Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
69 registered members (alarmguy, 4WD, AdditiveOCD, aircooled, A1O, 2009Edge, 10 invisible), 1,468 guests, and 63 spiders.
Topics286,322
Posts4,906,388
Members67,599
Most Online2,967
Mar 10th, 2019
2013 F150 5.0 oil and IOLM #4804874
07/04/18 10:11 AM
07/04/18 10:11 AM
Central NY
rsylvstr Offline OP
rsylvstr  Offline OP
Central NY
I have Chevron Supreme 5W-20 SN oil sitting around.
My understanding of the Ford IOLM on this truck is designed to know/monitor a semi-synthetic like MC blend and similar or better.
Would you just run this oil and set the IOLM to 100% or knock it down to start at 80% or another?
Hope this makes sense. She has 45k on the clock and is new to me.
Once she hits 60k I will just run the Miles synthetic blend 5W-30.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804878
07/04/18 10:13 AM
07/04/18 10:13 AM
San Rafael, CA
dogememe Online content
dogememe  Online Content
San Rafael, CA
chevron supreme 5w-20 is a quality synthetic blend, i'm sure it's on par or better than motorcraft oil.
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=205060&docFormat=PDF
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804888
07/04/18 10:18 AM
07/04/18 10:18 AM
Central NY
rsylvstr Offline OP
rsylvstr  Offline OP
Central NY
Thanks for that! No idea why they donít say it is a blend on the bottle.
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804901
07/04/18 10:36 AM
07/04/18 10:36 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
I would highly doubt that--it is more likely that it is designed to perform a weighted average of time, operating temperatures, static temperatures, operating speeds, and the like.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: 2013 F150 5.0 oil and IOLM [Re: 2015_PSD] #4804908
07/04/18 10:43 AM
07/04/18 10:43 AM
US
JLTD Online shocked
JLTD  Online Shocked
US
From everything I've seen, there IS some variability due to usage, but not much. On the 2013s it's calibrated to go 6 months or 10k miles....mine usually got to 10% at around 9100 miles. Always had plenty of miles left in the oil.
I'd think that Ford would have set it for dino to be the most conservative possible.
rsylvstr, I'd set it at 100% and take a sample around 7500 to make sure you're good for the interval.
I use the overseas owner's manual to choose my oil.
Using AMSOIL‚ĄĘ
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804912
07/04/18 10:48 AM
07/04/18 10:48 AM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
My understanding is that it has no actual sensor in the oil and has no idea what you put in but is a software algorithm designed around a grade and API spec.
It gets its input from engine speed load and temp sensors over time and calculates oil life from that.
Change the oil or API spec and it won't give you what you need.
In a mill with tons of chains and sprockets shearing oil I wouldn't skimp on oil filters or magnets if it were my truck and don't on my own.
Your truck your call.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804924
07/04/18 11:04 AM
07/04/18 11:04 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
As long as the oil has the appropriate Ford spec, which Chevron does for the 5W-20 & 5W-30 you're good to go. It doesn't have to be a synblend or synthetic. Shell Formula 5W-30 has Ford's spec and it's considered a conventional motor oil. However if your iOLM goes to 10,000 miles and you go that far I'd use a synthetic. Your engine should not be as tough on the oil like the Ford EcoBoost's. My iOLM in our 2.3 EB Explorer always tracks to 10,000 mi OC,s. I use Mobil 1 5W-30 but have been changing it in the 7,000 mi range. My iOLM reads 38-42% oil life left. While my UOA wear numbers come back good the oil shows signs of fuel dilution and thinning to a 20 weight oil from the original 30 weight oil. I might go a bit more for the next oil change and see how the UOA pans out.
Whimsey
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4804957
07/04/18 11:38 AM
07/04/18 11:38 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Correct
Unless the manual calls for synthetic-only, then conventional can be used.
Most-all 5w20s are blends, in order to meet the tough specs the government mandates these days. If you see a bottle of 5w20 that advertises itself as a blend, then it has a higher percentage of synthetic in that bottle, than the one that doesn't state it's a blend.
Use Chevron with confidence. What matters-most with your Ford is the viscosity you choose, which should be in-agreement with your owners manual under warranty.
If it's no longer under warranty, then you can choose nearby viscosities too....ie... 0W20/30, - 5W/10W30......etc..... If the manual has a disclaimer / No-No regarding those other viscosities I listed, then you have the right to either follow suit, or disregard their wordings.
After-all, you are full owner of that vehicle no longer under warranty and can use anything you like. The responsibility then falls on your lap / dime.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: 2013 F150 5.0 oil and IOLM [Re: JLTD] #4804965
07/04/18 11:54 AM
07/04/18 11:54 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
I am not sure when they changed it on the F-150's, but I know that my 2010 F-150 was merely a time/mileage counter that went to zero at 7,500 miles. My 2014 Explorer is not like that, it factors in operation and is not simply a counter, it works the same as the one in my 2015 Powerstroke.
Re: 2013 F150 5.0 oil and IOLM [Re: 2015_PSD] #4804988
07/04/18 12:37 PM
07/04/18 12:37 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
Yeah I don't know either, but in my 2013 I tested it several times and it was a countdown timer....whether towing, highway, or around town it counted almost exactly 1% per 100 miles.
It also counted down if parked, at a speed that would take it to 0% in 6 months.
I guess the monitors are getting smarter, but they're still only computer algorithms that are estimating the oil's condition - which is why I use them as a guideline along with a couple of UOAs.
On my T4R, it's 5000 miles and the warning goes off.
Using AMSOIL‚ĄĘ
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4805101
07/04/18 02:41 PM
07/04/18 02:41 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
I'm surprised no one has any info from Ford on how it works because from what you guys are saying -its a dumb countdown timer which is is lame.
GM's was pretty sophisticated - until I got it got corrected to 7500 miles regardless because of problems with the 3.6
I was able to dig out some fairly interesting data on how Honda does it with help from the Ridgeline owners forum guys Hondas is sensor heat based calibrated for dino and penalizes short cold hops.
UD
Uncle Dave
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4805152
07/04/18 03:38 PM
07/04/18 03:38 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
You could use 5W20 Supertech "conventional" and the results would be compairable to Motorcraft.
don't use.
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4805207
07/04/18 04:48 PM
07/04/18 04:48 PM
Central NY
rsylvstr Offline OP
rsylvstr  Offline OP
Central NY
I totally agree the readings would be the same.
The IOLM has NO ide what is in there.
My understanding as one posted already is it is based on algorithms that are matched to the ford spec.
Just installed a FL500s and MC blend 5w-20. Will see how long before she goes from 100% to 20%.
I just want to know what engineer to choke.
My big oil catch pan isnít big enough to catch both areas where the filter residue oil drains!
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4805244
07/04/18 06:10 PM
07/04/18 06:10 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
The only gripe I have about my Ram is after removing the oil filter oil falls all over the front end and makes a mess.
don't use.
Re: 2013 F150 5.0 oil and IOLM [Re: rsylvstr] #4805277
07/04/18 07:28 PM
07/04/18 07:28 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
LOL yeah drips both sides...I ended up getting a rectangular pan, the corners just made it outside the drips by about 2cm....
Using AMSOIL‚ĄĘ
