WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
97 registered members (53' Stude, 240_Ed, 2010Civic, 2015_PSD, 8 invisible), 2,221 guests, and 49 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Changed oil today, couldn't get the filter off! #4801415
06/30/18 12:52 PM
06/30/18 12:52 PM
Balearic Islands , Spain
FordCapriDriver Offline OP
Went to change the oil and filter on my 1988 Escort today, and i was unable to get the filter off frown
I tried the best i could probably nearly snapped a tendom and couldn't get the [censored] thing off, best of all it's right at the back of the engine in the middle of the block so it's hard to get to from either side, also tried from underneath with no success.
I think it might be because the engine was nearly warmed up and hot, also today was a pretty hot day with a high of +37C ( 99F ) , i last changed it in February and it was 10C that day ( 50F ) and i was able to get it off no problem, i only tightened it by hand.
I will attempt to get it off with the engine cold another day, the engine only takes 3L so i have 2L of change in case i spill a lot taking it off.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801423
06/30/18 01:01 PM
06/30/18 01:01 PM
NH
supton Offline
supton  Offline
NH
Bummer! I recall driving a screwdriver through one once.
I picked up a three pronged tool to go onto a ratchet and it seems to make the job a snap. This one.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 147k, ours
1999 Toyota Camry LE, 2.2L/4AT, 203k, his
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801427
06/30/18 01:06 PM
06/30/18 01:06 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Maybe being on your back you thought you were losing it, and were actually tightening it...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801431
06/30/18 01:11 PM
06/30/18 01:11 PM
PimTac Offline
PimTac  Offline
Iíve only had this problem with the first oil change on a new vehicle or after a dealer changed the oil. Iíve learned to loosen both the drain plug and the filter before doing the entire change.
Cannot see signatures any longer so it doesn’t matter.
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801446
06/30/18 01:28 PM
06/30/18 01:28 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Perhaps a little penetrating fluid might help?
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801453
06/30/18 01:48 PM
06/30/18 01:48 PM
NH
supton Offline
supton  Offline
NH
I like the idea of just waiting for it to get cold. Might make all the difference.
Re: Changed oil today, couldn't get the filter off! [Re: PimTac] #4801454
06/30/18 01:49 PM
06/30/18 01:49 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
This! DIY LOL thumbsup
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801457
06/30/18 01:50 PM
06/30/18 01:50 PM
NY
demarpaint Offline
demarpaint  Offline
NY
First make sure you're loosening it and not tightening it. Sometimes being on your back looking up like rollinpete said mixes things up for a moment. If you can't get it off giant Channel Lock pliers or stabbing a screw driver through it have always worked on the few I've encountered over the years that wouldn't come off.
I'd love to try a good fitting cap wrench and a blast from an impact gun on a test mule. Having the Channel Lock pliers or stabbing through it with a screw driver as a back up. The impact gun is something I've never tried though. I could swear some of these quick lube or dealer oil change guys use them to install the oil filter and the fill plug on a lot of cars.
God Bless Our Troops
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801476
06/30/18 02:15 PM
06/30/18 02:15 PM
USA
slacktide_bitog Offline
USA
No way to use a hammer and screwdriver? smile
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801478
06/30/18 02:18 PM
06/30/18 02:18 PM
Thanks for the advice, i'll try again Wednesday or Thursday when i have my day off and the engine is cold.
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801503
06/30/18 02:48 PM
06/30/18 02:48 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
1) Good grip? Twist it off.
2) OK grip but no turn? Try sloppy addition of masking tape. Make it flop around (sticky side up and down-all krinkly). Might work
3) Strap wrench. Go for the base plate so you don't crush the filter
3a) second choice is strap wrench on the end of the filter.
4) Correct size cup wrench
5) those 3 pronged things. Like the cup wrench, they slip sometimes. Nobody ever has a perfect fitting one.
6) those channel lock style pliers
7) Screwdriver Valentine is the last thing you want to do. No guarantee of success and the sheet metal can can just tear
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801507
06/30/18 02:52 PM
06/30/18 02:52 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
My filters come off easy, but if I had problems I would try one of these, looks like it could do the job.
Pete.
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801564
06/30/18 03:38 PM
06/30/18 03:38 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
I have used strap type filters in past for some very challenging filters I could not get off any other way. These will crush the filter until it finally comes off.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801565
06/30/18 03:40 PM
06/30/18 03:40 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
The above fit into very tight places where a screwdriver might not. Fits on a ratchet and slides in next to the filter.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Changed oil today, couldn't get the filter off! [Re: FordCapriDriver] #4801568
06/30/18 03:41 PM
06/30/18 03:41 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The spring loaded 3 finger one that goes on like a cap wrench is the one I use if I cannot get a filter off the normal ways and have access to the end.
Lisle probably makes the one I have.
Over the years you build up a collection of oil filter wrenches.
I have broken the spot weld on a HF cap wrench.
2015 Ford F250 w/Powerstroke
Page 1 of 4 1 2 3 4
