Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
111 registered members (10WSmuckers, 69Torino, 2004tdigls, 97K15004WD, 1WildPig, 7 invisible), 1,823 guests, and 49 spiders.
Topics284,677
Posts4,874,933
Members67,313
Most Online2,548
Feb 16th, 2019
TPMS sensor life #4806500
07/06/18 06:37 AM
07/06/18 06:37 AM
Shippensburg, PA
novadude Offline OP
novadude  Offline OP
Shippensburg, PA
How long do TPMS sensors last? I've got a set on my winter wheels / tires going on 7 years old. Tires are only used ~5 months out of the year. I assume these have a battery of some type with finite life. I need new winter tires this year. Is it a good idea to replace the TPMS sensors while the tires are off, or can they go a lot longer than 7 years?
Re: TPMS sensor life [Re: novadude] #4806511
07/06/18 06:47 AM
07/06/18 06:47 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
You might get another couple of years out of your current sensors, but it would be a good idea to either rebuild your sensors when you mount the new tires - only good if the rebuild includes a new battery, but may not be possible with all sensor brands - or replace the sensors with new ones.
HTH
USN NAVSECGRU 1970-1974
Re: TPMS sensor life [Re: novadude] #4806515
07/06/18 06:51 AM
07/06/18 06:51 AM
SE Michigan
MichiganMadMan Offline
SE Michigan
They'll last about 10 years, so I'd replace them for sure while you have the tires off.
2015 Chevrolet Impala
2011 E-350
2008 Subaru Impreza STI
2012 Honda NC700X
2011 Jonsered 2188 Chainsaw-The Judge.
Re: TPMS sensor life [Re: novadude] #4806521
07/06/18 06:56 AM
07/06/18 06:56 AM
WI.
dblshock Offline
dblshock  Offline
WI.
I disabled the TPMS.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: TPMS sensor life [Re: novadude] #4806562
07/06/18 07:40 AM
07/06/18 07:40 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
The odds are they can last over ten years but one out of four might not make it that long. If you make it 7 years and need to replace the tires around then, I would replace them.
If you want the job done right......do it yourself.
Re: TPMS sensor life [Re: novadude] #4806571
07/06/18 07:48 AM
07/06/18 07:48 AM
North TX
RTexasF Offline
RTexasF  Offline
North TX
We replaced ours at 8 years while getting new tires. Our RAV4s have five sensors, that added $300 to the cost of the tires times two....OUCH!
Re: TPMS sensor life [Re: novadude] #4806581
07/06/18 07:55 AM
07/06/18 07:55 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
I have a 2008 and 2010 Civic with TPMS. The 10's are original and I think the 08's are too. I plan to disable the TPMS light when they come on. I'm not going to spend a couple hundred bucks on each car to get new sensors. I'll just check my tire pressure myself. They really don't even work that well anyways...
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: TPMS sensor life [Re: RTexasF] #4806587
07/06/18 07:58 AM
07/06/18 07:58 AM
Snagglefoot Offline
Snagglefoot  Offline
There are cheaper ways such as buying them on Amazon, but you need a cooperative tire shop to put them in. I think most tire shops look at these as a nice profit center.
Having said that, they can save your life or those of your wife and kids. Not just by avoiding a blowout, but by avoiding being stuck on a freeway and having your family subjected to meeting a new group of “friends” on the side of the road.
Re: TPMS sensor life [Re: novadude] #4806605
07/06/18 08:15 AM
07/06/18 08:15 AM
Texas
wag123 Offline
wag123  Offline
Texas
It is going to depend on how long they are actually being used on a vehicle that is being driven. Most of them only power ON and transmit a signal when the tire is spinning faster than a certain speed, usually about 30 mph. When they are sitting static they power themselves OFF and the lithium battery is not being used/depleted.
Re: TPMS sensor life [Re: 2010Civic] #4806774
07/06/18 11:25 AM
07/06/18 11:25 AM
Ohio
hallstevenson Offline
Ohio
$50 for a 2-pack (VDO SE1001HP). I presume most units can be had for a similar price. Sam's Club will install for $5/tire and a $19 programming fee. I think Walmart has similar price. Check with your preferred tire shop too. Certainly doesn't have to cost a couple hundred bucks.
Re: TPMS sensor life [Re: hallstevenson] #4806792
07/06/18 11:44 AM
07/06/18 11:44 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
Amazon has the VDO 2-pack for $53, which it says do not fit my 2010 Civic. So that is $106 for all 4. Plus $40 for install/programming. Almost $150 out the door. I'll pass.
2010 Honda Civic LX
59,992 miles
Re: TPMS sensor life [Re: novadude] #4807173
07/06/18 08:21 PM
07/06/18 08:21 PM
Snagglefoot Offline
Snagglefoot  Offline
If they lasted 7 years, $150 would be just over $21.00 per year vs doing a tire change in an interesting hood. smile
Re: TPMS sensor life [Re: novadude] #4807428
07/07/18 07:28 AM
07/07/18 07:28 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
TPMS won't prevent you from having a flat?
2010 Honda Civic LX
59,992 miles
Re: TPMS sensor life [Re: novadude] #4807637
07/07/18 11:20 AM
07/07/18 11:20 AM
Texas
wag123 Offline
wag123  Offline
Texas
Ever wonder what drivers did for the 100+ years that TPMS was not available?
I check my tire pressures regularly and I keep an eye on my tires, always have. I am not about to spend what amounts to a pretty good percentage of the cost for a new set of tires to replace TPMS sensors. For me, this is a waste of money. I would rather invest the money in a better quality set of tires and replace them more often.
Re: TPMS sensor life [Re: Snagglefoot] #4807814
07/07/18 03:41 PM
07/07/18 03:41 PM
NH
supton Offline
supton  Offline
NH
So if you bought a car that didn't have them, would you retrofit them?
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 201k, his
Moderated by  ekpolk
