0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (3dfever, 2strokeNorthstar, Bjornviken, BrianF, burla, alphadog, 3 invisible), 626 guests, and 61 spiders.
Topics298,255
Posts4,988,173
Members67,246
Most Online2,474
Feb 10th, 2019
Are newer tpms sensors movement activated? #4804186
07/03/18 03:28 PM
07/03/18 03:28 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
i recall reading that newer TPMS sensor are now movement activated. this is done to conserve battery. is this true?
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804204
07/03/18 03:53 PM
07/03/18 03:53 PM
Canada
i_hate_autofraud Offline
Canada
They can be depends on who makes them and the system.
It's also possible the car sends a signal and wakes them up when you start to drive.
Re: Are newer tpms sensors movement activated? [Re: i_hate_autofraud] #4804210
07/03/18 03:59 PM
07/03/18 03:59 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Which means they would have to be constantly listening for the "wake up" signal, and that in itself would be chewing up their battery.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804247
07/03/18 04:56 PM
07/03/18 04:56 PM
MA, USA
krzyss Offline
krzyss  Offline
MA, USA
Listening to radio is usually less energy consuming than transmitting. So if “do not tell until asked” is implemented it may preserve battery life. Motion activation would be even better. I think engineers are using all the tricks available to save battery life.
Krzyś
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804256
07/03/18 05:01 PM
07/03/18 05:01 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
They are in sleep mode. I believe the sensors are micro-machined electrical mechanical MEMS with on-board firmware signal conditioning. One of the features are nano current sleep mode. any movement of the device triggers the output. Output is nothing more than a bursted data packet. If the receiver is listening it will receive and decode the packet. They also go to sleep in between output pulses so the battery can last a couple of years.
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804285
07/03/18 05:18 PM
07/03/18 05:18 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
On my 2017 RX 350 you have to wait a few minutes after being underway before you can get a read from the TPMS which leads me to believe that they must be in sleep mode.
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804452
07/03/18 07:55 PM
07/03/18 07:55 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
You may be thinking of ones that rely upon wheel speed differences instead of a pressure transducer.
My Honda Accord doesnt have any sensors in the wheel (fortunatelY). It uses an analysis of minute differences in wheel rotation.
Knock on wood, my BMW sensors still work.
Not sure what the lifetime of the batteries in these things are.
It would be sensible for the batteries to be isolated to avoid any quiescent drain.
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804540
07/03/18 09:25 PM
07/03/18 09:25 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Good question on the batteries in the TPMS system. 3 of the 4 sensors on my 10 year old Suburban are original and still work. One died and I ordered a package of 4 from Amazon. I gave one to the tire shop and they de-mounted the tire, installed the new sensor and activated it. I’ll do the other three when I toss these tires and buy new ones later this year.
If you want the job done right......do it yourself.
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4804618
07/04/18 12:14 AM
07/04/18 12:14 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I've got to be moving in my Sonata for my tire pressure to display, maybe that's the same thing?
2015 Hyundai Sonata 2.4L 91k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4805854
07/05/18 12:20 PM
07/05/18 12:20 PM
Canada
Canada
Years back, a hardware wireless application called "telepanel" had receivers and a CPU
that would 'wake up' and listen for 1 second and stay asleep 10 seconds and do it all
over again for years on 1 battery.
If there was an active data stream starting with a unit serial number, it would stay
on and turn off after data was received.
Re: Are newer tpms sensors movement activated? [Re: WhyMe] #4805954
07/05/18 01:41 PM
07/05/18 01:41 PM
Dana Point, CA
splinter Offline
splinter  Offline
Dana Point, CA
GMC = static readings at initial key on.
Porsche = readings only after exceeding ~20-MPH threshold.
M1 0W-40
T6 5W-40
PUP 0W-40
Moderated by  ekpolk
