Toyota 3.4L 5VZ-FE Crank Sprocket
by The Critic. 02/22/19 07:08 PM
Weird Noise After Shutdown - 2018 Giulia
by RamFan. 02/22/19 07:01 PM
2019 Honda Passport
by mailman74. 02/22/19 06:56 PM
Who is censoring me? public wifi
by Vern_in_IL. 02/22/19 06:53 PM
Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
114 registered members (2015_PSD, 2009Edge, AdditiveOCD, Al, 2004tdigls, 10WSmuckers, 9 invisible), 1,706 guests, and 54 spiders.
Topics284,683
Posts4,874,985
Members67,313
Most Online2,548
Feb 16th, 2019
Stuck brake caliper story #4800938
06/29/18 07:57 PM
06/29/18 07:57 PM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
I jump on the highway this evening and about 1 mile down the road, I think: something ain't right. The steering wheel is vibrating and my Accord keeps downshifting on a flat road to maintain speed set by the cruise control.
Rest stop is 1/2 mile ahead. I pull over. Slight smoke coming from front right wheel. The rim is hot. I don't know what to do. I need to get to an appointment in 40 minutes that's 30 miles away. I go into bathroom and repeatedly grab 40 ounce cups of cold water and drown the caliper and rotor... There's a steam bath pouring off the wheel. After about 2 gallons of water were poured onto the brakes, the steam stopped.
I slowly backed the car up a few feet and moved it forward.... There was no noise and appeared that no drag was present. I got back on the highway, hit 55mph for a few miles, pulled off at the exit, and the wheel wasn't hot.
I completed my trip, 90 miles total, without further issues.
What could have caused this??
The front brakes were replaced 20k miles ago. There's plenty of pad left. That same rotor was "hung up" 20k miles ago, and that same wheel not only got new pads and rotors, but also a new caliper and brake line because of the excessive heat generated from being "stuck". Today the new caliper WAS hung up, but it seems ok now.
The last time I drove the car was Sunday, and I was on the turnpike for 800 straight miles, going 80-90 mph, making a few stops as I drove back to Indiana from New Haven, Connecticut. There wasn't an issue then.
And as a side note: the rotor isn't warped from getting smoking hot and then being drenched in water. There is ZERO shake or vibration in the steering wheel when I apply the brakes.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Stuck brake caliper story [Re: Phishin] #4800946
06/29/18 08:12 PM
06/29/18 08:12 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Just a wild guess. The caliper slides need attention
Thick oil is better grin2
Re: Stuck brake caliper story [Re: Phishin] #4800953
06/29/18 08:22 PM
06/29/18 08:22 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
As above. Whatever it was that was stuck, its a fair bet that the dimensional changes caused by your emergency thermal shock un-stuck it. Its likely it'll stick again though, and that is a high risk technique to use routinely.
Strip, clean, and lubricate.
Re: Stuck brake caliper story [Re: Phishin] #4800954
06/29/18 08:25 PM
06/29/18 08:25 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
You probably warped the caliper slides to the point where they aren't even allowing the caliper to move anymore.
I'd replace the caliper and lube everything at the bare minimum.
Re: Stuck brake caliper story [Re: Phishin] #4800984
06/29/18 09:15 PM
06/29/18 09:15 PM
NH
supton Offline
supton  Offline
NH
I'd tear it apart and find out what is up. Make sure to push the Piston in and see if it is hard to push--if so, replace caliper. Otherwise lube up and keep an eye on it.
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 201k, his
Re: Stuck brake caliper story [Re: Phishin] #4800989
06/29/18 09:23 PM
06/29/18 09:23 PM
USA
slacktide_bitog Offline
USA
Replace the caliper anyway. Because next time, it won't be ok later.
The best ones to get are Cardone Ultra or Napa Eclipse. They are coated to stop the rust.
Re: Stuck brake caliper story [Re: slacktide_bitog] #4800992
06/29/18 09:27 PM
06/29/18 09:27 PM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
The green Permatex ultra synthetic caliper grease locked up the lower guide pins on my Subaru.. The bottle doesn't say anything about how it's only for metal to metal contact, it clearly says that you can use it on guide pins.. Except for on cars like mine that have rubber anti-rattle bushings on the metal guide pins. So I guess I'm trying to say, I wonder if your caliper guide pins have rubber bushings on them that swelled and froze the caliper. Granted, my brakes didn't fully lock up or anything. The pad on inside that the pistons push against was doing the braking, and had more wear than the outer pad.
Re: Stuck brake caliper story [Re: Phishin] #4801005
06/29/18 09:52 PM
06/29/18 09:52 PM
NY
demarpaint Offline
demarpaint  Offline
NY
If you're going to replace the caliper you might as well do the brake hose too. Often the hose breaks down from the inside out and some that material can break loose and cause the caliper to malfunction. Replacing the caliper alone and leaving a bad hose can cause the replacement caliper to fail early.
God Bless Our Troops
Re: Stuck brake caliper story [Re: Phishin] #4801085
06/30/18 03:26 AM
06/30/18 03:26 AM
A Warm place to live in
berniedd Offline
berniedd  Offline
Until you get it figured out, bring lots of plastic jugs filled with water.
Re: Stuck brake caliper story [Re: Phishin] #4801086
06/30/18 03:32 AM
06/30/18 03:32 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Caliper itself, internal failure of brake hose or binding caliper slides.
The "thinking" man's friend.
Re: Stuck brake caliper story [Re: Phishin] #4801091
06/30/18 03:45 AM
06/30/18 03:45 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I agree with the flexible brake hose. This is a common problem and should be replaced with the caliper.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Stuck brake caliper story [Re: demarpaint] #4801098
06/30/18 04:38 AM
06/30/18 04:38 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 Good call Frank. Not saying that's the only possibility but its good practice. It could be slides, piston binding, pins, hardened grease on the pins, etc.
I would get a pair of Reybestos Opti-Cal calipers from Rock, they are brand new not rams and are only about $60ea. These are what I am using now instead of remans, there is no core so if you have OE never rebuilt calipers you can keep them to rebuild yourself later.
Re: Stuck brake caliper story [Re: Phishin] #4801109
06/30/18 05:09 AM
06/30/18 05:09 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I suspect you know the answer already. Pull the caliper and examine everything that moves. If its the sliding pins then clean and lube if pins are not rusted, if rusted then replace the pin. If piston does not do back in, replace caliper, if nothing is found, then replace flex hose.
Check rotor with a dial gauge for runout.
2015 Ford F250 w/Powerstroke
Re: Stuck brake caliper story [Re: Phishin] #4801164
06/30/18 06:48 AM
06/30/18 06:48 AM
ME
eljefino Offline
eljefino  Offline
ME
I had this happen. The car had been sitting a couple years. But the final cure was a new master cylinder. The little hole in it that lets fluid back up when the foot's off the pedal was restricted/ blocked/ pedal pushrod out-of-calibration. After fixing the calipers I sometimes had a rock-hard pedal-- the hydraulics had a pressure preload. You should always have a little slop.
Re: Stuck brake caliper story [Re: Donald] #4801195
06/30/18 07:29 AM
06/30/18 07:29 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
You can actually strip and clean calipers, if you can be bothered. Quite satisfying.
Moderated by  ekpolk
