Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
53 registered members (bradepb, AndyB, 97K15004WD, billt460, bbhero, 6 invisible), 614 guests, and 59 spiders.
Topics284,588
Posts4,872,977
Members67,294
Most Online2,548
Feb 16th, 2019
Page 1 of 7 1 2 7
Lowest Noack oil for my 2018 VW GTI #4807307
07/06/18 11:50 PM
07/06/18 11:50 PM
USA
garlicbreadman Offline OP
USA
Hello
I have 2k miles on my oem fill. I plan to change my oil at about 3500 miles. Got a few questions. I want to prolong carbon build up as much as i can.
1) Whats the lowest noack oil from the big oil companys(m1, castrol, valvoline, pennzoil) that meets vw 502 505 specs?
2) Torn between 5w40 and 0w40, which generally has lower noack? I live in san Francisco.
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807308
07/07/18 12:10 AM
07/07/18 12:10 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Originally Posted By: garlicbreadman
Hello
In theory, 5W40 should have lower NOACK then 0W40. However, that is if both oils have same base oil etc. That is usually not the case. I would say safest bet would be Castrol 0W40. Old VISOM based M1 0W40 had NOACK 8.7% (Castrol 0W40 has NoACK of 9.1%) but there is no info on new GTL based M1 0W40. It should have lower NOACK but at the same time it has very high % of sulfated ash, which is not good when it comes to CBU.
I would look W30 oils. 0W30 and 5W30 should have lower NOACK then W40 oils.
Now since you are in CA you should have low sulfur gas. That means you could use VW504.00/507.00 oils. Mobil1 5W30 ESP meets that specification. According to some tests that oil has NOACK of 5.6%. Your 2018 GTI is approved for VW504.00/507.00. However, since that spec. has lower SAPS< I would do 3K and do UOA to see TBN retention and go from there.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807335
07/07/18 04:07 AM
07/07/18 04:07 AM
NY
mx5miata Offline
mx5miata  Offline
NY
VW's use Castrol Edge last I knew stick with it and OE filter.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807375
07/07/18 05:57 AM
07/07/18 05:57 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Driving style has a lot to do with valve deposits...more than oil choice I might argue. Provided you use 502 oil of course.
If you short trip you should have bought a different car. With the maturity of this motor VW should have figured it out by now but I guess they’ve been a little distracted!
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807382
07/07/18 06:08 AM
07/07/18 06:08 AM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
504/507 oil TBN starts low but doesn't come down as fast in my experience. I did a couple uoa on my 2015 Passat TDI at 10k miles and TBN was 3.8 left on both samples. That was the 5w-30 castrol edge professional I bought from the dealer.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Castrol Edge 0W-40
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807423
07/07/18 07:23 AM
07/07/18 07:23 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Mobil 1 0w-40,Shell helix ultra 5w-40 or Pennzoil 5w-40 if you want your engine to stay clean and have trouble free crank case ventilation
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807531
07/07/18 09:12 AM
07/07/18 09:12 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
NOACK? Seriously?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Lowest Noack oil for my 2018 VW GTI [Re: edyvw] #4807606
07/07/18 10:37 AM
07/07/18 10:37 AM
USA
USA
Hello
Thank you! Solid info
Re: Lowest Noack oil for my 2018 VW GTI [Re: garlicbreadman] #4807614
07/07/18 10:46 AM
07/07/18 10:46 AM
WY
sloinker Offline
sloinker  Offline
WY
I will have to find it again but it seems that the Calcium used in oils is the biggest culprit in LSPI for modern engines. Changing oil as often as you plan means Noack should be of less concern than those who have longer OCI's. Here's a link.
http://viewer.zmags.com/publication/ad7eebf9#/ad7eebf9/40
Re: Lowest Noack oil for my 2018 VW GTI [Re: sloinker] #4807626
07/07/18 11:01 AM
07/07/18 11:01 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Euro engines and oils do not have those issues as far as I know.
Re: Lowest Noack oil for my 2018 VW GTI [Re: dbias] #4807627
07/07/18 11:02 AM
07/07/18 11:02 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
That is because it is TDI.
Gasoline is different issue. In my VW CC with 2.0T I barely made 3K with Mobil1 5W30 ESP before TBN dropped below 1.
Re: Lowest Noack oil for my 2018 VW GTI [Re: CT8] #4807694
07/07/18 12:24 PM
07/07/18 12:24 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Originally Posted By: CT8
NOACK? Seriously?
Word.
There's so many more intelligent important (don't want to hurt anyone's feelings) things to base your pick of an oil for your engine, than to blindly pick an oil based solely on its lighter fractions evaporation rate at a temperature most oils and engines will never see.
99% of Americans are a fickle bunch, and will never ever keep ANY vehicle long enough to see the difference between today's oils that meet the specs for whatever engine they are using. The other 1% who do keep a vehicle long enough to see the differences between oils know that nothing mechanical runs forever, and periodically requires some TLC in the driveway. Other than the VW sludgers, most all engine failures and recalls of the past 20 years have been due to manufacturing defects, stupid engineers, or CAFE requirements that ask engines to do something they aren't intended to do nor are very good at (high boost at low RPM). Just my .02, but you are obviously free to interpret and take action as you wish. smile
I'd pick whatever spec oil is available and fits your budget, because honestly, with upper and lower limits for nearly all elemental components of engine oils today, there is very little room to differentiate between competitors when talking spec oils. It all comes down to how well their marketing department works. Hundreds of statistically similar UOAs don't lie.
Re: Lowest Noack oil for my 2018 VW GTI [Re: edyvw] #4807842
07/07/18 04:17 PM
07/07/18 04:17 PM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
Good point about the low sulfur in diesel but i think the sulfur in gasoline had come down in the last couple years so maybe the TBN would hold up better now. will have to look for 504/507 uoa
Re: Lowest Noack oil for my 2018 VW GTI [Re: SubieRubyRoo] #4808026
07/07/18 09:55 PM
07/07/18 09:55 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
NOACK? Seriously?
Word.
European manufacturers are very, very specific about NOACK.
Average American does not drive GTI.
Not sure how CAFE is stupid, but some people survived 20th and moved to 21st century. I understand that in some parts of the U.S. (like in my neighboring states) it is still struggle to move to 20th century.
Re: Lowest Noack oil for my 2018 VW GTI [Re: dbias] #4808027
07/07/18 09:57 PM
07/07/18 09:57 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
It is bit confusing, it is average requirement. Gas refiners could hypothetically ship gasoline up to 80ppm as long as average is I think 15ppm.
That means majority of that low average is already consumed by CA.
Page 1 of 7 1 2 7
Moderated by  ekpolk
