First let me say I am not a fan of additives. I do use a carb/injector cleaner every 5K miles or so.
I had a very unfavorable opinion of Sea Foam bc of my internal wiring..what I believe is what it is.
Fast forward: My Subaru 08 very well kept burned oil at over 70mph. As much as a quart in 250 miles. I switched to 40 wt and if I stay under 70 mph it uses almost no oil.
I had my subaru specialist check the vehicle out bc I was planning on giving it to a grandchild. I asked him to rereplace the screen on the fuel pump (in the tank) he told me in his experience it is not necessary. But he indicated that If I run a can of SeaFoam through the fuel system and add it at a half tank or less I would be good to go.
On a trip; my subaru for the first 4 years would deliver 30+ mpg. But since then usually gets 27+. I went out to Pittsburg with a full tank and a can of Seafoam. Over 470 miles the mileage was 30.1 mpg. I was very careful to fill the vehicle at the start and end of trip on the level at the same pump. I got 7 gallons out in Pittsburgh. So I have no doubt this was no error or no coincidence. I just added another can again.
I will give all of my vehicles a SeaFoam every 5 or 6K miles.
