Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
83 registered members (53' Stude, 2003f7, 4WD, AdditiveOCD, A1O, 2009Edge, 9 invisible), 1,589 guests, and 63 spiders.
Topics286,323
Posts4,906,412
Members67,599
Most Online2,967
Mar 10th, 2019
Sonata rear brakes #4800981
06/29/18 10:12 PM
06/29/18 10:12 PM
NH
supton Offline OP
supton  Offline OP
NH
Friend of mine just said he needs rear brakes on a 2011 Sonata. I just YouTube'd how to do the job, got that much. I don't know his budget yet, nor if I need to get rotors just yet, but I'll assume he wants budget. Yet decent quality. OEM or is AutoZone et all "better"? I will probably be able to mail order parts if need be.
Also, the vid said it had phenolic pistons. Can I use the usual disc brake tool, or do I need something special?
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 147k, ours
1999 Toyota Camry LE, 2.2L/4AT, 203k, his
Re: Sonata rear brakes [Re: supton] #4800987
06/29/18 10:21 PM
06/29/18 10:21 PM
USA
slacktide_bitog Offline
USA
You might as well replace the rotors anyway, since they are very easy to slide off and back on once you take the pads out.
The best rotors to get are EBC Premium, Centric Premium, or Wagner E-shield. Coated rotors really *do* make a difference! Non0coated rotors will rust overnight, but the coated ones really do help keep the rust off. They don;'t last forever, but they do last quite awhile!
Pair them with Akebono ProACT or EBC Ultimax2 pads smile
Re: Sonata rear brakes [Re: supton] #4800996
06/29/18 10:36 PM
06/29/18 10:36 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Hmmn,rear brakes on a 7 yr old Sonata.If the rotors aren't chewed up, how about doing a relube on the slides and a simple pad swap
Thick oil is better grin2
Re: Sonata rear brakes [Re: supton] #4801000
06/29/18 10:45 PM
06/29/18 10:45 PM
NC
ruhroh Offline
ruhroh  Offline
NC
Phenolic pistons just mean the material it's made out of, so use your usual brake compressor tool that'll fit.
Some phenolic pistons might swell over time and prevent new pads from releasing after braking so go for a short test drive after all's said and done.
Re: Sonata rear brakes [Re: andyd] #4801023
06/29/18 11:46 PM
06/29/18 11:46 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
+1 depends on how rusty they are.
When mine needs brakes, front or rear, it'll just get a pad slap.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Sonata rear brakes [Re: supton] #4801117
06/30/18 06:32 AM
06/30/18 06:32 AM
NH
supton Offline OP
supton  Offline OP
NH
Thanks on the pistons.
I'll ask and see if they are original. If so then I'll assume they need to be replaced. 7 years is a long time for rotors. Mine are always grooved and kinda ratty after 5. If I can, I'll see if I can do an inspection first, as a pad slap would be easiest & cheapest!
Re: Sonata rear brakes [Re: supton] #4801196
06/30/18 08:30 AM
06/30/18 08:30 AM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
Replace the rotors too. Avoid the cheap, no name rotor brands. It's a small price to pay.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Sonata rear brakes [Re: supton] #4801365
06/30/18 12:01 PM
06/30/18 12:01 PM
Texas
JustinH Offline
JustinH  Offline
Texas
Let me know if you have any trouble with the e brake cable.
I always have trouble with rear brakes, have never done my sonata before.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: Sonata rear brakes [Re: supton] #4801400
06/30/18 12:28 PM
06/30/18 12:28 PM
Texas
JustinH Offline
JustinH  Offline
Texas
After watching the youtube video on this vehicle, what a pain in the rear end.
Need to move the lower control arm and shock out about 1/16th of an inch to get at the lower caliper bracket bolt?
I would not do this job myself on jackstands.
Aligning that control arm is going to be fun, and putting it all back together.
If the rear rotors are serviceable, I would pay a shop to replace the pads, and let them machine the rotors with an on car brake lathe.
'11 Scion XB
Re: Sonata rear brakes [Re: supton] #4801414
06/30/18 12:52 PM
06/30/18 12:52 PM
NH
supton Offline OP
supton  Offline OP
NH
I didn't get the impression that it would mess with alignment. Looks like poor engineering but nothing that bad really. Two extra bolts and a jack to hold it up, not exactly awful.
Re: Sonata rear brakes [Re: supton] #4801641
06/30/18 05:32 PM
06/30/18 05:32 PM
Texas
JustinH Offline
JustinH  Offline
Texas
No not wheel alignment. I was talking about lining up the control arm with the hole to get the bolt into it.
'11 Scion XB
Re: Sonata rear brakes [Re: supton] #4802240
07/01/18 11:32 AM
07/01/18 11:32 AM
North Carolina
Urshurak776 Offline
Urshurak776  Offline
North Carolina
Just did this on my daughter's car. I like the price/performance of the Raybestos coated rotors and their service grade pads for rear and professional pads for the front. The whole rear job with coated rotors and pads from rockauto was about $60 shipped.
2012 Hyundai Santa Fe, 138,000 miles, Havoline Pro DS Full Syn 5W-30, WIX Filter.
2014 Kia Rio, 80,000 miles, Havoline Pro DS Syn 5W-30, WIX Filter.
Re: Sonata rear brakes [Re: supton] #4802354
07/01/18 01:16 PM
07/01/18 01:16 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
When I did the rears on my 2008 Hyundai Santa Fe AWD back around 2011, I wound up busting up some of the P-brake hardware in the process because the rotors were SO stuck on. Each little piece of the P-brake hardware was a dealer only part at the time. Other than that, it was you typical rear brake job, where the parking brake is built into the hat of the rotor. I think I used Carquest or Napa pads and rotors at the time. Not awfully expensive IIRC.
If I were you, I would run the car around with the parking brake on to wear some clearance so those rotors come off. I didn't know this trick back then.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Sonata rear brakes [Re: supton] #4811209
07/11/18 11:20 AM
07/11/18 11:20 AM
NH
supton Offline OP
supton  Offline OP
NH
Raybestos is good? Ok, I'll check with my friend and see if he wants to go that route. Cheap enough.
Re: Sonata rear brakes [Re: supton] #4811243
07/11/18 12:01 PM
07/11/18 12:01 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
The pads are good but look for different rotors like the ones mentioned above. The Raybestos rotors don't paint the backside of the rotors which may result in early rust there. Below is from a different thread.
Originally Posted By: slacktide_bitog
Originally Posted By: SatinSilver
What about the Raybestos coated rotors? I never see you mention them.
Raybestos doesn't coat the inside of the hat, so they will stick to the hub. Centric and Wagner do coat the inside hat, so they will not freeze to the hub. Also, Raybestos usually costs more than the other brands I mentioned.
Here's an example, for the 8th gen Civic (select any year from 2006-2011 on Rock Auto)
Raybestos
Centric
Wagner
