0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (3dfever, 2strokeNorthstar, Bjornviken, alphadog, bfleeman, BlakeB, 3 invisible), 669 guests, and 59 spiders.
Topics298,255
Posts4,988,171
Members67,246
Most Online2,474
Feb 10th, 2019
Need help/advice servicing 13 altima cvt. #4804110
07/03/18 02:31 PM
07/03/18 02:31 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
Ive talked to my dealer on two seperate ocassions about the cvt. Once they told me it has "lifetime fluid" and not to touch it. The other day another service writer said every 30k miles and the service was 400 bucks! I got a quote from a iffy lube type place who said it would be 200. They'd use valvoline cvt fluid and flush the system. No filter change. Just a flush and fill. Im not comfortable with iffy lube and the dealer wants too much. How hard is servicing this transmission?
There is no dipstick on the cap of the fill tube. I guess i'd either have to measure exactly what comes out and put that amount in or fashion a dipstick to get a point of reference for what needs to be in there. What about changing the filter as well? Never had a vehicle before tgat was so unfriendly for the owner to work on. I cant even find much info online about it.
Thanks as always
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804143
07/03/18 02:49 PM
07/03/18 02:49 PM
USA
slacktide_bitog Offline
USA
I think there is a drain plug on the transmission. Just drain it, measure how much you drained (you can get a bucket like that at the Hone Depot or any other hardware store), and pour the same amount back in.
Advance Auto has a sale on Castrol CVT for just $5/qt smile
Transmission dipsticks are almost never accurate anyway. Honda is the only one I know that can actually make an accurate transmission dipstick crzy
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804154
07/03/18 02:53 PM
07/03/18 02:53 PM
TX - TEXAS
walk23 Offline
walk23  Offline
TX - TEXAS
Buy the fluid off eBay and the dipstick kit for the "13 Altima. Go to a local transmission shop and have them drain and refill. Replace the amount taken out and check the level on new dipstick. I bought 5 qts of NS-3. Cost was less than $50 for the service. Dipstick about $20 and fluid about $65.
2005 F-150
5w20 PP/ FU XG-2
2013 Nissan 2.5 Altima SL
0W20 PP GTL/ FU7317
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804160
07/03/18 02:57 PM
07/03/18 02:57 PM
CA
The Critic Offline
The Critic  Offline
CA
Where are you in CA? I might have some recommendations.
2011 Toyota Prius - 184k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804182
07/03/18 03:21 PM
07/03/18 03:21 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I would learn to do it if you don't already know how before I let a quick lube place anywhere near the car to service that transmission.
God Bless Our Troops
Re: Need help/advice servicing 13 altima cvt. [Re: The Critic] #4804211
07/03/18 03:59 PM
07/03/18 03:59 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
I'm in bakersfield
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804214
07/03/18 04:08 PM
07/03/18 04:08 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
If it's setup like all the late model Nissan (Jatco) CVTs I've seen, it will have a drain plug on the pan, a fluid level check plug on the case and a capped refill tube in the engine bay.
On my 2016 Nissan Quest's CVT, I drained the pan cold, refilled with the same amount of CVT fluid that came out and then checked level with the level check plug.
With the vehicle on a level surface and warmed up, idling in park, CVT fluid should just dribble out of the level check plug. The factory service manual will state a specific fluid temp range it must be checked at. I forget what that range is. I shoot the pan with a hand held thermometer. This is not the FSM way, but it's worked for me.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804226
07/03/18 04:26 PM
07/03/18 04:26 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
Sounds like i need the factory servuce manual.
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804230
07/03/18 04:32 PM
07/03/18 04:32 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
For my 2016 Nissan Quest, the temp range for CVT fluid level checking is 98-113F, while idling in park. It's a pretty wide range.
I bought my Nissan NS-3 CVT fluid off eBay. I believe your 2013 needs NS-2. If you're out of warranty, I'd use which ever aftermarket CVT fluid you like that says suitable for use for Nissan NS-2, etc.
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804290
07/03/18 05:21 PM
07/03/18 05:21 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
You can get by with a drain and fill. Make sure the new and old fluid are the same temp and replace the same amount, easy peasy with an ATF funnel. I have a Jatco trans in my car and if you fill it to the check plug it will be underfilled when you cycle through the gears.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804332
07/03/18 05:52 PM
07/03/18 05:52 PM
Austin, TX
MaximaGuy Offline
MaximaGuy  Offline
Austin, TX
I wouldn't let the CVT serviced by any other than the dealership and the soups are quite unique.
Stay with OEM fluid and get it done with the dealership - you will thank yourself for a good night sleep.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804396
07/03/18 06:55 PM
07/03/18 06:55 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Really easy service. I bought a 2015 Altima with maybe 80K miles from Hertz for a friend. The drain is easy-peasy.
But make sure you can remove the filler plug first! Mine was stuck. Someone suggested a little penetrating fluid mighta helped...
Anyways I drained out 4.1 quarts of black fluid and replaced same with Valvoline CVT fluid.
Made a nice difference.
As slackdog sez, you can get Castrol CVT Synthetic for $5; buy a bunch.
I serviced the CVT once again; the fluid looked better.
Runs real good.
I did purchase the dipstick from Ebay.
I guess the best way is to measure the fluid temperature and check; I have not done it that way.
Finally, Youtube is your friend.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4804839
07/04/18 08:39 AM
07/04/18 08:39 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
^Quoted for truth. That my friend would be just too easy! Given the delicate nature of these things and the critical nature of the fluid you wont find me messing around with one, by the book with OE fluids or nothing.
Re: Need help/advice servicing 13 altima cvt. [Re: monster1] #4805735
07/05/18 10:37 AM
07/05/18 10:37 AM
Houston, Texas
BlitzPuppet Offline
BlitzPuppet  Offline
Houston, Texas
Recommended service is at 60K I believe. I took mine in to the dealer to get serviced as I believe it had some sort of action needed by a scan tool that resets "Fluid Life" or something like that.
I may be wrong, but I did it anyways.
Re: Need help/advice servicing 13 altima cvt. [Re: BlitzPuppet] #4806014
07/05/18 03:00 PM
07/05/18 03:00 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Originally Posted By: BlitzPuppet
I took mine in to the dealer to get serviced ...
Mind if I ask how much the dealer charged?
Thanks in advence...
2018 Lexus RX450h
2006 Acura TSX
Moderated by  ekpolk
