Originally Posted By: dbeau
Anyone know the bypass valve releif pressure of this filter?
Trying to compare to a Purolator boss PBL14612 or Fram Ultra XG7317
Thanks
From my research the XG7317 has the same bypass setting as the M/C filter version from Fram that crosses to the Yamaha filter. Go to Fram's wesite and do some cross checking and you'll see.
The 7317 is about 3/4 inch longer, but they also have a short version which is the same size as the Yamaha filter. Make sure you have room for a longer filter.
