0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (Bjornviken, BrianF, burla, alphadog, bfleeman, BlakeB, 3 invisible), 684 guests, and 58 spiders.
Topics298,255
Posts4,988,171
Members67,246
Most Online2,474
Feb 10th, 2019
marine application #4805680
07/05/18 09:26 AM
07/05/18 09:26 AM
Ma
Skedude Offline OP
Skedude  Offline OP
Ma
I've been using TW-C3 2-stroke oil in my jetskis. It seems like JASO FD would be the new alternative, is this correct? Does it matter if I go full synthetic or just the blend?
Re: marine application [Re: Skedude] #4805699
07/05/18 09:43 AM
07/05/18 09:43 AM
SE Michigan
MichiganMadMan Offline
SE Michigan
TCW-3 is really for outboards only, I'm not sure how it became the "universal" 2-stroke oil.
JASO FD is meant for higher RPM, hotter running stuff that changes throttle position and RPM frequently. (i.e.: Your jetski)
The synthetic blend versus full synthetic is up to you. Both will meet the standard. How much they "better" they are likely depends on the marketing department at the individual companies.
I run TCW-3 in my outboard and JASO FD Sea and Snow, Redmax, Stihl, Husqvarna, Echo (whatever is on sale) oil in everything else like my mower, leaf blower, weed whipper, chain saws, brush cutter. I just make sure it has the JASO FD seal on the bottle somewhere and I'm good to go.
2015 Chevrolet Impala
2008 Subaru Impreza STI
2004 Suzuki Hayabusa
1987 Honda VFR700F2
2011 Jonsered 2188 Chainsaw-The Judge.
Re: marine application [Re: Skedude] #4805702
07/05/18 09:46 AM
07/05/18 09:46 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
TCW3 is for marine applications, JASO FD is for motorcycles.
Marine engines run cooler, amongst other things I cannot recall so the oil specs are different
It does not really matter synth, dino or blend. Whatever is cheaper, your jet skis will live a long life on supertech TCW3
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: marine application [Re: Skedude] #4805723
07/05/18 10:26 AM
07/05/18 10:26 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
What does your ski require?
TCW-3 and FD are not the same specification.
beanoil: Tough under heat, real dirty afterwards.
Re: marine application [Re: Skedude] #4805778
07/05/18 11:16 AM
07/05/18 11:16 AM
MN
Tman220 Offline
Tman220  Offline
MN
TCW3 is supposed to run in all marine applications. Part of the TCW3 spec is NO ASH, and it also needs to have a degree of biodegradability, all in the name of pollution control. Also since Marine engines tend to be lower RPM lower performance, NO ASH oil is desired because the temps to keep combustion chambers and power valves free of soot are just not there.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: marine application [Re: Tman220] #4805815
07/05/18 11:45 AM
07/05/18 11:45 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
6000 [current Yamaha 90 4-stroke] is "lower RPM"? My Merc 2-strokes were 5200 (the Merc 50HP 4-stroke I once ran was 6200).
Which motors are you referring to as "lower RPM lower performance"? Maybe I just have run the exceptions?
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: marine application [Re: Johnny2Bad] #4805817
07/05/18 11:48 AM
07/05/18 11:48 AM
northern NY
Driz Offline
Driz  Offline
northern NY
I was thinking the same thing.......
Re: marine application [Re: Driz] #4805838
07/05/18 12:03 PM
07/05/18 12:03 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
vs a 12000rpm air cooled chainsaw a water cooled outboard is lower rpm and cooler.
Re: marine application [Re: Tman220] #4805860
07/05/18 12:26 PM
07/05/18 12:26 PM
NJ, USA
MotoTribologist Offline
NJ, USA
Just FYI, I don't believe there is any requirement for biodegradability of TC-W3 oils. Here are the manuals from the NMMA for all of the certification requirements:
TC-W3 Rating Manual
TC-W3 Product Approval System
TC-W3 Certification Test Manual
Re: marine application [Re: Johnny2Bad] #4805870
07/05/18 12:39 PM
07/05/18 12:39 PM
VW Fanboy Island
VW Fanboy Island
When your 4T motors rev higher than your 2T, that should be your first clue.
Re: marine application [Re: maxdustington] #4806007
07/05/18 02:52 PM
07/05/18 02:52 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
TCW3 also leaves an anti corrosion layer on the cylinder walls.
If you want the job done right......do it yourself.
Re: marine application [Re: MotoTribologist] #4806059
07/05/18 04:14 PM
07/05/18 04:14 PM
MN
Tman220 Offline
Tman220  Offline
MN
TC-W3 Rating Manual
Yes, you are correct, I thought I remember reading something about biodegradability long ago but after brushing up on those specs, that is not the case.
Re: marine application [Re: Johnny2Bad] #4806065
07/05/18 04:25 PM
07/05/18 04:25 PM
MN
Tman220 Offline
Tman220  Offline
MN
One type of engine where a Jaso FD spec is specified is a snowmobile engine. This type of engine I would consider a high performance, high RPM, high heat application compared to an outboard or a 2 stroke PWC. As a comparison it is typical for a 700 CC 2 cylinder, two stoke snowmobile engine to make about 140 hp. This horsepower is made around 7800 RPM. As a comparison, my 60 HP 3 cylinder yamaha outboard displaces 850 CC's. That 60 hp is made at 5000 RPM. These are wildly different numbers from engines with wildly different performance requirements. It shoudn't be surprising that they require different lube specifications.
Moderated by  ekpolk
