0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (bfleeman, anndel, 1WildPig, Ag76, bbhero, 3 invisible), 785 guests, and 57 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
Why is my transfer case fill plug leaking? Picture #4807314
07/07/18 12:49 AM
07/07/18 12:49 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
I have a 1997 GMC Sierra 1500 and keep my transfer case filled up to the bottom of the fill hole to the point it will leak out when you unscrew the fill plug. I have done it this way since it was new. I just flushed the fluid and filled it back up with fresh ATF and now the fluid is seeping out the fill plug. It leaks just enough that a new drop will form in a few days. The plug is tight and I dont know how it is leaking/seeping??? It has never done this before. Any ideas? Would plumbers tape stop it from leaking out? Here is a picture of how much seeps out in a day and eventually it will start running down and dripping.
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807315
07/07/18 01:04 AM
07/07/18 01:04 AM
California
SavagePatch Offline
SavagePatch  Offline
California
Get the red goop.
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807319
07/07/18 01:50 AM
07/07/18 01:50 AM
Massachusetts
turtlevette Offline
turtlevette  Offline
Massachusetts
You could swap the fill and drain plugs to see if its the plug or hole. I believe those are tapered threads so the thread clearance reduces as it gets tighter.
USA-1
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807320
07/07/18 01:52 AM
07/07/18 01:52 AM
South Oz, Australia
ozdrrider Offline
ozdrrider  Offline
South Oz, Australia
Low strength Loctite/sealer. It might be a tapered thread, but it will still leak without sealer.
15 Pajero 3.2 Penrite 10w40 full syn 50K km
06 Suzuki Swift Sport 1.6L 5w30 Nulon full syn
17 Suzuki DR650: Trialing LUBEALLOY LA 35 ES
83 350 Chev powered Ski Boat: Nulon 15w40
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807324
07/07/18 02:48 AM
07/07/18 02:48 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Transmission output shaft seal leak and causing it to overfill?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807330
07/07/18 03:21 AM
07/07/18 03:21 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Wrap some yellow Teflon tape around it. The yellow tape is a bit thicker than the white, its used for gas pipes and works great.
God Bless Our Troops
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807339
07/07/18 04:11 AM
07/07/18 04:11 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Ignore it. Doesn't appear to be enough to worry about. Probably was over torqued. Usually 2-3 threads should be showing when properly fitted and torqued.
The "thinking" man's friend.
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807340
07/07/18 04:24 AM
07/07/18 04:24 AM
NY
mx5miata Offline
mx5miata  Offline
NY
May have have cross threaded or there was debris that got in the threads. Unfortunately you have a leak there get a thread sealant with PTFE.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807351
07/07/18 05:11 AM
07/07/18 05:11 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Lots of good suggestions here. If it is not dripping a few drops overnight I would flush with brake cleaner, dry thoughtlessly then apply a ring of RTV or make-a-gasket / Make-a-seal (goop) around the outside of the threads. Don't get it in the square hole, just a ring around the threads to seal the weep path.
Next time you service the fluid, put some thread sealer on the threads before reinstalling the screw.
Also check to see that the oil is not coming from somewhere above the screw port and running down the body and only collecting there. The threads may be sealing fine but it is the lowest point on the part so any leaks above it will collect there.
Re: Why is my transfer case fill plug leaking? Picture [Re: demarpaint] #4807369
07/07/18 05:49 AM
07/07/18 05:49 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
This ^^^^^^^^^^^^^^^^^
Re: Why is my transfer case fill plug leaking? Picture [Re: demarpaint] #4807376
07/07/18 06:00 AM
07/07/18 06:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
^^^^ This. Its hard to goop oily threads, tighten firmly but don't over tighten tapered threads you can split the case, the tapers acts as a wedge.
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807380
07/07/18 06:04 AM
07/07/18 06:04 AM
Massachusetts
Zaedock Offline
Zaedock  Offline
Massachusetts
I use white Teflon on mine. White or yellow, it will stop seeping.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Why is my transfer case fill plug leaking? Picture [Re: Zaedock] #4807400
07/07/18 06:41 AM
07/07/18 06:41 AM
wv
krismoriah72 Offline
wv
Call me Mr. Obvious..but is that O-Ring 20 years old?
https://www.napaonline.com/en/p/NDP7041346
$6 for plug and o-ring.
Re: Why is my transfer case fill plug leaking? Picture [Re: krismoriah72] #4807462
07/07/18 08:00 AM
07/07/18 08:00 AM
Trav Offline
Trav  Offline
Ok Mr Obvious, wrong plug and there is no O ring. .
Re: Why is my transfer case fill plug leaking? Picture [Re: Chris B.] #4807518
07/07/18 08:57 AM
07/07/18 08:57 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
teflon tape it..
Goop is too messy
just take out the plug inspect threads clean it (brake clean or whatever)
let dry tape it the correct direction for the threads and it will be fine.
Moderated by  ekpolk
