Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
55 registered members (AndyB, 2015_PSD, 69Torino, alarmguy, Astro_Guy, 97K15004WD, 4 invisible), 651 guests, and 56 spiders.
Topics284,588
Posts4,872,980
Members67,294
Most Online2,548
Feb 16th, 2019
Page 1 of 3 1 2 3
2016 Mustang Differential OIl Change #4804933
07/04/18 10:14 AM
07/04/18 10:14 AM
Louisiana
ant Offline OP
ant  Offline OP
Louisiana
Time for an rear gear oil change, and the manual recommendation is Motorcraft 75w85. Would Redline in the same viscosity be a better oil to use? Could 75w90 be used, and would there be any advantage to going to the higher viscosity?
Re: 2016 Mustang Differential OIl Change [Re: ant] #4804948
07/04/18 10:29 AM
07/04/18 10:29 AM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
I’m a believer in 75W140 for all rear axles.
According to MacT garage on YouTube RedLine and Valvoline synpower both have much more additives than Motorcraft gear lines. I wouldn’t say that’s a guarantee they’ll perform better but something is take into consideration.
I personally use BG gear lubes. Mostly due to the fact that the distributor will give use products for use on our personal vehicles.
Re: 2016 Mustang Differential OIl Change [Re: ant] #4804961
07/04/18 10:44 AM
07/04/18 10:44 AM
US
JLTD Offline
JLTD  Offline
US
Redline 75w90 would be an excellent choice IMO.
I don't know about whether a 75w140 would be of benefit or not.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL™
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: 2016 Mustang Differential OIl Change [Re: ant] #4804963
07/04/18 10:50 AM
07/04/18 10:50 AM
Planet Earth
2015_PSD Online content
2015_PSD  Online Content
Planet Earth
I would seriously look into Amsoil 75W-110 as a replacement for xW-85/90. 75W-110 is the viscosity of the upper range of 75W-90 was before the J306 tables were updated in 2006 (as shown below). Otherwise, I would use Amsoil 75W-140--particularly if you are tracking the car or running it very hard.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo
2018 Mercedes Benz C300 2.0L Turbo
2015 Ford F-250 Platinum 4WD 6.7L PSD
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805024
07/04/18 12:24 PM
07/04/18 12:24 PM
Louisiana
ant Offline OP
ant  Offline OP
Louisiana
Usage is primarily driving to and from work, and once or twice a year at a local dragstrip. Would a 75w90 have advantage over Redline 75w85 in terms of wear?
If I change to 75w90, I would choose from the following:
Redline
Mobilube SHC (if I can find it in the USA)
Amsoil
Motul Gear 300 LS
Which of these would be the best choice?
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805187
07/04/18 03:19 PM
07/04/18 03:19 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Redline
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805224
07/04/18 04:27 PM
07/04/18 04:27 PM
Planet Earth
Planet Earth
Amsoil - PM Pablo, he can hook you up with a good deal on it.
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805247
07/04/18 05:24 PM
07/04/18 05:24 PM
Georgia, USA
XL1200RFan Offline
XL1200RFan  Offline
Georgia, USA
As it happens today I'm changing the differential lube in my 2016 F-150XL 3.5L, which has the 8.8" rear end. Typically I like to dump the factory fill by 10K, refill with a quality synthetic and then leave it alone to 100K or so. This process has served me well over the last 30+ years...never a diff or wheel bearing/axle issue.
Tomorrow after the RTV cures I'll be refilling with 2 quarts of Amsoil Severe Gear 75W-110.
John
2016 F-150 3.5 CE EP 5W-20 MC FL-500S
2014 Volvo XC60 3.2 PP 5W-30 Mann HU9254Y
2003 Chevy Express 2500HD 6.0 M1 EP 5W-30 Ultra XG3506
Re: 2016 Mustang Differential OIl Change [Re: XL1200RFan] #4805336
07/04/18 08:26 PM
07/04/18 08:26 PM
Planet Earth
Planet Earth
This is more or less the same process I use, but I will lower the OCI if I am towing frequently. I have Amsoil 75W-110 in the front axle and 75W-140 in the rear axle.
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805443
07/05/18 05:16 AM
07/05/18 05:16 AM
Louisiana
ant Offline OP
ant  Offline OP
Louisiana
Any suggestion on where to purchase Mobilube SHC 75w90? I have not been able to find it on the web in the USA in the container size I need?
Re: 2016 Mustang Differential OIl Change [Re: ant] #4805468
07/05/18 06:01 AM
07/05/18 06:01 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Same as Mobil Delvac 1? I get it in gallons from Grainger.
"Zed's dead baby, Zed's dead."
Re: 2016 Mustang Differential OIl Change [Re: rooflessVW] #4805812
07/05/18 11:42 AM
07/05/18 11:42 AM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
I think the old SHC that Prorsche liked became Delvac 1. Don't quote me on that, do your own due diligence, the SHC label has been tossed back and forth by Mobil for ages, especially in grease universe. I would call them. The Delvac 1 served me well.
Re: 2016 Mustang Differential OIl Change [Re: ant] #4806072
07/05/18 04:40 PM
07/05/18 04:40 PM
Louisiana
ant Offline OP
ant  Offline OP
Louisiana
What about Valvoline Synpower 75w90? How does it compare to Mobil, Redline and Amsoil?
Re: 2016 Mustang Differential OIl Change [Re: ant] #4806125
07/05/18 05:59 PM
07/05/18 05:59 PM
Planet Earth
Planet Earth
Though I initially suggested Amsoil, based upon your intended usage:
In all seriousness, any oil you choose would be fine. In fact, I would look at the cheapest oil that meets specification and just change it more often than looking at a uber premium (more expensive) oil which has its strength in extended OCIs.
Re: 2016 Mustang Differential OIl Change [Re: 2015_PSD] #4806190
07/05/18 06:57 PM
07/05/18 06:57 PM
Louisiana
ant Offline OP
ant  Offline OP
Louisiana
You're right probably don't need the most expensive oil, just need one fit for purpose. Do you see any issue with the 75w90 given that it's 50% higher viscosity?
Page 1 of 3 1 2 3
Moderated by  ekpolk
