Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
64 registered members (Best F100, 69Torino, Billbert, bismic1, Astro_Guy, 9 invisible), 805 guests, and 52 spiders.
Topics284,589
Posts4,872,998
Members67,294
Most Online2,548
Feb 16th, 2019
Oil suggestions for my modded Mercedes #4804490
07/03/18 08:43 PM
07/03/18 08:43 PM
Thornhill, Ontario, Canada
Mau Offline OP
Mau  Offline OP
Hey guys,
Got a 2017 Mercedes C43, factory fill is M1 0w40 which is what I've been running in it. I feel based on the oil temps the oil is sheering down to a 30 weight with the insane heat this car produces. This car is stage 2 tuned (with down pipes). Factory numbers are 362 hp / 384 ftlb torque. Tuned with down pipes this is now about 430 hp / 570 ftlb torque.
Oil temps are getting pretty high especially with brutal heat we've been having here in Toronto. I want to switch to a 5w40 oil for the summer and possibly for the winter (winter the car is usually indoors overnight and during the day so brutal cold starts are rare).
I've looked at Motul Xcess 5w40 and Liqui Moly Leichtlauf High Tech 5W-40 but to be honest stats wise (looking at HTHS, TBN, VI etc...) its not that much of a difference from the M1 0w40 which I know is a stout oil and everyone here loves.
What do you guys suggest I try? Redline oils are great but don't meet the 229.5 spec which honestly at this point not sure if I need to follow since my car is modded (still have a warranty!).
17 MB C43 AMG - Amsoil EFM 5w40
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804501
07/03/18 08:56 PM
07/03/18 08:56 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Does it have an oil pressure display? If oil pressure stays good while you're doing spirited driving, maybe the M1 0W-40 is protecting just fine.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804510
07/03/18 09:01 PM
07/03/18 09:01 PM
Mau Offline OP
Mau  Offline OP
when oil temps get high the car seems to kill its burbles for some reason. I'm seeing about 233 degrees Fahrenheit when the ambient temps are about 77.
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804516
07/03/18 09:04 PM
07/03/18 09:04 PM
john_pifer Offline
john_pifer  Offline
Kill its burbles?
What does that mean?
16 WRX - PPPP
Re: Oil suggestions for my modded Mercedes [Re: john_pifer] #4804525
07/03/18 09:13 PM
07/03/18 09:13 PM
Mau Offline OP
Mau  Offline OP
Kill its burbles?
Car has this burble to it when you let off the gas (must be doing something with the unburnt fuel), sounds insane but I guess for safety purposes it kills it (no more bubles) when the oil temps go over a threshold and with M1 0w40 its going over that threshold. Also I want to try another oil to see if the engine ticking noise goes away like the corvette guys that have the m1 0w40 factory fill have as well.
Here are the oils that I've researched and can attain easily in Canada (let me know if there are others I should look at).
Motul Xcess 5w40
Liquimoly 5w40
Total Quartz 9000 5w40
Amsoil European Car Formula 5W-40 Classic ESP
Castrol Edge SPT 5w40
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804536
07/03/18 09:23 PM
07/03/18 09:23 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
I've used a bunch of TQ 9000, great oil.
Did a shop do the work? What do they advise?
"If I walked on water, they'd say I couldn't swim."
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804561
07/03/18 10:01 PM
07/03/18 10:01 PM
TX
s2krunner Offline
s2krunner  Offline
TX
C43 is turbocharged engine, right?
Our local Mitsu Evolution 8/9 shop been using Amsoil. Track or daily in 100 plus degrees for years. Stock to high whp.
I know others are great oil as well but i will go try Amsoil first.
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804581
07/03/18 10:39 PM
07/03/18 10:39 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
All of those 5w-40's aren't going to be much, if any heavier than the 0w-40 you are running presently, because they are Euro 5w-40's, so they tend to hit right in the same visc range.
You could step up to an HDEO 5w-40, which would be heavier, or go with a 5w-50 or 15w-50 if you really feel you need the viscosity reserve.
AMSOIL makes a 5w-50:
https://www.amsoil.com/shop/by-product/m.../?code=AMRQT-EA
Mobil makes a 15w-50 that you can find at Canadian Tire.
2019 RAM 1500 Sport
2016 Grand Cherokee SRT
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804651
07/04/18 04:40 AM
07/04/18 04:40 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
235 isn't that bad for a high performance turbocharged car, I always was told 250-265 is max normal limit, and 300 is starting to break down. Maybe theres some sort of inline oil cooler you can add, or a while ago they used a finned oil filter cap cover to lower temps a bit on MBs older engines that all used the same housing and filter. Your filter is in a tough spot for cooling, dead center on the engine right behind the radiator, so I don't know if the cap will work. Is there any type of programming to run the cooling fan or aux water pumps a little longer? It was a long time ago but in the B5 S4s I owned I always swapped the after run relay out for lower temp/longer "on time" one, and it helped. Also a lot of the guys on the BMW forums are removing their engine trim covers, lowers cylinder head temps by 20-30 degrees on hotter or track days, which can help keep it down a little.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804659
07/04/18 05:18 AM
07/04/18 05:18 AM
Mau Offline OP
Mau  Offline OP
Thanks for the input guys. I may need to look at an external cooler, for now I have ordered amsoil 5w40 classic. Became a preferred member for a year, 3 oil changes will more than cover the membership.
Audios how do you like Fuchs?
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804662
07/04/18 05:25 AM
07/04/18 05:25 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
No problems so far, a lot of our customers run it to the full interval also (sometimes more...idiots) I recently sent a sample to Wix for testing, my buddy went 11k on his 17 jetta 1.8t ( 4.5 quarts....idiot), and its been sitting at a post office location for 15 days already, I guess BC i sent it in the bottle and didn't box it up. Interested to see how it holds up long term. Also peace of mind knowing the oil I put into cars is more than capable. Our cheapie Cam 2 5/30 blend for the basic oil changes is rated to 7k or so per Blackstone, so I feel better knowing its decent and not bottom of the barrel.
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804666
07/04/18 05:31 AM
07/04/18 05:31 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Why not Mobil 1 FS X2 5W-50?
Carries Porsche A40 and MB229.3 & 1.
"Zed's dead baby, Zed's dead."
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804735
07/04/18 07:17 AM
07/04/18 07:17 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This was made just for cars like this one. I ran this oil in its previous version the RS10w60 for over 200K in a superbike from when it was brand new, no other oil weights or brands for 12 years with no out of spec wear inside the engine or loss of compression.
It got hot enough to turn the tires into pencil erasers running 250+ kmh a lot of the time.
https://www.amazon.com/Castrol-12064-SUP...strol&psc=1
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4804762
07/04/18 07:40 AM
07/04/18 07:40 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Hello, fellow Torontonian here.
Is this an all situations DD? Do you have another car you drive? I was going to suggest something a little more stout for the summer and EDGE 0W40 for the winter. I would try something thicker in the winter if it is stored indoors. You can probably get by with a 10W in the winter here honestly, it seems average winter temp is -10 to -15c with a low of -25. I've been researching this to custom mix my coolant.
I think Trav's suggestion of the supercar oil is perfect. I would not really feel comfy running 0W40 in the summer, I hit over 100c oil temps driving in the city yesterday on a stock 1.8T. It might spin a little slowly on a really cold start, but you can never go too thick in a German car.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Oil suggestions for my modded Mercedes [Re: Mau] #4808491
07/08/18 03:35 PM
07/08/18 03:35 PM
Mau Offline OP
Mau  Offline OP
Just to update the thread, I went with Amsoil 5w40 EFM for now. Specs are good and it is approved by MB.
Moderated by  ekpolk
