Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
64 registered members (69Torino, Best F100, Billbert, Astro_Guy, alarmguy, 9 invisible), 786 guests, and 54 spiders.
Topics284,589
Posts4,872,994
Members67,294
Most Online2,548
Feb 16th, 2019
OE or aftermarket brand for thermostats #4806860
07/06/18 01:31 PM
07/06/18 01:31 PM
GTA, Ontario, Canada
gogozy Offline OP
gogozy  Offline OP
car is 2004 TSX, thinking of replace the waterpump, thermostat. I had determine to get the OE waterpump, but I wonder if I shall stick with OE or aftermarket thermostat? what aftermarket brand can be trusted? thanks for suggestion.
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806876
07/06/18 01:52 PM
07/06/18 01:52 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
OEM. One item that I will never cheap out on, is a thermostat.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806884
07/06/18 02:04 PM
07/06/18 02:04 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
OE for sure. Test it before you install it.
"Zed's dead baby, Zed's dead."
Re: OE or aftermarket brand for thermostats [Re: rooflessVW] #4806901
07/06/18 02:26 PM
07/06/18 02:26 PM
NY
demarpaint Offline
demarpaint  Offline
NY
approved
OE Always.
God Bless Our Troops
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806903
07/06/18 02:27 PM
07/06/18 02:27 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
OEM, do it and forget about it.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806915
07/06/18 02:40 PM
07/06/18 02:40 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
I just replaced mine. I didn't go OE. I was shopping for them on RockAuto, the only Motorcraft thermostat they had Listed for My car was a 190 Degree thermostat. every other brand, and the one I took out of the car were 180 Degree units.
I ended up getting a Motorad "failsafe" unit. designed so that if it does fail, it fails open. at least that's what the package/ marketing wank says...
they were all listed about the same price...
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806921
07/06/18 02:44 PM
07/06/18 02:44 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
OEM
My mechanic put a Stant in my grandparentís Trailblazer and it ran warm, the opening was quite a bit smaller than an OEM one.
2015 Hyundai Sonata 2.4L 91k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806944
07/06/18 03:17 PM
07/06/18 03:17 PM
California
VeryNoisyPoet Offline
California
I lean towards OEM.
Exercise the thermostat in a pan of boiling water before you install to make sure it opens and closes properly.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806956
07/06/18 03:32 PM
07/06/18 03:32 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I put a Stant thermostat and radiator cap in my Rav4 as PM at 320,000 miles. The cap failed. The thermostat is working fine. (KoW) After that, everyone said to stick with OEM for caps and thermostats. I have a no-name cap on it now. It works.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806959
07/06/18 03:33 PM
07/06/18 03:33 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
While is highly unlikely you will go wrong with OEM, I've always had good luck with the Stant SuperStat.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
Re: OE or aftermarket brand for thermostats [Re: earlyre] #4806978
07/06/18 04:12 PM
07/06/18 04:12 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
imported garbage! Not only are those inconsistent regarding the opening temp they stick open when the engine gets slightly above normal operating temps.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4806997
07/06/18 04:24 PM
07/06/18 04:24 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
OE only 100% Motorad "failsafe" is garbage I wouldn't put in any car.
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4809301
07/09/18 01:50 PM
07/09/18 01:50 PM
gogozy Offline OP
gogozy  Offline OP
sorry for delay, had a family emergency over the weekend.. it also cause me getting too tired, and worn out, and forgot to put the ATF fill bolt back on the MDX and drove it for ~15km before I realize it.. luckily the car seems fine for now.
thanks for everyone's unanimous advise, definitely will get the OE thermostats!
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4810146
07/10/18 10:44 AM
07/10/18 10:44 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
OE or Stant for thermostats.
Re: OE or aftermarket brand for thermostats [Re: gogozy] #4810326
07/10/18 12:56 PM
07/10/18 12:56 PM
California
nthach Offline
nthach  Offline
California
OE for 80% of the stuff out there. I'll use Stant on older American products. Supposedly Stant now has an "OE Exact" line but unless they are sourcing their Japanese/Korean t-stats from NTCL or Kuhzeh, it might not be.
Moderated by  ekpolk
