Happy 4th everyone... !
Lost power yesterday and fired up my Powermate PM01206000. Started with a couple pulls but after 15 minutes or so would start to sputter and then stall out.
Happened a number of times and each time, would run for a lesser amount of time... down to maybe 5 minutes. After the 2nd stall, I unplugged the low oil sensor... no effect
Ultimately moved choke in 1/4 position and ran for hours.
Fuel is good.
Air filter is fine.
Spark plug is new.
Generator has only 15 hours of run time.
I run the generator every 3 or 4 months and place a load on it for 15+ minutes.... then drain gas and store in garage
Any thoughts as to why this might be happening?
Thank you
Fuel is good.
Air filter is fine.
Spark plug is new.
Thank you
