comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
100 registered members (AdditiveOCD, ArrestMeRedZ, ARB1977, 2012AccentSE, 1978elcamino, 12 invisible), 2,150 guests, and 55 spiders.
Topics286,392
Posts4,907,441
Members67,614
Most Online2,967
Mar 10th, 2019
2015 Ford Powerstroke Fuel Filter #4801744
06/30/18 08:13 PM
06/30/18 08:13 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
Changed both of them today, I went over my normal FCI by 5K. No pictures, but they looked fine. The lower filter housing had some rust flakes in it and once before there was also some. My tank is plastic so it is in the fuel.
I just need to figure out which station has old tanks and stop going there. I use Stanadyne, Howe's, or Diesel Clean with every tank as added protection against lack of lubricity in ULSD, but I also run biodiesel which has a little more lubricity than standard #2 Diesel.
Anyone else use fuel additives?
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4801809
06/30/18 09:12 PM
06/30/18 09:12 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I do not believe any of the new diesel engines are very picky about the lubricity of the diesel fuel. But the Bosch VP44 in my 1999 Dodge Ram w/Cummin was a mechanical injector pump and required the proper lubricity.
I used TC-W3 two cycle oil to add to that diesel fuel.
2015 Ford F250 w/Powerstroke
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4801819
06/30/18 09:16 PM
06/30/18 09:16 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I use this with every fill up on my old Ford 7.3 and now on my Duramax.
I also don't use Biodiesel.
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2015 Ford Powerstroke Fuel Filter [Re: JohnnyJohnson] #4801840
06/30/18 09:37 PM
06/30/18 09:37 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
Yes, I use this one too. No choice in my area, biodiesel is all there is.
Re: 2015 Ford Powerstroke Fuel Filter [Re: Donald] #4801845
06/30/18 09:39 PM
06/30/18 09:39 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
I would stay on top of your filter maintenance and drain monthly. There are many cases of the HPFP having issues in 2012-2016 Ford trucks posted, mostly due to water in the fuel. I use the additives for water control as much as lubricity.
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4801850
06/30/18 09:43 PM
06/30/18 09:43 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Well I am glad I have yet to find any rust in the fuel I buy. I only use high traffic stops and fingers crossed I wont run into any issues.
My Ram uses a 2 filter setup as well. The rear course filter/water separator seems to soak up the brunt of the debris. I wish it was a cartridge filter so I could inspect it without having to tear it down (have yet to). The front cartridge (3 micron) always comes out looking great at 24,000km. So much so I will begin extending the change index off warranty.
I don't use additives. I spoke with a few of my friends in the area that run diesels. Cummins and Powerstrokes. No one uses them and have yet to run into any issue. No one treats with antigel either as the stations up here use seasonal fuel and do a good job of keeping their tanks in order.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4801879
06/30/18 10:23 PM
06/30/18 10:23 PM
Naperville, IL
wwillson Offline
Administrator
wwillson  Offline
Administrator
Naperville, IL
I have a Duramax with the Denso HPFP and run Opti-Lube XPD. It may not be required, but with the lubricity index of ULSD, I'd rather be safe than have an expensive repair bill if the HPFP would go like many of the Bosch CP3/CP4 pumps did.
Re: 2015 Ford Powerstroke Fuel Filter [Re: wwillson] #4801922
06/30/18 11:25 PM
06/30/18 11:25 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
Agreed; the Bosch is what Ford uses.
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4802466
07/01/18 03:59 PM
07/01/18 03:59 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
The rust most likely came out of the fuel terminal or pipeline. It is amazing the amount of junk that comes up out of the pipelines that only run refined products when we run pigs through them. For the amount of product transferred it isnít much at all but sends a nasty slug down the line when we clean it out.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4802469
07/01/18 04:06 PM
07/01/18 04:06 PM
New Hampshire
frankbee3 Offline
frankbee3  Offline
New Hampshire
I too am concerned with lower lubricity of ULSD. My 2003 Dodge Ram Cummins uses the CP-3 pump if I remember.
I found some report somewhere where different fuel additives were tested for lubricity. I think I may have found the information on the turbo diesel register.com forum. I ended up choosing Amalgamated TDR-WDA fuel additive. I went with the 2.5 gallon container, which was right around $100. Amalgamated was really nice to deal with.
I havenít run the truck with straight fuel since I have owned the truck.
My goal is to prevent having to replace any of the high pressure fuel system components for as long as possible.
Sorry, the link I was going to attach seems to be a dead link now..
1992 Toyota Pickup
2001 Mazda Miata
2003 Dodge Ram 2500 Cummins
2008 Subaru Outback
Cessna 180
Miscellaneous Yard tractors and lawn mowers
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4806804
07/06/18 01:06 PM
07/06/18 01:06 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
Any newer Ford owner needs to take great care of their fuel system on these 6.7's.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4818607
07/20/18 09:24 AM
07/20/18 09:24 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Stanadyne every tank here, after trying several different adds. Decent product, price is right at Rural King.
I just ordered a quart of FP60 to try as well.
beanoil: Tough under heat, real dirty afterwards.
Re: 2015 Ford Powerstroke Fuel Filter [Re: 2015_PSD] #4850767
08/25/18 05:06 PM
08/25/18 05:06 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Keep those filters clean, gents.
While a sales blurb, I have a tendency to believe it. VP Fuels on Diesel
I'm still running Stanadyne every tank, I started adding FP60 in a small dose as well. FP60 smells just like a new vinyl pool liner to me.
