When a smart charger is hooked to a battery that is up in the 12.65 or higher range, it seems to think the battery is close to fully charged,, and can instantly goto float stage, despite the battery being well below 100%.
One mmust outsmart the smmart charger.. Load the battery until voltage falls to the 12.5 or less range.
The charger should then seek 14.x volts with its mmaximum output.
Those with flooded batteries, with removable caps, can take hydrometer readings, See SG's in the fair to poor range, yet the charger will say all is fine and dandy, and throw that green light and hold float voltages, low 13's.
Very little pressure difference between 12.8 and 13.2. very few amps flow.
When the charger is trying to get the battery to 14.7, much bigger pressure difference, more amps flow, and that extra pressure can be required, not just to save time, but to reexpand the battery capacity back to its remaining potential.
One will never return a used battery to its max remaining capacity at float voltage.
Load the battery with something that can drag voltage to sub12,5v quickly, restart charger, remove load. Pray voltage at battery terminals climbs to 14.5ish volts and stays there for an hour or 4.
The battery state of charge Polygraph is the temperature compensated hydrometer.
When one uses one of these on a questionable battery, and one uses this trick the charger into doibng its job, by loading battery, restarting charger and forcing it to seek absorption voltage, one will likely see the specific gravity rise a bit more each time, upto the 1.275 range.
Note 1.275 specific gravity is not 12.75 volts and batteries in cold climates might go as high as 13.100 and those for intended for hot climates might only reach 1.265.
Trick your charger into doing its job. Load battery, drop voltage below 12.6, restart charger, let it go.
Lather rinse repeat until specific gravity no longer rises in response to time at 14.5ish volts.
the time it takes fore Sg to max out at 14.5v can be 2 hours, the time it can take for it to do it at 13.3 volts can be 5 days, or very possibly never.
Each and every lead acid battery since the beginning of lead acid batteries has always wanted to be 100% charged, and kept cool. Thge tool for determining 100% state of charge is bnot the green light on the smart charger. Their pootential to fully charge a battery was castrated at the factory for fear of overcharging. Like battery bubblewrap for helicopter parents.
That said any charging is better than no charging, just know 100% charged is not determined by a green light, no matter how impressive the marketing material is written, ,along with their 8 to 33 stages of charging, the last of which fellates the purchaser once the battery got its green light happy ending.
