No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
122 registered members (10WSmuckers, 928, Alisobob, AandPDan, AdditiveOCD, 11 invisible), 1,746 guests, and 55 spiders.
Topics284,678
Posts4,874,959
Members67,313
Most Online2,548
Feb 16th, 2019
Greasing Chassis #4806460
07/06/18 05:31 AM
07/06/18 05:31 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Car in question is my 2018 Chevy Silverado 3500HD.
I get a couple of free oil changes at the dealership, so yesterday I had the oil changed for the first time in my new truck. I asked about chassis grease and the service manager said:
"You don't want to add grease until the rubber boot is deflated, otherwise you will rupture it"
I'll be the first to admit, I'm inexperienced at hitting ball joints, tie rod ends, and other zerks with a grease gun. But it's my understanding is that you squeeze fresh grease through the zerk until you see it push out the other side of joint? Is that not the case?
Of course, I could see a bozo pumping the snot out of a grease gun and blowing out the seal.
And one last question, what happens to the grease over time? Does it slowly seep out of the junctions and fall away?
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Greasing Chassis [Re: Phishin] #4806470
07/06/18 05:53 AM
07/06/18 05:53 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I'm with you. I like greasing my suspension parts until I can watch the boot filling up with grease. If some grease spewed out, not biggie!
Where does the grease go? I think that over time with suspension movement up & down, side to side, that the grease works it way out little by little and can ultimately start to dry up if not replenished regularly.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Greasing Chassis [Re: Phishin] #4806472
07/06/18 05:55 AM
07/06/18 05:55 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
The word deflated may be the wrong word choice since you don't want to run it to the point of it needing grease, but yes you could overfill something and cause a boot to tear.
Does the manual say how often to grease everything? Is there a way for you to grease it by feel? Maybe 1 or 2 full pumps and call it good?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Greasing Chassis [Re: Phishin] #4806484
07/06/18 06:11 AM
07/06/18 06:11 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I watch for it to start to swell or feel it swell then stop. If a tiny bit oozes out between the bottom of the boot and where the boot sits no big deal. People have a tendency to pump like mad until it is forced out, and usually end up splitting the boot. I've seen some shops use air grease guns and fill it until it is forced out. One guy I knew didn't wipe the zerk fittings off before greasing the cars, forcing dirt into the joint, not good! I guess time is money and the faster the grease goes in the faster the vehicle is off the lift.
My van is the only vehicle I currently own with grease fittings. I grease it twice a year, not based on miles. I do it in the early spring, and the late fall before the first snow fall. That schedule has served me well. Many people grease their vehicles when they change the oil.
God Bless Our Troops
Re: Greasing Chassis [Re: Phishin] #4806485
07/06/18 06:11 AM
07/06/18 06:11 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I grease mine and customers till I see the boot move. Not squirt out. I guess the old grease comes out of the boot and that's why things are so greasy down there.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Greasing Chassis [Re: Phishin] #4806493
07/06/18 06:21 AM
07/06/18 06:21 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Fill them till they just swell a little thats it. Some of the new boots are using Euro style spring retainers to help prevent grease loss, the problem is this style of retainers was meant for LFL joints so yes they can burst easier than old school open end boots.
Try Schaeffers 238, it is a high 5% moly greaae and stays in the joint a long time. Invest in a good grease gun if you don't own one and do your own grease jobs.
https://www.amazon.com/Schaeffer-Manufac...=schaeffers+238
Re: Greasing Chassis [Re: Phishin] #4806497
07/06/18 06:29 AM
07/06/18 06:29 AM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
Pump a little grease onto a paper towel. Not much is expended with each pump. On open joints on my tractor, I pump grease until the old dirty grease is expelled. On "sealed" boot type joints, I carefully watch, feel that some grease is filling the boot.
Re: Greasing Chassis [Re: Phishin] #4806517
07/06/18 06:51 AM
07/06/18 06:51 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I grease once a year on my 2008 3/4 ton Chev. I find I never have to pump more than 3 times on the full size lever type gun. I look to see that the boot swells a bit and normally dont try to get grease to ooze out but dont worry if it does.
Ill edit this based on Mastersolenoids comments. This is a rubber boot that will let grease escape, but the boot normally gets quite plump before it starts to escape.
If you want the job done right......do it yourself.
Re: Greasing Chassis [Re: Snagglefoot] #4806530
07/06/18 07:06 AM
07/06/18 07:06 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
I think this explains some of the confusion.
Some joints have either:
1) Plastic Cover
2) Rubber Boot that allowed grease to come out / new grease would push out water
3) Sealed Rubber Boot that would require occasional greasing / that you could rupture
4) Sealed Rubber Boot with NO Zerk Fitting
Correct me if I'm wrong, but greasing would depend on the type of Boot Cover.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Greasing Chassis [Re: Phishin] #4806642
07/06/18 08:52 AM
07/06/18 08:52 AM
Canada
nobb Offline
nobb  Offline
Canada
All the greaseable joints I've seen had boots that have a grease relief. I always just pump slowly until the grease oozes out. Why would they design greaseable boots with no relief?
Re: Greasing Chassis [Re: Phishin] #4806669
07/06/18 09:28 AM
07/06/18 09:28 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I do not like the suspension parts that are not greasable . But if that is the way they come from the factory , not much you can do .
I certainly am not going to swap them out for parts that have grease zerts . Wait until they wear out , then replace them .
Wyr
God bless
Re: Greasing Chassis [Re: WyrTwister] #4806671
07/06/18 09:31 AM
07/06/18 09:31 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Originally Posted By: WyrTwister
I do not like the suspension parts that are not greasable . But if that is the way they come from the factory , not much you can do.
Interesting, I don't like the ones that are. The greaseable ones I've bought in the past have worn out much faster than the non-greaseable ones (especially Moog). Maybe they have improved since I last tried them but I find them inferior.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Greasing Chassis [Re: Phishin] #4806674
07/06/18 09:33 AM
07/06/18 09:33 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Did you grease them ?
Wyr
God bless
Re: Greasing Chassis [Re: WyrTwister] #4806679
07/06/18 09:37 AM
07/06/18 09:37 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Oh yeah, absolutely. I do all my own maintenance and have a couple of grease guns.
I remember thinking at the time it sounded like a good idea to be able to grease them but for whatever reason it just didn't work out for my cars. It was only on my Asian vehicles, the BMW doesn't have any greaseable parts even in the aftermarket.
1994 BMW 530i, 241K
Re: Greasing Chassis [Re: kschachn] #4806887
07/06/18 02:06 PM
07/06/18 02:06 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Because they are not as durable as sealed, that's why they are not used anymore. Moog sucks.
I was looking at cars on kijiji last night and one had a pic of the front clip off and a bunch of moog boxes. I actually cringed.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Moderated by  ekpolk
