0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Need new Binoculars
by FirstNissan - 11/20/19 09:47 PM
Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
83 registered members (69Torino, 69GTX, 2004tdigls, 4WD, 2010Civic, 7 invisible), 1,455 guests, and 26 spiders.
Topics297,700
Posts5,120,942
Members69,924
Most Online3,589
Nov 2nd, 2019
Sun shade, which side faces out? #4800374 06/29/18 07:37 AM
M
MoneyJohn Offline OP
M
Hello folks,
I am not trolling, a serious question.
I have a cheap $10 sunshade, both sides are silver in color but one side is flat like Aluminum foil and another side is creasy/wavy/not smooth and fluffy in the material. So which side should I face out?
I have tried both and I do not 'feel' the difference, so not too sure if there is any standard for this or put the way you like.
Many thanks
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800376 06/29/18 07:38 AM
H
HemiHawk Offline
H
Shiny side out.
2015 Mustang GT
2017 VW GTI sport
1995 Mustang GTS
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800427 06/29/18 08:34 AM
M
M
Both sides are shiny, flat Aluminum side or creasy fluffy side?
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800440 06/29/18 08:45 AM
M
mbacfp Offline
M
Can you post a pic? Aluminum side out, fluffy side inside...would be my guess without pic.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800477 06/29/18 09:20 AM
Yah-Tah-Hey Offline
The side that was out when new is the side that goes out. Probably doesn't make that much difference.
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800507 06/29/18 09:55 AM
Schmoe Offline
most shiny, reflective surface out. You're trying to reflect the sun rays out of your interior, the insides are going to get hot still regardless.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800533 06/29/18 10:33 AM
H
hallstevenson Offline
H
My son bought me a Star Wars sun shade. One side is dimpled and the other side is smooth(er) has an image with Luke, Obi-Wan, and so on. Only makes sense that the image side is out.
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800554 06/29/18 11:13 AM
R
raytseng Offline
R
it probably doesnt matter if its cheap.
The reflectivity of dimpled vs smooth is inconsequential if they are both foil. The dimpled may be less of a hazard as it disperses the reflected light though.
On more expensive shades, he fluffier dimpled side goes out, because the dimples are due to a thin layer of foam insulation. (it is still foiled).
So it goes dimpled foil-> foam-> backing->smooth.
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800598 06/29/18 11:41 AM
blupupher Offline
if both sides are shiny, I don't think it really matters. The most reflective side would probably be best, but I doubt anything significant .
Just having anything in the window will reduce the heat inside the vehicle.
5k: 2018 Santa Fe: PP 10W-30/OEM
6 mo: 2018 Soul: Synpower 5W-30/PrimeGuard
Annual: 2012 xB: M1 EP 0W-20/CQ Blue, 2002 F150: Magnatec 5W-20/Bosch D+, 1994 VT1100: Peak 15W-40/D+
Re: Sun shade, which side faces out? [Re: MoneyJohn] #4800620 06/29/18 12:06 PM
T
Triple_Se7en Online Content
Online Content
T
Smooth side where it might collect the most dirt, dust, fade / sun.. Keep the fluffy side where the least amount of maintenance will occur.
19 Hyundai SantaFe 2.4GDI Valv Syn 5w30 / NAPA O/E filter / 6oz Liqui-Moly Treatment
20 Kia Soul X-Line 2.0 non-turbo / Factory-fill oil / filter
04 Colorado 3.5 / Castrol Edge 0W40 Euro / K&N filter
