OVERKILL
$100 Site Donor 2021
Originally Posted By: ZeeOSix
It just means that nothing using UPNP inside your network is active, so there are no active mappings. Yes, you should disable it.
Should both the UPnP and UpnP NAT-T be disabled? Right now, both show as "Enabled" on my modem/router.
Will setting these to "Disable" cause any headaches down the road, like if I need to setup a wireless device (cell phone, smartTV, etc) up to use my modem/router?
Disable both. Since both are not doing anything presently, the odds of it breaking anything are pretty low.
