0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
36 registered members (alphadog, bfleeman, BlakeB, BrianF, Blkstanger, anndel, 2 invisible), 733 guests, and 56 spiders.
Topics298,255
Posts4,988,168
Members67,246
Most Online2,474
Feb 10th, 2019
Baseplate holes vs baseplate holes #4805375
07/04/18 10:14 PM
07/04/18 10:14 PM
Dallas,Tx USA
aquariuscsm Offline OP
Dallas,Tx USA
Take two different filters,both for the same application. Would the filter with larger and more baseplate holes be better than the one with fewer,smaller baseplate holes?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 10W30
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805388
07/04/18 10:42 PM
07/04/18 10:42 PM
USA
slacktide_bitog Offline
USA
You know, I've been waiting for someone on here to post a question about baseplate holes, and how each mfr decides on the hole configuration of their baseplates. crzy
For example, the Zetec filter
Fram's 8316 has 6 small holes
Champ uses 8 holes, but one is twice the size of the other holes, EXCEPT on the M1-211
The now-discontinued M1-211 used six small holes
Purolator uses elongated oval holes on both the 25230 and 20195
Wix uses six large holes on the 51315
Hastings/Baldwin uses 7 small holes on the B1416/LF483
the Fram 7317 uses a bunch of very large holes (this is a relatively small filter used mainly on Honda and Nissan engines)
The Purolator 14610 uses 8 small holes
Champ uses 6 small holes
Wix uses 8 small holes on the 57356
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805405
07/04/18 11:53 PM
07/04/18 11:53 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The more flow area the better to minimize the pressure drop through the base plate.
But the difference between base plates is probably less than 1 psi. So as long as there are enough holes and area to minimize delta-p in the first place, adding more flow area isn't really going to result in much gain.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805449
07/05/18 05:38 AM
07/05/18 05:38 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Topic has been discussed before, imo and in my observation mostly as a halo effect observation. By that I mean one appears to favor/like a particular brand first and then notes more and/or larger inlet holes for that brand of choice. Or conversely dislikes another brand and notes smaller and/or less inlet holes.
My thought after reading this board for many years, as long as the total area of the inlet holes is at least equal to the area of the inner diameter of the filter mounting stud then plenty of flow, ie, flow not an issue. I trust the manufacturers have taken that into considering when designing the filter and get it right.
Best example in personal use, Wix/NG for most Hondas used to be the 5/1356 (still made), has very large holes. Then Wix went to a new baseplate design for several applications including Honda, now it's the 5/7356. The latter application has smaller holes but I'm confident it meets the criteria noted above. So selecting a filter by inlet hole shape, size or number a pointless exercise imo. My .02
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805496
07/05/18 06:49 AM
07/05/18 06:49 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
We discussed this a bit back in 2016:
Originally Posted By: 2015_PSD
I was curious about this situation too with regards to the holes in a MC FL-820s versus a FRAM Ultra XG2 (Ford Modular Engines). Although the FRAM inlet holes were smaller (but more of them), they still flowed more than the outlet. You should perform a calculation to see if the same applies to the XG5:
Baseplate Flow Calculation:
FL-820s Baseplate:
FRAM Ultra XG2 Baseplate:
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo
2018 Mercedes Benz C300 2.0L Turbo
2015 Ford F-250 Platinum 4WD 6.7L PSD
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805499
07/05/18 06:52 AM
07/05/18 06:52 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
As long as the baseplate holes have a larger area than the hole in the pipe it won't matter how big they are
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805544
07/05/18 07:48 AM
07/05/18 07:48 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
If the oil pump is mechanical single speed the flow is essentially the same. Picture a 1 inch pipe going to a 3 inch, then back to a 1/4 inch. Pressures rise and fall at each pipe size, but flow is the same. No one has yet explained why some Fram larger filters have 8 smaller holes while the smaller filters have 10 larger holes. May be just due to manufacturing ease or something.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4805905
07/05/18 01:12 PM
07/05/18 01:12 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The same total hole flow area on a small filter base is going to make it look more "swiss cheesed" than on a large filter base.
A designer would want enough total hole flow area to ensure minimal delta-p across the base plate, while also leaving enough material to ensure structural strength without "swiss cheesing" the base plate too much.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4806062
07/05/18 04:22 PM
07/05/18 04:22 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
More holes, and bigger, on the xg4967 vs xg3614
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4806100
07/05/18 05:20 PM
07/05/18 05:20 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The delta-p difference through those two base plates under the same flow conditions would be pretty small and insignificant.
Are those two base plates the same thickness? If the larger base plate is thinner material, they wouldn't want to swiss cheese it as much as the smaller filter.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4806359
07/05/18 09:53 PM
07/05/18 09:53 PM
Dallas,Tx USA
Dallas,Tx USA
For example,the Mobil 1 filter for my Accord has 6 tiny baseplate holes while the Fram TG has 10 huge baseplate holes.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4806429
07/06/18 04:06 AM
07/06/18 04:06 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
The German Mann filters only have 4 medium sized holes.
https://shop.advanceautoparts.com/p/mann-hummel-oil-filter-w-930-21/99998142-P
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4810286
07/10/18 12:12 PM
07/10/18 12:12 PM
California
DGXR Offline
DGXR  Offline
California
I am pretty sure the number and size of holes in the baseplate does not matter. This is not the restricting element in the oiling system. Yes the holes do impede flow a small amount, but the filter media and the oil flow through the journals will provide much more resistance. Consider that a bypass valve (if equipped) allows the canister to pressurize before it opens, and this pressure will be far greater than any restriction caused by the baseplate holes. Also, consider typical pressures of an automotive oil pump, and these baseplate holes quickly become negligible. As to the rhyme and reason for filter manufacturers using one hole pattern over another, larger holes or smaller holes... I have no idea. As long as the baseplate is not weakened by too many holes or thin metal (the gasket needs to be held firmly to the block).
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 2wd access cab
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Baseplate holes vs baseplate holes [Re: DGXR] #4810457
07/10/18 02:54 PM
07/10/18 02:54 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The oil pressure inside the can and the pressure drop across holes or media are two different things. The pressure drop is dependent on the oil flow through a restriction. The bypass valve operated on delta-p. The pressure seen inside the can is dependent on the system restriction down stream of the filter's inlet (ie, the engine and also the filter itself) and the max pressure relief valve setting on the oil pump.
Re: Baseplate holes vs baseplate holes [Re: aquariuscsm] #4812427
07/12/18 03:14 PM
07/12/18 03:14 PM
AZ
larrymoencurly Offline
AZ
A long time ago, the Fram PH3600 and PH2870A had the same base plate but different relief pressures, and at least one other filter maker, AC Delco, used the PF-56 for both. Then Fram changed the PH2870A, both the shape of the base plate (to be like the ones goodtimes posted) and the number and size of holes. Why would they make those changes if they didn't think it mattered, especially because they didn't advertise it?
Moderated by  ekpolk
