0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
36 registered members (alphadog, bfleeman, BlakeB, BrianF, Blkstanger, anndel, 2 invisible), 733 guests, and 56 spiders.
Topics298,255
Posts4,988,168
Members67,246
Most Online2,474
Feb 10th, 2019
Kubota T1760 transmission fluid type/change #4804786
07/04/18 08:03 AM
07/04/18 08:03 AM
ms
racinjason Offline OP
ms
I recently acquired a T1760 with 235 hours on it. I want to change the transmission fluid. I know I have to pull the trans out to fully drain it. You can half change it with the plug on the side, maybe I should just half change it a few times.
My question is what fluid to put in it? I canít find a definite answer. It looks like udt or sudt2, but I know itís a hydro-gear unit, which I hear anything from 10w30-5w or 15w-50.
I really donít want to hear any whining, but I want the trans to last. Itís a strange looking unit. Iíve worked on countless mowers and this one looks the oddest. I donít think it would be easy to replace and for sure not worth a new one. It works fine at this time.
Any input would be appreciated.
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4804849
07/04/18 08:46 AM
07/04/18 08:46 AM
Virginia
mattwithcats Offline
Virginia
Looks like 20w-50...
I would use NAPA 15w-50, full synthetic...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4804907
07/04/18 09:42 AM
07/04/18 09:42 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Wow that is low hours for being 20 years old. You could probably get away with multiple drain and fills, especially if you can get dino 20W50W or 10W30 at a discount and change it often. When you are OK with the condition of the fluid, put something good in.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4804916
07/04/18 09:52 AM
07/04/18 09:52 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
I would do two drain & fills and call it good.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4805022
07/04/18 12:24 PM
07/04/18 12:24 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
I'd use exactly the Kubota fluids, in your case UDT would do quite well and is less expensive than SUDT2. Kubota tranny fluids are excellent and seldom equated in the non OEM fluids. Go onto any farm tractors forum and they'll confirm what I just wrote.
Re: Kubota T1760 transmission fluid type/change [Re: mattwithcats] #4805077
07/04/18 01:22 PM
07/04/18 01:22 PM
ms
ms
Lol fixing to go pickup 10 qts in a minute. I have some hydro gear zt2800ís to service and replace an input seal.
Re: Kubota T1760 transmission fluid type/change [Re: maxdustington] #4805080
07/04/18 01:23 PM
07/04/18 01:23 PM
ms
ms
I have 20-30 gallons of straight 40, also 12 or so gallons of 15w40.
Re: Kubota T1760 transmission fluid type/change [Re: Pelican] #4805086
07/04/18 01:26 PM
07/04/18 01:26 PM
ms
ms
I have 2.5 gallons of udt I probably wonít use(all my bigger Kubotaís use sudt2) I also have 2 gallons of mystic Jt-5. I know udt is fine, BUT. See all the recommendations for 15w50 syn.
Kubota doesnít make it clear and I canít find a sticker on the rear end to see which model hydro gear it is.
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4805701
07/05/18 09:45 AM
07/05/18 09:45 AM
Pelican Offline
Pelican  Offline
I'd play it safe and go with Kubota's fluids.
Re: Kubota T1760 transmission fluid type/change [Re: racinjason] #4810149
07/10/18 10:48 AM
07/10/18 10:48 AM
ms
ms
Well an update
1. It does in fact have a drain plug(found it after trans was out). Internet says it doesnít have one, itís there right in the center.
2. It doesnít hold 2.5 qts(less than 2). I let it drain for 2 days upside down.
3. I donít think itís a hydro gear like the internet says. It has no stickers or model numbers that I could find. I believe it to be a Kubota made unit. The design is like Kubota imo.
4. Fluid smells like UDT, I will put that back in it
5. It does not like 15w-50. It moves fine but is LOUD.
Maybe this will help someone out.
Moderated by  ekpolk
