Originally Posted By: boulderdentist
High pressure side is larger than low pressure side so you can't connect wrong components. There is a tool which allows the valve to be replaced without loss of refrigerant. I got mine on Amazon as well as the Schrader valves.
Scott
Based on the little research I have done, the special tools made by MasterCool etc. are too small for the bigger fitting that I have.
