroscopic
It is 'hygroscopic'
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Brake fluid as a bore cleaner? [Re: Triple_Se7en] #4807493
07/07/18 09:30 AM
07/07/18 09:30 AM
Ohio
igolfat8 Offline OP
igolfat8  Offline OP
Ohio
Are there health risks using brake fluid?
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807495
07/07/18 09:32 AM
07/07/18 09:32 AM
Ohio
igolfat8 Offline OP
igolfat8  Offline OP
Ohio
My second reply should have read brake FLUID and not brake cleaner. I am unable to edit the thread for some reason?
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807498
07/07/18 09:35 AM
07/07/18 09:35 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm not sure about brake fluid as a bore cleaner. The old formula GM Top Engine Cleaner was great for cleaning up powder fouling. The bench rest shooters did it all the time. I tried it myself and it worked very well. It was best done outdoors though.
God Bless Our Troops
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807504
07/07/18 09:40 AM
07/07/18 09:40 AM
Florida
hatt Online content
hatt  Online Content
Florida
What does it do for lead and copper fouling?
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807512
07/07/18 09:52 AM
07/07/18 09:52 AM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
Interesting. Which DOT number is the brake fluid you tested?
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807551
07/07/18 10:27 AM
07/07/18 10:27 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
It's not. And that alone would steer me far away from it for gun use. A lot of automotive brake fluids have warnings right on the bottle, to not allow it to come into contact with painted surfaces. So why risk using something on a gun that could damage some part of it? Back to the risk vs. reward factor. None to be had.
I would stick to solvents and cleaners that won't hurt any part of your weapon through accidental contact. The health risk to using any these products is way overblown. It's not as if the local cemetery has a section for people who have allowed themselves too much contact with brake fluid and gun cleaners.
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807619
07/07/18 11:52 AM
07/07/18 11:52 AM
WY
sloinker Offline
sloinker  Offline
WY
I would use it taking care to stay away from areas not to be cleaned. Wear gloves and follow the cleaning with a light coat of a trusted gun product to protect those clean parts. Try it out on a lesser value weapon for a few months and see for yourself.
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807647
07/07/18 12:29 PM
07/07/18 12:29 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Are we discussing "brake fluid" or "brake cleaner"? Huge difference.
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807748
07/07/18 03:06 PM
07/07/18 03:06 PM
Ohio
igolfat8 Offline OP
igolfat8  Offline OP
Ohio
We are discussing Brake fluid. I mistyped brake cleaner in an above post but Iím unable to edit it for some reason?
Re: Brake fluid as a bore cleaner? [Re: igolfat8] #4807837
07/07/18 05:12 PM
07/07/18 05:12 PM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
CLR really cleans out bores, but itíll take the bluing off, too. Donít ask me how I know. whistle
