Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
No start
by Roughneck777. 02/22/19 08:24 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
119 registered members (2003f7, 53' Stude, 2015_PSD, 2004tdigls, 007, 16 invisible), 1,850 guests, and 48 spiders.
Topics284,668
Posts4,874,842
Members67,313
Most Online2,548
Feb 16th, 2019
Page 1 of 3 1 2 3
What the Ford?! #4803413
07/02/18 05:32 PM
07/02/18 05:32 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Took on my first work on a 5.4 3V (in an '05 F150) today. Okay, what I've seen of post-squarebody F150's so far is that they just don't seem to age well and the 5.4 is, at the least, prone to exhaust leaks. Trim parts, interior pieces, etc. aren't available or are hard to find, especially in comparison to GM trucks that I can get door handles, climate control knobs, etc. for at most any parts house - in stock. I'm guessing that comes from the fact the F150 has been split off from the 250/350 for quite a while, making all cosmetic parts relevant to only a few models where Chevys are the same over 10/20/30 series, and usually stay that way for 5-8 years at a time.
But what really amazes me is under the hood of this truck. Plugs... well, of course we already know about those, but thankfully none broke on this one. I could do the VC gaskets and plugs in an LS-powered Chevy in the time it takes to do the plugs alone on the 5.4, even if it has the updated plugs that you don't have worry about snapping off. I'm going to guess doing VC gaskets on a 5.4 would take as long as doing exhaust manifolds, VC gaskets, and plugs on an LS, but then there's the EXHAUST MANIFOLDS on this engine. Remove fender liner (no biggie), remove exhaust (which won't actually come all the way out on the passenger side, after separating the Y-pipe), remove starter (3 bolts that are tight as the blazes and take the perfect combination of tools to gain access to), then use $100 worth of extensions, open end wrenches, and swivels to get at the studs, half of which are jammed right up against the upper control arm/coil over tower. Break half the studs, drop sway bar (because the passenger half of the Y-pipe won't come all the way out and make room), then fish the manifold out in just the right fashion, and go buy another $75 in tools I've never needed for anything else to drill out the studs that have barely a fist's space in front of them inside the frame.
No wonder a GMT800 goes for 50% more than an equivalent F150.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: What the Ford?! [Re: Alex_V] #4803436
07/02/18 05:58 PM
07/02/18 05:58 PM
MN
14Accent Offline
14Accent  Offline
MN
This is why any time a job like that comes in on an F150 I take the cab off. It just isn't worth the [censored] on those things trying to work on them with the body on. If I sold plugs and manifolds, I would have had the cab off in a jiffy.
Sorry you had the misfortune of working on one of those bad boys! Take a look at the project I just had on one last week:
2011 F-150 Ecoboost timing chain replacement
I completely agree about the Chevy trucks. Couple years ago I had to do head gaskets on a 6.0 2500. Did it in the body, no problem. Plenty of room for everything.
Try that on a 5.4...
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: What the Ford?! [Re: Alex_V] #4803452
07/02/18 06:17 PM
07/02/18 06:17 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
OHC vs pushrod.
Advantage pushrod.
What advantage is there in these OHC Ford engines?
I can't see any.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: What the Ford?! [Re: Alex_V] #4803471
07/02/18 06:44 PM
07/02/18 06:44 PM
out there
spasm3 Offline
spasm3  Offline
out there
Plus the non afm 5.3 T motors are good for at least 250k+
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: What the Ford?! [Re: fdcg27] #4803496
07/02/18 07:22 PM
07/02/18 07:22 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
Originally Posted By: fdcg27
OHC vs pushrod.
Advantage pushrod.
I can't see any.
Torque, back in the 5.4 2v vs GM 5.3 iron block days the 5.4 was making 360 lbft in the 2500 rpm range. The 5.3 was around 330 at 4000.
I dont feel like any engine can claim that much of a longevity advantage over the 2v modulate. Just look at how many 4.6s are running around with 300k+ miles. My buddys work truck is just shy of 500k on a 2v V10.
I wont make excuses for the 5.4 3v. That thing shouldve never happened.
Re: What the Ford?! [Re: fdcg27] #4803498
07/02/18 07:24 PM
07/02/18 07:24 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
OHC vs pushrod.
Advantage pushrod.
I can't see any.
Planned obsolescence and more money for dealers in parts and service.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: What the Ford?! [Re: Alex_V] #4803506
07/02/18 07:38 PM
07/02/18 07:38 PM
Canada
honeeagle Offline
honeeagle  Offline
Canada
What is the problem ,its called job security
if cars were perfect what would you do to feed your family
Volvo 670 singled smart car 'on deck' towing newmar 5th
Re: What the Ford?! [Re: fdcg27] #4803577
07/02/18 08:48 PM
07/02/18 08:48 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
OHC vs pushrod.
Advantage pushrod.
I can't see any.
I'm not at all sure the method of valve actuation has much to do with it. There are plenty of OHC and DOHC engines that are easy to work on and last a very long time.
I will agree that the modern Chevy Small Block is an excellent engine and is probably impossible to beat when it comes to outright power to weight and capability. Manufacturers, including Ferrari dump millions of dollars into exceedingly complex designs that cannot beat a simple, normally aspirated 5+ liter LS based engine. Watching the Corvette C7r cleanup at the Daytona 24 hour race, against the worlds best, was rather enlightening.
Re: What the Ford?! [Re: Alex_V] #4803672
07/03/18 02:23 AM
07/03/18 02:23 AM
Wisconsin
Black_Thunder Offline
Wisconsin
same argument could be had with Cadillac Northstar engines or any other FWD with a v8 wedged in the engine bay sideway or even a V6 for that matter.
they are trying to make vehicles lighter weight/smaller without allowing excess room for the drivetrain.
I know several guys with Duramaxes that say its easier to take the cabs off or pull the engine to do any real work on it, so its not just a ford thing.
the super duties are easier to work on with the larger engine bay, the f150's have had smaller engine bays since the late 90's
I do miss the old 4.9's
I'd buy Callahan autoparts if I could.
Re: What the Ford?! [Re: Alex_V] #4803747
07/03/18 07:06 AM
07/03/18 07:06 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
I don't disagree, it's not a Ford-only thing - but this isn't a diesel truck that was, almost, designed for commercial use and duty cycles. Hail the 300! Makes this thing look like trying to cut grass with the space shuttle. And, also, the 5.4 may have been more powerful than the 5.3, but it wasn't GM's only big gas engine for trucks. In the Chevy world it's the equivalent of the 6.0 never having existed and the only good-size gas engine choices for trucks being the 5.3 and 8.1. If the 5.4 had been less troublesome I wouldn't scratch my head, but from what I've seen of its longevity and capability it's never been superior to the LS, yet FMC kept using it and actually made it worse. BTW, I think 250K for a non-AFM LS is a pretty conservative number. I've seen them take serious abuse with over 250K already on them and not phase them.
I don't have the equipment to pull the cab or I would.
And cars don't have to be intentionally flawed for me to feed my family - I still make enough money working on 3800 V6's, OM617's, and the Honda F23. wink
Re: What the Ford?! [Re: Alex_V] #4803771
07/03/18 07:32 AM
07/03/18 07:32 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Don't forget the 5.4 also gets awful fuel economy. I've become a big fan of the 4.6 2V, though. Even the 4.6 3V in my wife's Mustang seems decent. Not sure what the differences are between it and the 5.4.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: What the Ford?! [Re: Silverado12] #4803901
07/03/18 10:23 AM
07/03/18 10:23 AM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
Stroke and deck height. The 4.6 3v came along late enough that the most obvious flaws of the 5.4 3v were redesigned already.
Re: What the Ford?! [Re: Alex_V] #4803909
07/03/18 10:30 AM
07/03/18 10:30 AM
South Central PA (Fulton Co)
Delta Online happy
Delta  Online Happy
The 2V 5.4 wasn't the easiest to work on either. We had one in the old '01 Expedition, and replacing coil packs and plugs was a chore and a half with the fuel lines going right on top. The rear HVAC stuff under the hood didn't help as far as room though. It would like to go through the recommended 5w20 oil pretty fast too.
'17 VW GTI 2.0T - 6MT - 13K - PPE 5w40
'15 Camry SE - 2.5 - 21K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: What the Ford?! [Re: Alex_V] #4803949
07/03/18 11:17 AM
07/03/18 11:17 AM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
Not going to get a lot of arguement on the 5.4 3V being a piece of work. I owned one in my '04 F150, and in this conversation, the wonderful timing chain and VCT system hasn't been touched on, but that is what doomed mine.
The 2V version all in all was pretty decent, though it never got the fuel mileage the Chevy's did.
And not everything was figured out on the 4.6 3V - my '07 Explorer has one of those, and two exhaust manifolds later (and you thought the F150 was fun...) They also initially had the same plug issue as the 5.4's did...
Re: What the Ford?! [Re: Alex_V] #4804127
07/03/18 02:40 PM
07/03/18 02:40 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
I've done plugs and manifolds on a '01 5.4-powered F150 and, while everything's in the same spot on the engine, the plugs are conventional and the standard control-arm front suspension isn't all up in the way of the manifolds. Still inferior to an LS engine but manageable. This 3V is just silly.
Page 1 of 3 1 2 3
Moderated by  ekpolk
