57 registered members (69Torino, Astro_Guy, alarmguy, AndyB, Aero540T, 2015_PSD, 8 invisible),
723
guests, and 53
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,589
Posts4,872,991
Members67,294
Most Online2,548 Feb 16th, 2019
Atf maxlife vs dex 6
#4806976
07/06/18 04:07 PM
07/06/18 04:07 PM
Posts: 309 Washington
Dylan1303
OP
OP
Washington
So i want to do a drain and fill on my equinox. Would you use maxlife or supertech dex6. Which one and why? Those are the 2 choices i have readily available. Would like to focus on just those 2 brands.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi 13 equinox 2.4 awd pp 5w30
Re: Atf maxlife vs dex 6
[Re: Dylan1303]
#4806985
07/06/18 04:17 PM
07/06/18 04:17 PM
Posts: 7,738 USA
slacktide_bitog
USA
If you're still under warranty, use the ST D6. You want something that is licensed Dexron VI during the warranty period. ST is licensed. Maxlife isn't  So my choice would be ST during the warranty, then Maxlife after it expires. Does your transmission have a drain plug?
[Re: Dylan1303]
#4806986
07/06/18 04:17 PM
07/06/18 04:17 PM
Posts: 973 Missouri
gabriel9766
Missouri
So i want to do a drain and fill on my equinox. Would you use maxlife or supertech dex6. Which one and why? Those are the 2 choices i have readily available. Would like to focus on just those 2 brands. any one of them would work. I used AutoZones dex6 in my Malibu at 25k and she's still doing good. Hit 45k omw home from work today. 27% left on the OLM so next oil change she gets, trans drain and fill, cabin filter, air filter, and brake fluid flush along with the full synthetic oil change.
2015 Malibu LT 2.5L PPPP 0w20 46.1K 2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K 2010 Fusion SE 2.5L MC 0w20 110K 2008 Escape XLT 2.3L MC 5w30 187K 2007 Fusion SE 2.3L- 173.5K STHM 0W20
[Re: slacktide_bitog]
#4807006
07/06/18 04:35 PM
07/06/18 04:35 PM
Dylan1303
OP
OP
Washington
If you're still under warranty, use the ST D6. You want something that is licensed Dexron VI during the warranty period. ST is licensed. Maxlife isn't  So my choice would be ST during the warranty, then Maxlife after it expires. Does your transmission have a drain plug? Out of warranty it has 107k as far as i know this will be its first trans service. Also on the back of maxlife it says it can be used for dex 2,3,6. Claiming it can be used doesnt count as a license?
[Re: Dylan1303]
#4807034
07/06/18 05:05 PM
07/06/18 05:05 PM
Posts: 19,696 Iowegia - USA
MolaKule
Iowegia - USA
Out of warranty it has 107k as far as i know this will be its first trans service. Well, then get enough for at least three drains and refills. ATF Technology
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
[Re: Dylan1303]
#4807105
07/06/18 07:06 PM
07/06/18 07:06 PM
Posts: 306 Georgia
Charlie2015
Georgia
They are both good options. I would personally use maxlife because I have used it in the past and liked it.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi 2009 Scion tC Manual (Daily Driver) 165k mi
[Re: Dylan1303]
#4807136
07/06/18 07:49 PM
07/06/18 07:49 PM
Posts: 3,172 Ohio
beast3300
Ohio
I haven't had good luck with Maxlife. I only use Dex 6 in my GM products.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
[Re: Dylan1303]
#4807709
07/07/18 12:46 PM
07/07/18 12:46 PM
Dylan1303
OP
OP
Washington
Ill be going with st dex 6 thanks guys
[Re: Dylan1303]
#4807793
07/07/18 03:06 PM
07/07/18 03:06 PM
Posts: 904 Mississippi
TheLawnRanger
Mississippi
Castrol dex 6 is $5 a quart at AAP. Not that there's anything wrong with supertech.
'99 Cavalier 5w 30 SuperTech conventional '11 Impala 5w 30 Magnatec full synthetic '12 Colorado 5w 30 Magnatec full synthetic *regular Wix oil filters for all
