WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
101 registered members (14Accent, 92saturnsl2, 53' Stude, 240_Ed, 2010Civic, 8 invisible), 2,178 guests, and 50 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Using only OE parts #4805554
07/05/18 08:55 AM
07/05/18 08:55 AM
WNY
redhat Offline OP
redhat  Offline OP
WNY
A good friend and I were talking the other day and both came to a topic I though was significant.
OE/OEM parts on automobiles. What I am referring to is... when a part fails on a car, replacing that said part with only an OE/OEM part.
I would assume, while costs can be high, it would always keep your car driving and performing at its prime. I can only imagine that my troubles with my Honda Accord (that are now steering me into the direction of selling) have partially stemmed from replacing most if not all front end components with parts store aftermarket.
Thoughts?
17 Taurus Limited AWD - Dealer Fill of MCSB 5W-20 FL500S, 16k
14 Civic EX Coupe - NAPA Syn 0W-20 TG7317, 64k
09 Accord Sedan 5MT - Traveler 15W-40 XG7317, 151k
87 Regal Limited - 20W-50 VR1 WIX 51042
Re: Using only OE parts [Re: redhat] #4805577
07/05/18 09:10 AM
07/05/18 09:10 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
There are plenty of after market parts as good as OE.
Akebono brake pads for one.
Avoid the parts in the "budget" section on RockAuto.
2015 Ford F250 w/Powerstroke
Re: Using only OE parts [Re: redhat] #4805590
07/05/18 09:18 AM
07/05/18 09:18 AM
NH
supton Offline
supton  Offline
NH
If it's only a few bucks more, go OE. If aftermarket has a part that fixes a failing in the OE design, go aftermarket. If the part is prone to failure regardless of who makes it, I guess you can alternate and see which one costs less (cost per mile/month or similar metric).
I suppose on a beater that might not be around much longer there may be reason to go with whatever is cheaper.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 147k, ours
1999 Toyota Camry LE, 2.2L/4AT, 203k, his
Re: Using only OE parts [Re: redhat] #4805601
07/05/18 09:28 AM
07/05/18 09:28 AM
PA
d00df00d Online content
d00df00d  Online Content
PA
There's no question that the people who design cars don't get everything right. The question is, if someone DIDN'T design the car, how likely are they to do a better job? If they did, how could I as an amateur even tell? And if I didn't like the way the designers did something, such that I'd want to change it with aftermarket parts... why on earth would I have the car in the first place?
That's why I always go for cars that are fit-for-purpose (and budget) from the factory, and service them with almost nothing but OE parts, with VERY few exceptions. Had the best luck that way, by far.
BTW, there's an important difference between OE and OEM:
OE = Original Equipment = The exact part that came on your car, or an updated version from the car's manufacturer.
OEM = Original Equipment Manufacturer = The "same" part made on the same assembly line by the same company that makes the part for the car manufacturer. Could be identical, or could be slightly off.
Usually -- and with some notable exceptions -- OE has the best performance and quality control, followed by OEM, and then other aftermarket stuff. That's why pricing and warranty coverage -- again, with notable exceptions -- generally follow the same trend.
2008 BMW M3 Sedan 6MT
Re: Using only OE parts [Re: redhat] #4805603
07/05/18 09:29 AM
07/05/18 09:29 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I avoid aftermarket whenever I can. Too much junk that fails a month later. I always hear the "lifetime warranty" bull from Autozone, but I could care less. What good is a lifetime warranty if you have to replace the thing every 3 months? I made a mistake buying a Duralast alternator for the Jeep. After the third one failed in less than a month I was ready to throw it through their window and tell them to keep it. Replaced with a Mopar one and no issues in over 2 years.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Using only OE parts [Re: redhat] #4805604
07/05/18 09:29 AM
07/05/18 09:29 AM
NY
demarpaint Offline
demarpaint  Offline
NY
When it comes to parts like sensors, thermostats, radiator caps, water pumps, and a few others parts I will only buy OE.
God Bless Our Troops
Re: Using only OE parts [Re: redhat] #4805607
07/05/18 09:31 AM
07/05/18 09:31 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would say OEM are Usually higher quality.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Using only OE parts [Re: redhat] #4805644
07/05/18 10:04 AM
07/05/18 10:04 AM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
I use OEM for Sensors and parts that I feel might require it.
I know for some of the cars I have owned and some of the current stuff there are aftermarket parts that fix thing that were not caught
during the production run.
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Using only OE parts [Re: d00df00d] #4805649
07/05/18 10:06 AM
07/05/18 10:06 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Here's a few things you're missing. The people who design the cars design it to a certain budget with all sorts of compromises. The aftermarket sees the results of the failures and can design a better part. The manufacturer has certain constraints they still have to abide by. Case in point was sway bar links. Ford use to make them out of plastic. Meant they were weak and broke pretty reliability every 2 years or so. I got aftermarket metal ones. Didn't end up replacing them. They probably had to be plastic to keep the weight down. Same thing with their water pumps, at one point, they used plastic for the impellers. I'm sure that kept the weight down, but they tended to break and fall apart. Aftermarkets didn't care about weight restrictions or CAFE so they were metal ones. OEM all the time can be a flawed mentality. You can have the same problem with OEM tires, lousy grip or whatever issues due to CAFE. Aftermarket doesn't care about worse gas mileage.
But yeah, I'd agree with the OE push. It's funny with Mercedes, Wahler makes their thermostats and when you buy the part, the spot where you'd see the MB logo is burred out. Still an OE part, but cheaper because it's not OEM.
Re: Using only OE parts [Re: redhat] #4805660
07/05/18 10:17 AM
07/05/18 10:17 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
I only use OEM or aftermarket upgrade parts.
"Zed's dead baby, Zed's dead."
Re: Using only OE parts [Re: d00df00d] #4805661
07/05/18 10:17 AM
07/05/18 10:17 AM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
+10
Re: Using only OE parts [Re: redhat] #4805662
07/05/18 10:18 AM
07/05/18 10:18 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
My train of thought is that most of the time I can buy OE on the internet for less than any parts store sold brand.
I consider myself an avid DIYr and have yet to find anything as good as OE for my domestic vehicles. Her Volvo on the other hand is another story. Lots of good stuff out there for cheap.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Using only OE parts [Re: CT8] #4805665
07/05/18 10:19 AM
07/05/18 10:19 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Here is another dirty little secret OE suppliers and OEM do not mean that company actually produced that particular part for any company. They may for example made a window crank handle holding clip for GM years ago but have not a LCA for anyone, yet their advertising claims they are an OE supplier. Not 100% false but certainly deceptive.
Re: Using only OE parts [Re: d00df00d] #4805684
07/05/18 10:28 AM
07/05/18 10:28 AM
North Carolina
North Carolina
Cars are bundles of compromise.
No reason not to use the aftermarket to swing the compromise towards your preferences vs the preferences of the masses or government.
Re: Using only OE parts [Re: redhat] #4805697
07/05/18 10:42 AM
07/05/18 10:42 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I've seen someone mention on this board that if the labour costs more than the part, it's worth it to go OE.
I've also seen someone mention on this board that the aftermarket part can be a copy of a flawed first revision of an OE part that never gets updated, I believe the example was a fan clutch on a F150 or Chevy Trailblazer. When you buy an OE part from the dealership 9 times out of 10 you get the latest revision, at least you can tell by the part number.
I'm with roofless on trying to upgrade with aftermarket performance parts. Suspension is the one place where 90% of the time you can get better quality/performance. Struts, springs and mounts, sway bar end link bushings, control arm bushings, etc can be upgraded for the same price or cheaper as OE. There are exceptions, my car has OE Audi TT control arm bushings and I put OE rear axle bushings in my old Golf because the aftermarkets were not recommended.
I'd also say 10-15 years old and 200000+ kms depending on the car and condition is about where I start thinking about using aftermarket parts. I just changed a coolant elbow on my car that is known to break on the 1.8Ts. The consensus is that you replace it with a metal version, but it was $100+ CAD and I got a Gates from Rockauto for $40.
One thing that is nice about euro cars is that the OE parts are easy to get reboxed. Any of those German parts companies (Lemforder, Sachs, etc) usually produce good stuff. Beck/Arnley seems to have improved the quality of their parts, too. They might have gone back to reboxing OE parts like they did in the past.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Page 1 of 3 1 2 3
