0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
38 registered members (750HMF, Bjornviken, Aero540T, 3dfever, 2strokeNorthstar, BrianF, 2 invisible), 618 guests, and 61 spiders.
Topics298,255
Posts4,988,178
Members67,246
Most Online2,474
Feb 10th, 2019
PUP 5w30 6.5k miles, 2017 Equinox 32k total miles #4804485
07/03/18 08:36 PM
07/03/18 08:36 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
They suggested 7500 miles on the last UOA, so I stretched it as far as the oil life monitor would let me. Got it down to 1% on the monitor, which ended up right around 6500 miles.
Filter for both changes on the UOA was a purolator pure-one filter PL22500. This was my last one, plan on switching over to a Fram ultra on the next change.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4804494
07/03/18 08:48 PM
07/03/18 08:48 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Oil is very good in viscosity range for a 5w30 ... And no potassium or sodium in your oil to show a coolant leak.. No fuel in gas as evidenced by high flash point.
This is a very good report.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4804608
07/03/18 11:56 PM
07/03/18 11:56 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
OLM is rather conservative.
7500 miles and beyond appears doable.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4804660
07/04/18 05:23 AM
07/04/18 05:23 AM
Milton, FL
jhs914 Offline
jhs914  Offline
Milton, FL
Doesn't GM require a Dex1Gen2 oil for that engine to control intake deposits and timing chain wear on this DI engine? Calcium looks too high for a D1G1 oil. PUP is a great oil and I'm sure it will handle timing chain wear just fine but not sure about intake deposits with that calcium level. Pennzoil web site shows this is a Dex1 oil but not Gen2.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4806300
07/05/18 08:46 PM
07/05/18 08:46 PM
Texas
4WD Offline
4WD  Offline
Texas
Was the same oil used on the 5500 mile OCI?
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4808518
07/08/18 04:32 PM
07/08/18 04:32 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
I am unfortunately not 100% sure... it was either PP or PUP.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: jhs914] #4808856
07/09/18 06:42 AM
07/09/18 06:42 AM
Milton, FL
jhs914 Offline
jhs914  Offline
Milton, FL
Meant calcium too high for a D1G2 oil.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4811861
07/11/18 09:55 PM
07/11/18 09:55 PM
The land of USA-made Subies!
SubieRubyRoo Offline
jhs914, Where is it discussed that high calcium causes intake deposits, please? This is a new claim for me.
Nice looking report! I've got about 17 gallons of PUP 5W20 since two of my vehicles spec it.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: SubieRubyRoo] #4812079
07/12/18 08:33 AM
07/12/18 08:33 AM
PimTac Offline
PimTac  Offline
Higher Calcium is a likely cause of LSPI hence the shift to high magnesium-lower calcium add packs. PUP has not followed this trend, yet.
Calcium does not cause intake deposits.
Cannot see signatures any longer so it doesn’t matter.
Re: PUP 5w30 6.5k miles, 2017 Equinox 32k total miles [Re: DenverGP] #4812356
07/12/18 02:09 PM
07/12/18 02:09 PM
Pim, while I can't personally verify this, that's what I understood. This claim that calcium causes the carbonized intake deposits sounded barmy (thanks, Shannow!) at best, so I wanted to see if there was any basis for the claim.
Yes, SOPUS has let PUP lag behind on formulation, but if it meets the specs for your engine, it's still a really good choice to dump in the sump after you drain the old oil while on your rump, in the driveway. smile
Moderated by  ekpolk
