WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
106 registered members (2015_PSD, 2K2AcuraTL, 95oRANGEcRUSH, 14Accent, 92saturnsl2, 53' Stude, 11 invisible), 2,050 guests, and 53 spiders.
Topics286,244
Posts4,905,163
Members67,587
Most Online2,967
Mar 10th, 2019
Rattling Brakes when going over bumps #4805317
07/04/18 08:38 PM
07/04/18 08:38 PM
Ontario, CA
Quakish Offline OP
Quakish  Offline OP
Ontario, CA
2004 Honda CRV. Changed front rotors and pads about 2 months ago. rotors are raybestos and pads are akebono. no shims on the new pads. also installed new aftermarket brake pad clips. lubed the slider pins and greased the clips. everything went back together fine. noticed that when i go over bumps or expansion joints i hear a rattle coming from the front brakes, like something is loose. the rattle goes away when the brakes are engaged. any ideas? could the pads be slightly out of spec? could it be the lack of shims on the new pads? or the aftermarket pad clips? my simple mind is stumped.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805321
07/04/18 08:52 PM
07/04/18 08:52 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Did you get all of the caliper and bracket bolts tight? I did the brakes on my 04 civic recently and took a short drive with loose bolts on the caliper or bracket and it made an awful racket. Also check the lug nuts.
Previous pads were Wagner thermoquiets with no (integrated) shims and they had no unusual rattles.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805327
07/04/18 09:04 PM
07/04/18 09:04 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
The springs/clips that hold the pads could have moved or simply broken. Stuff happens. Take em apart and look.
Re: Rattling Brakes when going over bumps [Re: WobblyElvis] #4805334
07/04/18 09:24 PM
07/04/18 09:24 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Miles on that CR-V? The bracket which holds the pads' ears can wear.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805335
07/04/18 09:24 PM
07/04/18 09:24 PM
Canada sometimes
Ded Mazai Offline
Ded Mazai  Offline
Canada sometimes
That is what the anti-vibration shims are for. I doubt you can fix the noise without the shims. You might want to apply some aftermarket noise suppressing paste on the back side of the pads. Canadian Tire should have it.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805341
07/04/18 09:44 PM
07/04/18 09:44 PM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
I would think Akebono Pads would fit like OEM's but it sounds like there loose to me.
Re: Rattling Brakes when going over bumps [Re: Warstud] #4805394
07/05/18 12:09 AM
07/05/18 12:09 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Same. I thought they fit every application perfectly and released a lemon scent when you applied the brakes.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805419
07/05/18 02:55 AM
07/05/18 02:55 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Pads are a funny beast today. They used to fit in the clips but lately seem mostly too tight in my experience. Grinding them a tad is sometimes needed or they bind . You never know what youíre getting these days it seems so grab them wiggle and see. If theyíre too loose take them back.
One other thought is the caliper assembly itself. Is it meaning the puck sticking ? Youíll likely never be able to answer that question either . An 04 is long in the tooth in the rust belt and those puppies swim in that [censored] constantly. The front caliper on my 2000 GMC rotted right through in 2013! Figure that one out, I canít.. If the clips donít seem visually loose you might try just replacing them with refurb calipers and be done with it.
I started doing that a while back whenever I started having post 100k mile brake issues, normally faster than expected wear on pads and itís always served me well. A rebuild kit costs nearly as much as the whole assembly so donít bother honing just replace and be happy. Probably $120 for both sides max more like 75 IIRC. Donít chuck your cores as they want em back for rebuilding. Since theyíre off itís an opportunity to swap out the brake fluid as well which is a good idea at that age.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805425
07/05/18 04:21 AM
07/05/18 04:21 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Check your brake hardware.
The "thinking" man's friend.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805442
07/05/18 06:12 AM
07/05/18 06:12 AM
The Motor City
Kestas Online content
Global Moderator
Kestas  Online Content
Global Moderator
The Motor City
I had a 90 LeBaron that did that. The ears of the pad backing wore divots in the caliper that was not taken up by the anti rattle clips. The only fix - which I never did - was to weld metal to build up the surface again.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805508
07/05/18 08:04 AM
07/05/18 08:04 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Put some of this sauce on the back of the pads, let dry 20 min and reinstall. This will stop the rattle.
https://shop.advanceautoparts.com/p/crc-...mp;gclsrc=aw.ds
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805707
07/05/18 10:53 AM
07/05/18 10:53 AM
The Motor City
Global Moderator
Global Moderator
The Motor City
It won't work if the pad is loose in the caliper. It didn't work on my 90 LeBaron.
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805853
07/05/18 01:20 PM
07/05/18 01:20 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Unless something is actually broken, it might not be anything to worry about.
It's the callipers rattling on the brackets. They don't grip the rotors tightly (otherwise your brakes would be on all the time) and are supposed to slide freely so there is always some play. Most installations use some kind of anti-rattle mechanism but if they are missing (even inadvertently) the brakes will work exactly the same; it's not really a fault condition, it's just an annoyance condition.
You can go in and fix it, or not, as you see fit. Some brake setups don't have an OEM anti-rattle mechanism, but replacement pads usually come with something you can use on replacement.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Rattling Brakes when going over bumps [Re: Quakish] #4805857
07/05/18 01:22 PM
07/05/18 01:22 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
How do you know that it's the brake pads?
Re: Rattling Brakes when going over bumps [Re: Kestas] #4805966
07/05/18 02:56 PM
07/05/18 02:56 PM
Trav Offline
Trav  Offline
If the pads are very loose that it wont there is something really wrong with the fitment of the pads and probably should be replaced. It will prevent slight movement but its not going to stop a marble in a can.
