Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
64 registered members (4WD, A1O, 2009Edge, aloe2018, AdditiveOCD, ARB1977, 8 invisible), 1,459 guests, and 57 spiders.
Topics286,321
Posts4,906,384
Members67,599
Most Online2,967
Mar 10th, 2019
Pressure washer engine backfiring #4805025
07/04/18 01:27 PM
07/04/18 01:27 PM
Athens, GA GO DAWGS
dawgn86 Offline OP
dawgn86  Offline OP
Athens, GA GO DAWGS
Hi All
I bought a new pressure last year from Northern Tool...3000psi with a Honda engine GX160 or 190 engine.
It cranks and runs well, but when I let off the pressure trigger, it backfires many times. I use a quality fuel ( the non ethanol )...
Any ideas of how to cure this?
Thanks
2006 Nissan Pathfinder Mobil 1 Synthetic 5w-30
2008 Nissan Frontier Mobil 1 Synthetic 5w-30
2012 Jeep Cherokee Laredo Penzoil 5w-20 Synthetic
2013 Toyota Tacoma PreRunner 0w-20 Valvoline Synthetic
Re: Pressure washer engine backfiring [Re: dawgn86] #4805029
07/04/18 01:32 PM
07/04/18 01:32 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Check the spark plug, but odds are it probably is in need of a carburetor adjustment. I've had it happen over the years and a carburetor adjustment did the trick. Sometimes the vibration knocks them out of adjustment.
God Bless Our Troops
Re: Pressure washer engine backfiring [Re: dawgn86] #4805031
07/04/18 01:35 PM
07/04/18 01:35 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
does it sound like its under a high load when its doing this?
might be the unloader.
If its not working right its trying to compress water that isnt flowing.
Some of these pumps have a very tiny hole and they get clogged with debris from your hose or water.
(I always flush my hose for a min before hooking up)
If it sounds like it is under no load when its backfiring.. its probably some kind of carb issue.
Re: Pressure washer engine backfiring [Re: dawgn86] #4805091
07/04/18 02:31 PM
07/04/18 02:31 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Check for clean cooling fins, mouse nest.
2015 Ford F250 w/Powerstroke
Re: Pressure washer engine backfiring [Re: dawgn86] #4805124
07/04/18 03:12 PM
07/04/18 03:12 PM
Athens, GA GO DAWGS
dawgn86 Offline OP
dawgn86  Offline OP
Athens, GA GO DAWGS
I got it last summer and used it some...used it a few weeks ago and noticed the backfire...does when when you let off the pressure...hate to think the unloader or carb is out of whack with it being less than a year old. I have a new plug to try and see if that helps.
Re: Pressure washer engine backfiring [Re: Donald] #4805140
07/04/18 03:28 PM
07/04/18 03:28 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
'Twas just going to say that. A mouse nest made my friend's B&S 22HP (lawn tractor) backfire
Re: Pressure washer engine backfiring [Re: dawgn86] #4806251
07/05/18 09:02 PM
07/05/18 09:02 PM
Athens, GA GO DAWGS
dawgn86 Offline OP
dawgn86  Offline OP
Athens, GA GO DAWGS
So, I fired up the pressure today and used it about a half hour..no backfire at all....maybe the new plug did the trick. I also put in some Start Tron as well.
Re: Pressure washer engine backfiring [Re: dawgn86] #4806678
07/06/18 10:36 AM
07/06/18 10:36 AM
Southeast
meep Offline
meep  Offline
Southeast
running lean will backfire. overheated valves will promote backfire (too tight). sometimes I've seen very efficient engines, when under zero load, spit and pop, as they spin free. you can also try a different fuel. if it's not burning completely, it will ignite when it passes through the muffler
2018 F150
2015 crv (wifey!)
Re: Pressure washer engine backfiring [Re: meep] #4806733
07/06/18 11:45 AM
07/06/18 11:45 AM
Athens, GA GO DAWGS
dawgn86 Offline OP
dawgn86  Offline OP
Athens, GA GO DAWGS
Thanks...that will be the next thing I try if it returns
