I was firmly in the “no mixing” crowd until I started using this forum. The more I read, the more I realized most modern oils you buy are mixed anyway, especially synthetic blend. I tried It with the mother-in-law’s beater with a leaky valve cover. I used whatever loose quarts I had until I replaced the gasket. No problems.
Then I tried it in the family van. I had lots of AAP and AZ clearance oil. I put in 4 quarts of 0W-20, a quart of 20W-50, and a quart of 5W-30, all synthetic. I did the math, and it was right in the 5W-30 range. It’s at 3K and hasn’t lost a bit. Mileage is great, and it runs quiet.
