No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
122 registered members (10WSmuckers, 928, Alisobob, AandPDan, AdditiveOCD, 11 invisible), 1,746 guests, and 55 spiders.
Topics284,678
Posts4,874,959
Members67,313
Most Online2,548
Feb 16th, 2019
A-1 Cardone or ACDelco? #4805547
07/05/18 07:49 AM
07/05/18 07:49 AM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
Have a 95 Ford F350 and the driver side front window motor is no good. Would go Motorcraft but its a little pricey and need to get the truck going. What is preferred for window motors? Rebuilt A-1 Cardone or brand new ACDelco? Price is similar.
Think twice, speak once.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805549
07/05/18 07:52 AM
07/05/18 07:52 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I would just buy the cheapest no-name one off eBay. Done it twice so far, and so far so good.
Having said that, if you are handy sometimes you can do things to the motor like replace the brushes, etc.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805580
07/05/18 08:13 AM
07/05/18 08:13 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Please spend the extra and buy Motorcraft, look for NOS or new on ebay too, sometimes you luck out and get a super deal.
Never buy Cardone anything, I have gone through more junk than I care to think about from them over the years.
Its the labor to keep changing bad parts that breaks the camels back.
4 defective wiper motors in a row all failed within days, new Motorcraft worked perfectly the first time and is still working in that car. Delco is hit and miss, they were good at one time but today its a real carp shoot, not as bad as Cardone or Atsco and others but not good either.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805584
07/05/18 08:14 AM
07/05/18 08:14 AM
Jupiter, FL
thescreensavers Offline
Jupiter, FL
ACdelco is an OEM for GM. So that should be better than A1.
I usually check to see if the pictures for the item are the same. If they are then they are likely the same part.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: A-1 Cardone or ACDelco? [Re: thescreensavers] #4805624
07/05/18 08:41 AM
07/05/18 08:41 AM
Trav Offline
Trav  Offline
There are many different parts to ACDelco, OE and aftermarket, they are not the same in quality. You cannot go by looks, its absolutely meaningless, Walbro fuel pumps is a good example.
http://walbrofuelpumps.com/best-tips-for-spotting-fake-walbro-255
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805634
07/05/18 08:52 AM
07/05/18 08:52 AM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
There is a Ford Motorcraft motor that I found earlier on Rockauto for only $18 more than the ACDelco - the only rub is there isn't any pictures (description matches though) but its sold without a core charge and it's labeled High Level Service Design; Kit.
A quick internet search found a recent post on another forum that means its a lower tier Motorcraft part designed for older vehicles that don't need to last as long and therefore isn't OEM quality.
I think I will go with that as its $55 shipped and a rebuilt Motorcraft part is close to $100 shipped and should be better than the normal aftermarket stuff.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805650
07/05/18 09:08 AM
07/05/18 09:08 AM
Trav Offline
Trav  Offline
Service grade new is decent, they still have to meet all Motorcraft test and QC and be suitable for dealer service use on older vehicles.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805676
07/05/18 09:24 AM
07/05/18 09:24 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Dont buy cheap and have it die in the lowered position just before a good rain.
Id go to a junkyard before A1 Cardone personally.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805692
07/05/18 09:32 AM
07/05/18 09:32 AM
USA
slacktide_bitog Offline
USA
Get the Motorcraft motor
Re: A-1 Cardone or ACDelco? [Re: Trav] #4805742
07/05/18 10:50 AM
07/05/18 10:50 AM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
Thanks for the explanation. The original lasted 23 years and 335k miles, so I want something that will last but doesn't have to be another 335k miles.
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805791
07/05/18 11:26 AM
07/05/18 11:26 AM
CA
The Critic Online crying
The Critic  Online Crying
CA
Avoid Cardont/A1 Car-be-done.
ACDelco is likely to be a reboxed part. If at all possible, buy the Motorcraft.
2011 Toyota Prius - 184k - M1 EP 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805923
07/05/18 01:25 PM
07/05/18 01:25 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
I'll say it this way, I'd have a hard time trusting a parts company that was named "A1 Car done". It just seems like the cheapest, most panderous jobber [censored] brand available.
There's no replacement...'scosity for natural viscosity
Re: A-1 Cardone or ACDelco? [Re: PeterPolyol] #4805938
07/05/18 01:34 PM
07/05/18 01:34 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
That and Dorman, what a stupid name. Both of them suck!
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: A-1 Cardone or ACDelco? [Re: SVTCobra] #4805981
07/05/18 02:07 PM
07/05/18 02:07 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
If you buy AC Delco...if it is an "Advantage" part...it is China made likely...and quality is....well...... As much work as a window motor does and the PITA it is to change (or have it fail) I would go OE.
HDEO in Diesel Engines. No spark plugs here.
Re: A-1 Cardone or ACDelco? [Re: PiperOne] #4805984
07/05/18 02:13 PM
07/05/18 02:13 PM
TX
s2krunner Offline
s2krunner  Offline
TX
Some Motorcraft parts made in China.
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Moderated by  ekpolk
