New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
116 registered members (1WildPig, 240_Ed, 69Torino, 2003f7, 53' Stude, 14 invisible), 1,867 guests, and 48 spiders.
Topics284,669
Posts4,874,845
Members67,313
Most Online2,548
Feb 16th, 2019
Generator Cuts Off #4804747
07/04/18 07:29 AM
07/04/18 07:29 AM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Happy 4th everyone... !
Lost power yesterday and fired up my Powermate PM01206000. Started with a couple pulls but after 15 minutes or so would start to sputter and then stall out.
Happened a number of times and each time, would run for a lesser amount of time... down to maybe 5 minutes. After the 2nd stall, I unplugged the low oil sensor... no effect
Ultimately moved choke in 1/4 position and ran for hours.
Fuel is good.
Air filter is fine.
Spark plug is new.
Generator has only 15 hours of run time.
I run the generator every 3 or 4 months and place a load on it for 15+ minutes.... then drain gas and store in garage
Any thoughts as to why this might be happening?
Thank you
God Bless America
Re: Generator Cuts Off [Re: Finz] #4804783
07/04/18 07:59 AM
07/04/18 07:59 AM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
I would have tried putting the choke back to full off before shutting it off to see if it now would keep running. It may have cleaned itself out. Pretty obviously wasn't getting enough gas . OR, it has developed a vacuum leak.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Generator Cuts Off [Re: Finz] #4804794
07/04/18 08:11 AM
07/04/18 08:11 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Sounds like a carburetor jet getting partially clogged.
double check that the vent in the gas cap isn't clogged.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Generator Cuts Off [Re: Finz] #4804799
07/04/18 08:15 AM
07/04/18 08:15 AM
Ohio
Dave Sherman Offline
Ohio
Maybe a clogged emulsion tube or jet. You might take the float bowl off and see if its clean in the bowl. Does it have a fuel filter? Check that too.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Generator Cuts Off [Re: Finz] #4804818
07/04/18 08:27 AM
07/04/18 08:27 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
While its running, quickly flip the choke over to choke. Do this 10-20 times. Sometimes this will suck a "looogie" through the carb, and clear any restrictions.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Generator Cuts Off [Re: Finz] #4804826
07/04/18 08:29 AM
07/04/18 08:29 AM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Good stuff everyone.... will give all of these a shot
Loogie.... LOL - showing your age with the one I think. Havent heard that term since... a while ago
Thanks again
God Bless America
Re: Generator Cuts Off [Re: Finz] #4804837
07/04/18 08:39 AM
07/04/18 08:39 AM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
Pour some good Fuel System Cleaner in the gas tank. Run it on choke. It may work without having to mess with the carb.
Re: Generator Cuts Off [Re: Finz] #4804866
07/04/18 09:02 AM
07/04/18 09:02 AM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
...and now its running like a top
Hate it when stufff fixes itself
Thanks again for the responses and have a safe 4th
God Bless America
Re: Generator Cuts Off [Re: Warstud] #4804868
07/04/18 09:04 AM
07/04/18 09:04 AM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Warstud... Good call
I have a dose of Berryman B-12 in the gas cans. Started doing that when filling a couple years ago
God Bless America
Re: Generator Cuts Off [Re: bubbatime] #4804897
07/04/18 09:27 AM
07/04/18 09:27 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I'll have to remember this, thanks for the tip.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Generator Cuts Off [Re: Finz] #4804969
07/04/18 11:03 AM
07/04/18 11:03 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Sounds to me like like my old friend BOOZEGAZ has claimed another victim. Ya cant run ethanol in any small carbed engines that sit pretty much period. Well you can if you use a fuel shut off valve and drain the carb every shut down. Its far better to use high test or even 100 Low Lead airplane gas in those things that sit like a standby generator. Heck even my GM 2 bbl plugged this year after a full rebuild just last season. As usual just pull the covers clean out the jet and it ran fine again. That ethanol is evil!
youll probably get lucky using the cleaner as others mentioned since it runs. If not take it off and clean it. They usually get a nice cleanish lens of varnish in the main jet in my experience. If that doesnt do it just buy a new carb. Lately they have gotten super cheap. When I did a fellas snowblower last year it cost him $13. Put it on and away it went just like when my Genny died several years back. Not even an adjustment needed. Carbs are so cheap they cost less than an OEM rebuild kit. You never could do that before the ethanol scourge
Moderated by  ekpolk
