Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
118 registered members (Al, 10WSmuckers, 928, Alisobob, AandPDan, 11 invisible), 1,747 guests, and 55 spiders.
Topics284,678
Posts4,874,959
Members67,313
Most Online2,548
Feb 16th, 2019
Coolant Question No Radiator Cap #4804939
07/04/18 10:22 AM
07/04/18 10:22 AM
Columbus, Ohio
John_K Offline OP
John_K  Offline OP
Columbus, Ohio
My wife's Grand Marquis is the first car I have ever worked on with no radiator cap. The overflow tank is pressurized. Does this mean the coolant level in the tank is the same as in the radiator, or does it blow back and forth with pressure? I am used to just popping the cap and looking at the radiator level.
2009 Mercury Grand Marquis, 8 cyl auto, 83xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 96xxx miles, Maxlife/OEM Filter
Current oil stash: 518 qts.
Re: Coolant Question No Radiator Cap [Re: John_K] #4804949
07/04/18 10:30 AM
07/04/18 10:30 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Radiator cap is on the coolant bottle. The radiator is completely full on these systems and the level is checked in the bottle.
"Zed's dead baby, Zed's dead."
Re: Coolant Question No Radiator Cap [Re: John_K] #4805018
07/04/18 12:22 PM
07/04/18 12:22 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Correct as above plus the fluid goes back and forth with thermal expansion. If you are changing the fluid, check for a drain valve but many cars do not have those either, and you have to pull a hose off at the bottom of the rad. You add the fluid at the expansion tank or if you prefer you can pull off the small hose to the rad and use a funnel. Your choice.
If you want the job done right......do it yourself.
Re: Coolant Question No Radiator Cap [Re: John_K] #4807341
07/07/18 04:25 AM
07/07/18 04:25 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I just replaced coolant in my GM. I pulled the lower hose at the radiator to drain. I have heard bad stories about some of the plastic petcocks either breaking or seeping.Fill the bottle to the marks and watch it for a couple days as you will need to top off until all the air is out. It should be filled with G05 coolant.
The "thinking" man's friend.
Moderated by  ekpolk
